Re: MuuMuu's 68 Dart... It's a Learning Process...
[Re: NV69B7RR]
#1987176
01/09/16 09:49 PM
01/09/16 09:49 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
You will make it to MATS and the autocross!!! The most frustrating part of any build is delays that come from things outside your control. But book your room, schedule vacation from work, plan your route, and make going to MATS your attainable goal. Well, looking at the MATS website, there seems to be a cruise going to the event on Thursday that leaves from the Glendora Dodge Dealership 5 miles from my house all the way to Vegas. So, that was my plan of action to go to the event. If something goes wrong and I am unsure of fixing it, someone may have some nohow or someone they know to get it to Vegas.
[Re: MuuMuu101]
#1990132
01/13/16 08:12 PM
01/13/16 08:12 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
Sammy I have not been following every post on this thread but it sure seems like Hotchkis is jacking you around with the time it is taking. I had my mechanic install a complete TVS in my 69Dart and he did it ALL in 4 days in between all the other bread and butter shop work he had going on...a one man shop! I see some other stuff going on and I don't know what all it is but it still seems like it has been going on for a loooooong time!
Driving modern convenience in classic beauty
[Re: Darius]
#1990180
01/13/16 08:55 PM
01/13/16 08:55 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Sammy I have not been following every post on this thread but it sure seems like Hotchkis is jacking you around with the time it is taking. I had my mechanic install a complete TVS in my 69Dart and he did it ALL in 4 days in between all the other bread and butter shop work he had going on...a one man shop! I see some other stuff going on and I don't know what all it is but it still seems like it has been going on for a loooooong time! Well, I put together the entire TVS minus the sway bars and subframe connectors before I took it to them. What has taken most of 6 months has been making seat brackets, installing a steering wheel, and making a 6-point cage. What I'm going to have them do next is install the 408 and T56, a borgeson steering box, radiator, and other necessities. I don't want to talk down about Hotchkis because the quality of their work is amazing, but their priorities seem to favor quick customer product installations, the boss's projects, and then my car. My Dart is the lowest tiki-man on the totem pole. Just look at their Facebook page and you won't see a single picture or reference of my car unless it's far in the background. If I were them, I'd be pretty tired rolling my Dart in and out of the shop every day. Once I get my Dart back, there is no way in hell it is ever going to any shop again. It cost way too much money in labor and takes way too much time (granted if I were to do an engine and T56 swap, it would have probably taken me 5 years to do). Again, Hotchkis does great work but the turnaround time has been awful. Right now, they're just waiting on the engine which will be done in a week and a half so hopefully they can kick it into gear and finish the car.
[Re: MuuMuu101]
#1996766
01/23/16 01:17 AM
01/23/16 01:17 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
[Re: MuuMuu101]
#1996809
01/23/16 02:23 AM
01/23/16 02:23 AM
Posts: 16,165 Mesa, Arizona
dart4forte
Mesa, Arizona
Had a long day today. Drove all the way out to Indio to pick up the engine and drove all the way back to Santa Fe Springs to drop it off at Hotchkis. Engine looks real good and Brian was great to talk to. It's a 408 making 523 hp @ 6000 rpm and 522 ft lbs of torque at 4500 rpm.
Crank: Scat 4340 4" Rods: Scat 4340 I-beams 6.123" Pistons: Icon Forged Dish 4.030" Camshaft: Custom Hydraulic Rollers by Comp Cam Lifters: Morel Timing Set: Double Roller Oil Pump-Pickup-Pan: Milodon Road Race Pan and Pickup with Melling Pump
Heads: Engine Quest/IMM Intake Valves: 2.02 Exhaust Valves: 1.60" Rocker Arms: 1.6 Chromoly Intake: Port-Matched Edelbrock LD4B Carb: Holley 850 DP Timing: 34 deg
Headers: TTI shorties Why did you go with the LD4B? Wouldn't a LD340 or an Airgap been better. Runners in the LD4B awful small.
Abe Lincoln
[Re: dart4forte]
#1996816
01/23/16 02:30 AM
01/23/16 02:30 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Headers: TTI shorties Why did you go with the LD4B? Wouldn't a LD340 or an Airgap been better. Runners in the LD4B awful small. It's what I had at the time of the drop off and it was cheaper to port-matched. I figured it would be the largest restricter. Otherwise, I would have went with the Airgap. I was planning on saving the LD4B for a 273 build.
[Re: MuuMuu101]
#1998977
01/26/16 01:24 PM
01/26/16 01:24 PM
Posts: 1,671 Caldwell, Idaho
67R/T4speeder
Caldwell, Idaho
He didn't give them to me. It just says "custom" on the build sheet. Give Brian a call and see if he'll give it out. All he said is it's going to be pretty lopey and aggressive and will idle a little hard on warm up, but it when it's warm, it will start right up. Sounds like my Dart 340 cam, I was beginning to think I was tuning wrong for when cold. It was in there when I got the car so I do not know what is, but it sure runs good when warmed up:) I found some old Isky boxes in trunk but nothing with cam #s just retainers and springs. I put a new timing chain on just because I wanted fresh but I saw no #s on front of cam and had stock chain and sprockets still. I bet your will be a runner for sure also.
[Re: MuuMuu101]
#2003952
02/02/16 02:40 AM
02/02/16 02:40 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I talked to them again today, applying that pressure. Well, the '61 El Camino that has been in the shop for about a month or so was getting aligned today and should be done. However, the boss's Barracuda isn't done yet and won't be done till next Monday. They said, starting a week from Tuesday they'll get back on it. I told them to get on it. They're already ordering the PS box and radiator (of course charging more money). At this rate, there's no way the car is making it to MCATS. They still have to finish off a couple of the tubes in the side members of the cage. If anything, I may make it to Willow Springs for Spring Fling.
[Re: MuuMuu101]
#2004017
02/02/16 10:46 AM
02/02/16 10:46 AM
Darius
Sacramento, Ca
Squeaky wheels get grease Sammy. Go tell the owner you will be posting on these sites the kind of service you have received and see if he responds.
[Re: Darius]
#2004246
02/02/16 04:59 PM
02/02/16 04:59 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Squeaky wheels get grease Sammy. Go tell the owner you will be posting on these sites the kind of service you have received and see if he responds. I'm going to give them a couple weeks to give them the benefit of the doubt and see if they start working on my car again. I'm not the kind of guy who's just going to blaze someone on the internet. But people are already noticing based off of my threads that this is taking way too long.
[Re: Darius]
#2015122
02/19/16 12:50 AM
02/19/16 12:50 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Squeaky wheels get grease Sammy. Go tell the owner you will be posting on these sites the kind of service you have received and see if he responds. Sure seems like lack of service.. I have mentioned the same thing to Samy about squeaky wheel... They sure are dragging their feet working on his car IMO and can't imagine it would encourage any one else reading this to want to jump up and have them do a project on their car as well. ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: OzHemi]
#2015137
02/19/16 01:01 AM
02/19/16 01:01 AM
dart4forte
Mesa, Arizona
Is this the same outfit that sells suspension systems? If this is an example of their business practices I'd think twice before I put my car into a hostage situation.
Abe Lincoln
[Re: MuuMuu101]
#2016192
02/20/16 06:48 PM
02/20/16 06:48 PM
Darius
Sacramento, Ca
You car became so much MORE than what you started to build...awesome. Sure hope you get it for Willow Springs, I am really looking forward to seeing how it handles there.
[Re: Geo4K]
#2016213
02/20/16 07:38 PM
02/20/16 07:38 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Sweet baby Jesus, you're gonna enjoy it when you push the loud pedal in that car. I follow your build and enjoy the time you take documenting it all. You and Al V over at FABO and his 69 GTS do a great job. Too bad about the car-shop purgatory. I guess it's not just a paint and body thing...
Good luck - George Who's AI V? I don't think I've spotted that thread.
