Page 1 of 5 1 2 3 4 5
it's time for [b]DON'T ASK ME HOW I KNOW[/b] #2018007
02/23/16 01:07 PM
02/23/16 01:07 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
as in the past at race season beginning or end relate your contribution,
. please follow with DON'T ASK ME HOW I KNOW
when you change the position of your seat be sure to check
if you fit with your helmet on and not wait until you are at the track
home of the
Sox and Martin Hemi Duster
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: HEMIFRED] #2018025
02/23/16 01:33 PM
02/23/16 01:33 PM
muskegon MI
v cummins Offline
v cummins  Offline
muskegon MI
When filling the cool can with ice don't forget to put the lid on.
DON'T ASK ME HOW I KNOW. snowblow
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: HEMIFRED] #2018034
02/23/16 01:45 PM
02/23/16 01:45 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
When building your own headers, don't forget to allow for spark plug access.
[image][/image]
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: HEMIFRED] #2018038
02/23/16 01:55 PM
02/23/16 01:55 PM
Brea, Ca
Dart Racer Offline
Dart Racer  Offline
Brea, Ca
It IS possible for a 4" carb stud to pass through the intake and the valves to enjoy a home in the top of a piston.......
Don't ask me how I know........grrrrrrrrrr
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: HEMIFRED] #2018048
02/23/16 02:02 PM
02/23/16 02:02 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
always go to the bathroom before getting strapped in the car and pulling into the staging lanes.Believe me I know. whistling nervous work
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: HEMIFRED] #2018052
02/23/16 02:12 PM
02/23/16 02:12 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
When priming a new engine make sure it has an oil filter - if not it takes about 15 seconds to put 5 quarts of oil on the floor while you wonder what you did wrong!
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: HEMIFRED] #2018060
02/23/16 02:32 PM
02/23/16 02:32 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Install the oil pressure gauge line before testing the oil accumulator. Don't ask how I know.
Doug
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: HEMIFRED] #2018061
02/23/16 02:32 PM
02/23/16 02:32 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
If you keep shearing off ring gear teeth, you may want to check and make sure that your timing chain hasn't jumped, rather than repeatedly dropping the transmission and replacing the ring gear on the converter.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: HEMIFRED] #2018075
02/23/16 03:00 PM
02/23/16 03:00 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Touching the positive battery post and the engine block with a dipstick makes for a very hot thin piece of metal. Don't ask me how I know, or about the scar
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: CTD5.9] #2018078
02/23/16 03:05 PM
02/23/16 03:05 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
When removing a mechanical fuel pump make sure the outlet fitting isn't facing up and the arm isn't on an up swing. Don't ask me how I know...
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: HEMIFRED] #2018079
02/23/16 03:06 PM
02/23/16 03:06 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
GREAT STUFF KEEP IT COMING
many looks but only a few posts ? could they be too embarrassed or are they perfect?
home of the
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: HEMIFRED] #2018082
02/23/16 03:13 PM
02/23/16 03:13 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
if you go to start your car and the engine locks up ,dont start taking the motor apart.check to see if you forgot to put the power valve plugs in the carb.
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: HEMIFRED] #2018085
02/23/16 03:16 PM
02/23/16 03:16 PM
K
Kiddart Offline
Kiddart  Offline
K
Make sure you check your helpers work, especially when it comes to lug nuts,
Ask me how I know.
Thank you
Kiddart
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: HEMIFRED] #2018102
02/23/16 03:54 PM
02/23/16 03:54 PM
sgcuda Offline
sgcuda  Offline
Make a checklist before you leave home. You don't want to get to the track and find out you forgot something...
Like your helmet eek
[image][/image]
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: HEMIFRED] #2018112
02/23/16 04:00 PM
02/23/16 04:00 PM
K
Kiddart Offline
Kiddart  Offline
K
haha
I know that feeling as well.
Thank you
Kiddart
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: sgcuda] #2018113
02/23/16 04:05 PM
02/23/16 04:05 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Make sure the brake parts cleaner has dried before you start using the angle grinder nearby!
DAMHIK!
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: sgcuda] #2018115
02/23/16 04:08 PM
02/23/16 04:08 PM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
When you release the trans brake button at starting line make sure you dont bump your Shifter (Turbo Action) into nuetral. Ask me how I know.
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: HEMIFRED] #2018134
02/23/16 04:47 PM
02/23/16 04:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Fuse it!
DAMHIK
68 Barracuda Formula S 340
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: Bad340fish] #2018141
02/23/16 05:00 PM
02/23/16 05:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Make sure you bring the key to open up the
trailer... DAMHIK
wave
Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b] [Re: HEMIFRED] #2018142
02/23/16 05:01 PM
02/23/16 05:01 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
Back out the adjustable oil pressure adjuster, prior starting your engine.give it only a few turns to you see were the oil pressure is. pop that oil filter like a soda can. help
