Re: Trick Flow heads
[Re: fast68plymouth]
#2015732
02/19/16 11:19 PM
02/19/16 11:19 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Would like a pair of them. Nice work .
1963 Plymouth Max Wedge 1971 Barracuda
[Re: AndyF]
#2016027
02/20/16 01:24 PM
02/20/16 01:24 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I have my new clear top valve cover mounted up on the Trick Flow heads for the next round of dyno testing. Andy do those only fit with a non conventional distributor location?
#2018166
02/23/16 05:54 PM
02/23/16 05:54 PM
Posts: 1,361 Wild West
M_D
Wild West
Andy, how is the clear top going to be sealed to the rest of the valve cover? I can't tell if you have some sort of gasket in there and don't see any signs of an o-ring or groove.
I will/would be interesting to see in there while the engine ran.
[Re: AndyF]
#2020963
02/27/16 10:17 PM
02/27/16 10:17 PM
M_D
Wild West
Thanks for the explanation. Being able to see the valve train while running to check for proper oiling and to easily inspect it while not running makes a lot of sense to me. Especially on new engines and parts when things might need some sorting out and extra monitoring. I'll get some gaskets made for it. I also have a stainless steel beauty ring that goes on the top so the bolts aren't riding on the polycarb.
#2021191
02/28/16 12:12 PM
02/28/16 12:12 PM
crabman173
crabman173
Looks like fun! I had my hands on the Trick Flows yesterday for first time--WOW! All I can say is Happy Trails Indy!
[Re: 69 plymouth rnr]
#2024982
03/05/16 01:58 PM
03/05/16 01:58 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
This is a great thread but is there anyone who can confirm Trick Flows claims on a 440 build they claim . Or any other trick flow dyno numbers with different combos?? THANKS Had only one day to dink with these combinations. Trick Flow 240, .030" over 440, stock stroke, 9.9:1 compression, 850 Mighty Demon, Edelbrock Victor and RPM intakes, Solid roller 238/242 @ .050. Victor..... 500 lb-ft 3,300-6,100rpm 550 lb-ft 4,500-5,300rpm 562 lb-ft @ 4,800rpm 591 hp @ 5,900rpm RPM........ 500 lb-ft 3,100-5,900rpm 550 lb-ft 3,600-5,200 558 lb-ft @ 4,800rpm 575 hp @ 5,700
#2024993
03/05/16 02:18 PM
03/05/16 02:18 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
No, brand new build. Have done recent builds very similar but with cleaned up Victor heads and solid/hydraulic flat tappets.
[Re: AndyF]
#2033867
03/18/16 03:49 PM
03/18/16 03:49 PM
Posts: 65 Huntsville, AL
venom107
Huntsville, AL
I've heard that the low deck intake will be available by the end of the month. I'll get one on the dyno as soon as it shows up. The RB intake is available now from Summit but I haven't bought one since I don't have a standard port RB engine to use it on. Andy, I got my low deck TF intake in yesterday. Ordered last week. Still have a month or so wait on the heads, but the intakes are available.
#2034294
03/19/16 03:22 AM
03/19/16 03:22 AM
Posts: 619 nj
JAMESDART
nj
I'm curious about the ported m1, I noticed the other day the ports are pretty bad from one side of the intake to the other. I compared it to some edlebrocks and as much as people complain about them the eddys were much better. I'm bummed out, when I received my tf heads I opened one box looked at it and put them on the shelf. Since my rods were backordered I couldn't do much. The other day I opened both to check gaskets on the intake ports and comparee to some intakes. One of my heads was damaged before packing. The boxes are perfect. I have to call and see what can be done.
[Re: AndyF]
#2037438
03/23/16 10:09 PM
03/23/16 10:09 PM
Posts: 1,505 TN
SCATPACK 1
TN
I have my new clear top valve cover mounted up on the Trick Flow heads for the next round of dyno testing. I would really like to see a video of those clear valve covers on a running engine. Is this something that can stay on there all the time or just for testing or dyno work? Would they hold up on a street car? Thanks for the input Jerry
Old Geezer Racing
