Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project
[Re: 10secGTX]
#2010415
02/12/16 11:21 AM
02/12/16 11:21 AM
Posts: 10,658 Rittman Ohio
fourgearsavoy
Rittman Ohio
I hope you ordered the extra tall shifters for that Lenco Looking forward to seeing it this summer at a dragstrip near us Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Blown 68 R/T]
#2010429
02/12/16 11:59 AM
02/12/16 11:59 AM
Posts: 17,929 Akron, Ohio
ProSport
Akron, Ohio
Very nice looking B-body! I think you're gonna need more hood pins with your new motor. Bob, car should look familiar, it was Labrat's(Randy B's). Awesome!!
[Re: lockjaw-express]
#2016833
02/21/16 08:18 PM
02/21/16 08:18 PM
fourgearsavoy
Rittman Ohio
Wow that fits better than I thought it would Glad to see more guys not afraid to cut a big hole in the floor to get transmission they want in the car . Have you put the shifters on and made a few passes yet Gus
#2032139
03/16/16 01:24 AM
03/16/16 01:24 AM
fourgearsavoy
Rittman Ohio
Wow that is one pretty chunk of transmission right there There sure are some awesome stick Mopars on this site Gus
#2032150
03/16/16 01:58 AM
03/16/16 01:58 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Should put a 4 speed hump and boot for every lever! That would be nuts!
Mopar to the bone!!!
[Re: 72Swinger]
#2032274
03/16/16 10:35 AM
03/16/16 10:35 AM
Posts: 3,313 West Coast, USA
jbc426
West Coast, USA
I had to modify my torsion bar crossmember and reinforce it to install a 200R4 in my A-Body. It looks like you cut the torsion bar crossmember completely out over the transmission and notched your bolt-on rear motor mount too. I'm curious about your solution for reinforcing those areas to get the strength back into those critical chassis components, especially on a torsion bar car. Please post some pictures of your set-up.
I'm no expert, but it looks like adding a second crossmember towards the rear of the transmission tied to the sub-frame connectors would work a lot better than the long tubes your using for an additional rear motor mount attaching point. The leverage those long bars have to work against those minor attachment points on the crossmember don't look like they would last long with the forces at work against them.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2032304
03/16/16 11:17 AM
03/16/16 11:17 AM
Posts: 562 Ohio
lockjaw-express
Ohio
Hi JBC, yes, I have been thinking that as well...great idea, thank you!
I looked at my car today, and you gave me a great idea. Thank you again.
Also, if someone out there knows how to hide the shifter pushrods and the shifter towers that stick out the tunnel, I am open to all ideas.
This is why I love posting on Moparts...always great ideas!
BR, Mark
#2032722
03/16/16 09:55 PM
03/16/16 09:55 PM
72Swinger
Nebraska
BR, Mark I did the frame connector mount deal for my 6 spd swap.
[Re: 72Swinger]
#2032924
03/17/16 06:34 AM
03/17/16 06:34 AM
jbc426
West Coast, USA
BR, Mark I did the frame connector mount deal for my 6 spd swap. Beautiful rear transmission mount. Are you running torsion bars or a coil-over front suspension? If torsion bar, you may want to reinforce the torsion bar crossmember, or you will begin to see cracks on your floor pan due to the flexing of the cut-out crossmember.
