Re: trailer tire [Re: max_maniac] #2015669
02/19/16 09:13 PM
02/19/16 09:13 PM
Originally Posted By max_maniac
Originally Posted By jwb123
My experience is that it is not your weather, it is your tires. Standard 15 inch trailer tires are JUNK. I converted my last trailer to 16 inch, 10 ply light truck tires and never looked back, two years parked outside and no problems. Tire shop got me a size that was only 1/2 inch taller than my regular 15 tires, so all I had to do was buy rims.
With 15 inch trailer tires I used to blow out on average at least two a summer. Had damage to trailer, and changing trailer tires on the interstate is much more dangerous than drag racing.
Bought a new trailer this year and 16 inch tires were an option, so I got them on it as well.
[u][/u]
The light truck tires are NOT LEGAL in most states. There are many states that it is the law that the tire has to be marked "Trailer Tire". I'm sure if I had 15" light truck tires they may last longer too but they are not legal for me.
Do you know or know of any other person being stopped by the local law enforcement and looked at thier trailer tires for the "trailer tire only" designation labels work I know I always look at the GVW rating on all of my tires, truck, car and trailers, to make sure there rated a bunch (minimum of 10%+) higher than the known load I'm towing or carrying up I have fought that war on enclosed car trailer tires blowing up for no reason runaway I've had some that weren't two years old and where ran at 5 lbs more pressure cold than what was on the sidewall and the load on each wheel and tire was 1200 lbs less than the max GVR of those tires confused I haven't lost one in the last three years, knock on wood, so I will probally have three of them blow out on the next long trip to a race work shruggy I carry three spares now ready to go now realcrazy grin I have had two tires come apart 80 miles apart from each other on the same trip, I also lost two by running over a rock in the dark on early morning before sunrise runaway I missed it with the truck and hit it with both of the right side trailer tires, bent the rims and ruined the sidewalls whiney
Re: trailer tire [Re: bonefish] #2015694
02/19/16 09:54 PM
02/19/16 09:54 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
My trailer has the 16" tires, that's what it came with, my time limit is 4 years, and that's buying good tires, at 5 Ill blow 1 or 2 tires that season, so I swap them at 4.
Re: trailer tire [Re: wyoming] #2015700
02/19/16 10:08 PM
02/19/16 10:08 PM
IN
ahy Offline
ahy  Offline
IN
Most common tire dressings actually accelerate degradation according to Michelin. I think the tire covers and best tires you can fit will help the most.
Re: trailer tire [Re: ahy] #2015809
02/20/16 01:08 AM
02/20/16 01:08 AM
Winter Park, Florida
classracer Offline
classracer  Offline
I fought the tire blow out woes for years. 26' Haulmark trailer st225x75r15 tires rated at 2550 lbs each. I kept them covered, tried an extra 10 psi while towing. Bottom line you better replace them every two years, and hope for the best during the two years. I just changer over to 16" wheels and Goodyear Lt245x75r16ht tires that are rated at 3100 or so pounds each. Normal inflation is 80psi. I wanted to use LT235x85r16 tires, but I did not have room. So far things seem to be much better. The trailer sits 2" higher, the ride is better, the tires don't bow out when in contact with the road, and when towing they run much cooler. Eventually I will have the trailer in a barn and on concrete, but for now tire covers and a piece of plywood on the sun side.
70 Challenger A/SA 2441
Re: trailer tire [Re: bonefish] #2015883
02/20/16 02:53 AM
02/20/16 02:53 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
From 97 to 2014 my Haulmark trailer had about every 15" combo you could think of on it.... and it came down to the same as many. Throw them out after two years.
My dad got out of racing so we sold the 24ft and kept his Cargo Mate 28ft trailer. It has 235/85/16 tires and now it looks like I'm back in the two year deal because this trailer is eating the tires off it!!! The right rear seems to be taking the brunt of it as it will be 6-8 degrees warmer when I stop for a rest and check them. I'm hoping to find somewhere to try and get it aligned.
Re: trailer tire [Re: J_BODY] #2015894
02/20/16 03:32 AM
02/20/16 03:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Haulmark bought the cheapest crap tire you can
buy(Carlisle) they could blow with just the weight
of the empty trailer... I run a 43' trailer with 2
axles.. very heavy duty ones.. I buy the best tires
for the 16" rims.. I have had 1 blow out.. that was
after 7 years on them.. and that was part my fault..
the wheel cover fell off on the sunny side of the
trailer and it sat for a few months like that.. I run
the MAX air pressure the wheel can take..95psi and I
check the pressure EVERY time that trailer goes out the
drive way(the tire can take 100psi but the wheels are
only 90psi so I run a couple psi high for the wheel
EDIT
The 43' is not Haulmark.. thats my home made
trailer.. my old 26' was a Haulmark
wave
Re: trailer tire [Re: J_BODY] #2015896
02/20/16 03:36 AM
02/20/16 03:36 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
What type of axles do you have on your trailer ? I have the torsion type and when I loaded up the trailer to max the axles would deflect and wear out the tires fast from over heating.
Re: trailer tire [Re: bonefish] #2015905
02/20/16 04:05 AM
02/20/16 04:05 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Our 24ft Haulmark had torsion flex axles (5K axles). Our current Cargo Mate has leaf springs. Personally, looking under the trailer, it looked like an afterthought the way the leaf perches are welded to boxes welded to the frame. Long story... my dad ordered the trailer. I told him to absolutely get the big axles, and 16" wheels. It showed up with 15" wheels. He was going to accept it, until we discussed once again the tire he77 I'd been living..... so, he took the trailer back to where he bought it. From there I have no idea what happened.... other than it had 16" wheels (six lug 16" wheels on 5K axles) the first time I saw it. We got 4 years out of the first set of tires, but most of that was short trips to the local track with a couple long treks from SoDak to our home in AZ. The current set of tires have only been on a little over a year and the outer edge is wearing badly on a couple.... right rear seems to be the worst.
Re: trailer tire [Re: MR_P_BODY] #2015967
02/20/16 11:39 AM
02/20/16 11:39 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
EDIT
wave
care to share what you consider the BEST tire.i,d rather spend more than waste less.
Re: trailer tire [Re: bonefish] #2015977
02/20/16 12:01 PM
02/20/16 12:01 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
EDIT
wave
If you go on this website and do some reading it is USUALLY kept up to date with lots of good info. I had issues with the generator in my motorhome and these guys straightened me out. Most of these guys are full-time RV'ers so they are on the road all the time. Lots of good up to date info on tires. For me like I said I'm stuck with 15 inch tires and 3500 pound axles so I'm overloaded (not legal) every-time I go to the track. I have had very good luck with the Carliles upgraded 10 ply tires. I get 4 years out of my tires and I tow 80 mile round trip every week from April 1st to the second week of November and usually 3 trips a year to Norwalk a year at 400 miles round-trip. I park on gravel at home during the week and over the Winter. Trailer is always parked outside in PA weather with the tires uncovered. http://www.rv.net/
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: trailer tire [Re: bonefish] #2015982
02/20/16 12:08 PM
02/20/16 12:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
EDIT
wave
Dont quote me but I believe the last set I bought
were Marathon trailer tire(Goodyear).. the heaviest
rated I could buy. was F or G rated... I have tried
others but they werent rated as high.... I'm not home
right now so I cant go see what I have
wave
Re: trailer tire [Re: bonefish] #2016112
02/20/16 03:58 PM
02/20/16 03:58 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I use the tire covers and it does keep the tires looking better with no cracks.
However it is the age that seems to get them. Don't ask me how I know.
Bill
Re: trailer tire [Re: bonefish] #2016443
02/21/16 01:50 AM
02/21/16 01:50 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
My Haulmark which I purchased in 97 was equipped with Goodyear Marathons. After two years or so a sizable egg appeared on the sidewall..... Goodyear replaced all four tires no questions asked (recall). As I remember the score card read like this. 2 sets of GY Marathons, Carlisle (needed tires NOW.... tread was coming off GY, noted at the track.... might have been three to four years on those, I was in denial about them lasting), cheap Chinese tires two years, my first set of Maxxis 10 plys... two years, second set of some sort of 10 ply, two years...
My present trailer has "HI RUN" 16" tires on it. Max psi listed at 90, but I run 80. The trailer was originally equipped with some other Chinese tire.
I hate trailer tires....
Re: trailer tire [Re: bonefish] #2016516
02/21/16 10:42 AM
02/21/16 10:42 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Those goofy looking airless tires they make for heavy equipment might eventually find an application here. However I am sure age and lack of use causes problems with those as well.
68 Barracuda Formula S 340
Re: trailer tire [Re: Bad340fish] #2016583
02/21/16 01:40 PM
02/21/16 01:40 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
MAN! this is confusing.if you go to the tire sellers web reveiw all tires get 4 or 5 star reveiws.if you go to forum web reveiws there aint no such thing as a good trailer tire. shruggy
Re: trailer tire [Re: bonefish] #2016591
02/21/16 02:02 PM
02/21/16 02:02 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
In the 16" arena there is also the G rated tire with it's max inflation of around 120 psi, but I don't think my steel wheels are rated for them.... that and I'm not sure living in the desert that they would be prone to lasting any longer due to the environment. Back in June I left town to race in vegas. The road temp was 168 degrees. Stopped about 1/2 way for a snack break and my tire temps were 159. you can literally spend days reading info and stories on this subject. This was one bit of helpful info I found years ago at Discount Tires web site:
Trailer Tire Applications
•Trailer tires are designed for use on trailer axle positions only. They are not built to handle the loads applied to, or the traction required by, drive or steering axles.
Inflation
•Always inflate trailer tires to the maximum inflation indicated on the sidewall.
•Check inflation when the tires are cool and have not been exposed to the sun.
•If the tires are hot to the touch from operation, add three psi to the max inflation.
•Underinflation is the number one cause of trailer tire failure.
Load Carrying Capacity
•All tires must be identical in size for the tires to properly manage the weight of the trailer.
•The combined capacity of the tires must equal or exceed the Gross Vehicle Weight (GVW) of the axle.
•The combined capacity of all of the tires should exceed the loaded trailer weight by 20 percent.
•If the actual weight is not available, use the trailer GVW. If a tire fails on a tandem axle trailer, you should replace both tires on that side. The remaining tire is likely to have been subjected to excessive loading.
•If the tires are replaced with tires of larger diameter, the tongue height may need to be adjusted to maintain proper weight distribution.
Speed
•All "ST" tires have a maximum speed rating of 65 mph.
•As heat builds up, the tire's structure starts to disintegrate and weaken.
•The load carrying capacity gradually decreases as the heat and stresses generated by higher speed increases.
Time
•Time and the elements weaken a trailer tire.
•In approximately three years, roughly one-third of the tire's strength is gone.
•Three to five years is the projected life of a normal trailer tire.
•It is suggested that trailer tires be replaced after three to four years of service regardless of tread depth or tire appearance.
Mileage
•Trailer tires are not designed to wear out.
•The life of a trailer tire is limited by time and duty cycles.
•The mileage expectation of a trailer tire is 5,000 to 12,000 miles
One of the more "enlightening" things I noted was the "time" information, the "heat", and the general statement about pretty much not going by "tread wear".
Re: trailer tire [Re: bonefish] #2016818
02/21/16 09:03 PM
02/21/16 09:03 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I have a 24ft enclosed trailer and have gone through the tires too. I've been buying Carlisle from tire discount with $25 warranty. After buying 4 I am getting them for $25 apiece now, still sucks changing a tire on the side of freeway but $25 is better than full price. And if I catch them quickly with lumps they will replace them.
Re: trailer tire [Re: bonefish] #2016854
02/21/16 09:32 PM
02/21/16 09:32 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Im thinking they are designed to only last 4-5 years max. Remember back in the day on a trip to a "Junk yard" you could find tires that where 10-20 years old and would last till worn out. The down side is those tires lasting a long time in the dumps, in fact never going anywhere. So now they crumble and come apart in 6 years, brake down faster. Once all the tire manufacturers came on line making these, they make more money with the quicker turnover. Why would they want to make a tire that last 10 years when they can sell 2-3 sets in the same time. Make the EPA happy and get richer, no brainier.
Re: trailer tire [Re: bonefish] #2017487
02/22/16 04:51 PM
02/22/16 04:51 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
popcorn
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
