Re: Push Rod Angles (b1-TS (2), Hemi 99, Goodwin Hemi) [Re: Dragula] #2017524
02/22/16 05:50 PM
02/22/16 05:50 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Originally Posted By Dragula
Originally Posted By Biginchmopar
And now the Predator Deal:
Which block is that on, wedge or Hemi layout?
KB Wedge
Mine is now KB Hemi
Re: Push Rod Angles (b1-TS (2), Hemi 99, Goodwin Hemi) [Re: Diablo] #2017588
02/22/16 07:00 PM
02/22/16 07:00 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I've never seen a lifter layout like that,
how is the cam configured?
Re: Push Rod Angles (b1-TS (2), Hemi 99, Goodwin Hemi) [Re: jlatessa] #2017649
02/22/16 09:07 PM
02/22/16 09:07 PM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
Nothing really special about it. Its IEEIEEI. Lifters are just angled different so they have better geometry up to the rocker. Looking at the cam it looks just like any other cam. Just a lot bigger wink
Re: Push Rod Angles (b1-TS (2), Hemi 99, Goodwin Hemi) [Re: Diablo] #2017859
02/23/16 02:21 AM
02/23/16 02:21 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
So each lifter centerline is still perpendicular to cam centerline?
Or do intake and exhaust lobes have different centerlines?
Thanks, Joe
Re: Push Rod Angles (b1-TS (2), Hemi 99, Goodwin Hemi) [Re: jlatessa] #2018391
02/23/16 10:35 PM
02/23/16 10:35 PM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
Thanks, Joe
Same centerline but these Cams are 60-70mm's. When you have something the size of your forearm you can play with the design a lot more.
Re: Push Rod Angles (b1-TS (2), Hemi 99, Goodwin Hemi) [Re: Diablo] #2018598
02/24/16 02:49 AM
02/24/16 02:49 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
That makes thing a little more clear to me,
thanks for your enlightenment.
And good luck...Joe
Re: Push Rod Angles (b1-TS (2), Hemi 99, Goodwin Hemi) [Re: Biginchmopar] #2019138
02/24/16 11:05 PM
02/24/16 11:05 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
B1-MC:
Those exh rockers look like b1 originals ?
....BAD A$$ STREET CAR.....
Re: Push Rod Angles (b1-TS (2), Hemi 99, Goodwin Hemi) [Re: Al_Alguire] #2091570
06/14/16 02:16 AM
06/14/16 02:16 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Originally Posted By Al_Alguire
Best I got on my Predator deal, 9/16" double taper pushrod, .937" Jesel keyway lifter.
Seems the Predator heads could use some relocated lifter bores
Alan Jones
Re: Push Rod Angles (b1-TS (2), Hemi 99, Goodwin Hemi) [Re: Diablo] #2091745
06/14/16 12:47 PM
06/14/16 12:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Problem is you can only go so far with the available cam cores right now..
Re: Push Rod Angles (b1-TS (2), Hemi 99, Goodwin Hemi) [Re: Al_Alguire] #2091846
06/14/16 03:56 PM
06/14/16 03:56 PM
Chicago land, IL
dafixr Offline
dafixr  Offline
Chicago land, IL
Al
Can I get some info on your set up, just got a hemi 99 for our car.
Thanks JIM
Re: Push Rod Angles (b1-TS (2), Hemi 99, Goodwin Hemi) [Re: LA360] #2095313
06/20/16 11:23 PM
06/20/16 11:23 PM
LA360 Offline
LA360  Offline
I guess if there were more guys running them, someone would do a run of cores
Alan Jones
Re: Push Rod Angles (b1-TS (2), Hemi 99, Goodwin Hemi) [Re: Diablo] #2095375
06/21/16 12:37 AM
06/21/16 12:37 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Don't look like there's much room to move... the cam bearings have to be where they are(in that block)
Re: Push Rod Angles (b1-TS (2), Hemi 99, Goodwin Hemi) [Re: LA360] #2095400
06/21/16 01:00 AM
06/21/16 01:00 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
You can do whatever you want if you step up to a tool steel billet core. But that's a $1500 cam, plus the machine work on block to move bores. To do that though, you really need to order the block blank and put the lifter bores where they need to be
