Re: Moog or PST?
[Re: Sniper]
#2980304
10/31/21 05:13 PM
10/31/21 05:13 PM
Posts: 270 Mountain View, CA
68rrunner
Mountain View, CA
I went with PST for my front end rebuild except for both sides of the torsion bar because of the issue kentj340 notes. I've heard issues with using poly on the torsion bars as well so I felt that would be better served using rubber. That said, I am very pleased with the feel of the upgraded suspension. To the best of my knowledge no Mopar torsion bar uses any bushings on either end. Do you mean the strut rods? If so, they only use a bushing on one end. I'd wager he's referring to the grease boot on the T-Bar.
Re: Moog or PST?
[Re: 68rrunner]
#2980314
10/31/21 05:42 PM
10/31/21 05:42 PM
Posts: 10,752 North Dakota
6PakBee
North Dakota
I went with PST for my front end rebuild except for both sides of the torsion bar because of the issue kentj340 notes. I've heard issues with using poly on the torsion bars as well so I felt that would be better served using rubber. That said, I am very pleased with the feel of the upgraded suspension. To the best of my knowledge no Mopar torsion bar uses any bushings on either end. Do you mean the strut rods? If so, they only use a bushing on one end. I'd wager he's referring to the grease boot on the T-Bar. I thought he was referring to the lower control arm bushings!!
Re: Moog or PST?
[Re: 68rrunner]
#2980315
10/31/21 05:42 PM
10/31/21 05:42 PM
MoreParts
I went with PST for my front end rebuild except for both sides of the torsion bar because of the issue kentj340 notes. I've heard issues with using poly on the torsion bars as well so I felt that would be better served using rubber. That said, I am very pleased with the feel of the upgraded suspension. To the best of my knowledge no Mopar torsion bar uses any bushings on either end. Do you mean the strut rods? If so, they only use a bushing on one end. I'd wager he's referring to the grease boot on the T-Bar. I did mean the strut rod. Sorry, it's been a little while. I went with moog rubber on both ends. Kent's pic above and a few other problems with going with poly is why I chose that.
