Re: Push Rod Angles (b1-TS (2), Hemi 99, Goodwin Hemi)
[Re: Dragula]
#2017524
02/22/16 05:50 PM
02/22/16 05:50 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
And now the Predator Deal: Which block is that on, wedge or Hemi layout? KB Wedge Mine is now KB Hemi
[Re: jlatessa]
#2018391
02/23/16 10:35 PM
02/23/16 10:35 PM
Posts: 1,107 Quebec, Canada
Diablo
Quebec, Canada
So each lifter centerline is still perpendicular to cam centerline? Or do intake and exhaust lobes have different centerlines? Thanks, Joe Same centerline but these Cams are 60-70mm's. When you have something the size of your forearm you can play with the design a lot more.
[Re: Al_Alguire]
#2091570
06/14/16 02:16 AM
06/14/16 02:16 AM
Posts: 6,150 Melbourne , Australia
LA360
Best I got on my Predator deal, 9/16" double taper pushrod, .937" Jesel keyway lifter. Seems the Predator heads could use some relocated lifter bores
Alan Jones
[Re: Diablo]
#2091745
06/14/16 12:47 PM
06/14/16 12:47 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Problem is you can only go so far with the available cam cores right now..
[Re: LA360]
#2095313
06/20/16 11:23 PM
06/20/16 11:23 PM
LA360
Best I got on my Predator deal, 9/16" double taper pushrod, .937" Jesel keyway lifter. Seems the Predator heads could use some relocated lifter bores I guess if there were more guys running them, someone would do a run of cores
Alan Jones
[Re: Diablo]
#2095375
06/21/16 12:37 AM
06/21/16 12:37 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Don't look like there's much room to move... the cam bearings have to be where they are(in that block)
[Re: LA360]
#2095400
06/21/16 01:00 AM
06/21/16 01:00 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Best I got on my Predator deal, 9/16" double taper pushrod, .937" Jesel keyway lifter. Seems the Predator heads could use some relocated lifter bores I guess if there were more guys running them, someone would do a run of cores You can do whatever you want if you step up to a tool steel billet core. But that's a $1500 cam, plus the machine work on block to move bores. To do that though, you really need to order the block blank and put the lifter bores where they need to be
