904 front drum differences 71-72 solved, new problems #2011914
02/14/16 07:14 PM
02/14/16 07:14 PM
Lakewood, Colorado
herkamer Offline OP
herkamer  Offline OP
Lakewood, Colorado
Apparently I got a 72-up rebuild kit for my 71 904. Now it's open and non-returnable. Looks like the lip seals for the rear drum/piston are correct and went in just fine. Inner lip seal was the failure point last time, and I'll confirm when I can air test. That brings me to the front drum/piston/seals. Obviously this was a change between 71 and 72. Question is can I interchange a 72-up 4 clutch drum with no problems? Or do I need anything else? I have access to a bunch of used parts and there should be 72-up drums there.
This unit had previously been rebuilt so I can't assure that all the parts are the ones that came in it from the factory. Casting dates would lead me to believe they are correct.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: 904 front drum differences 71-72 [Re: herkamer] #2011938
02/14/16 07:51 PM
02/14/16 07:51 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Yes, '72 saw a change to the narrow lip seals in the front drum and, yes, you can install a '72-later drum in your '71.
Re: 904 front drum differences 71-72 [Re: herkamer] #2012039
02/14/16 10:15 PM
02/14/16 10:15 PM
Lakewood, Colorado
herkamer Offline OP
herkamer  Offline OP
Lakewood, Colorado
Perfect, thank you!
Matt
69 Dart Swinger 340
and even more
Re: 904 front drum differences 71-72 [Re: herkamer] #2012219
02/15/16 02:38 AM
02/15/16 02:38 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
You can also buy the lip seals you need individually...
Tony
70 AARCuda Vitamin C
Re: 904 front drum differences 71-72 [Re: herkamer] #2015009
02/18/16 10:47 PM
02/18/16 10:47 PM
Lakewood, Colorado
herkamer Offline OP
herkamer  Offline OP
Lakewood, Colorado
Maybe I'm missing something. Got a drum assembly from my friends part stash. Took it apart and shows its a 79. Physically identical to the 71 parts with the 70 casting date. What's the possibility it is a newer setup? Pics attached for clarification. 71 unit is on the left in the pics
Matt
69 Dart Swinger 340
and even more
Re: 904 front drum differences 71-72 [Re: herkamer] #2015010
02/18/16 10:48 PM
02/18/16 10:48 PM
Lakewood, Colorado
herkamer Offline OP
herkamer  Offline OP
Lakewood, Colorado
Pic 2
Matt
69 Dart Swinger 340
and even more
Re: 904 front drum differences 71-72 [Re: herkamer] #2015013
02/18/16 10:50 PM
02/18/16 10:50 PM
Lakewood, Colorado
herkamer Offline OP
herkamer  Offline OP
Lakewood, Colorado
Pic 3 with both drums
Matt
69 Dart Swinger 340
and even more
Re: 904 front drum differences 71-72 [Re: herkamer] #2015165
02/19/16 01:35 AM
02/19/16 01:35 AM
GEORGIA
barracuda7199 Offline
GEORGIA
Is the groove for the lip seal the same? Can you compare the seals out of both drums and piston?
Re: 904 front drum differences 71-72 [Re: herkamer] #2015211
02/19/16 02:56 AM
02/19/16 02:56 AM
Lakewood, Colorado
herkamer Offline OP
herkamer  Offline OP
Lakewood, Colorado
Every dimension I mic'ed was the same. Lip groove is in the same place. The original seals looked the same.
Transmission build date is Jan 11, 1971. Not sure if this could have been a possible mid year change. And again I cannot 100% confirm those parts are original to the transmission, just that was in it when I took it apart. I don't want to burn this thing up again, it's getting too close to race season now.
Matt
69 Dart Swinger 340
and even more
Re: 904 front drum differences 71-72 [Re: herkamer] #2016393
02/21/16 12:40 AM
02/21/16 12:40 AM
Lakewood, Colorado
herkamer Offline OP
herkamer  Offline OP
Lakewood, Colorado
Guess it doesn't matter now, I upgraded to the later unit just in case.
So the next problem I am having is that I upgraded front pumps because the original reaction shaft bushing was loose. That ended up being part of the problem, it was the wrong year and had an extra hole. So I'm back to using the original if I can. New bushing fits in the reaction support ok, but it's not tight like I would expect it to be. What are my options besides finding a new pump?
Matt
69 Dart Swinger 340
and even more
Re: 904 front drum differences 71-72 [Re: herkamer] #2016631
02/21/16 04:01 PM
02/21/16 04:01 PM
Lakewood, Colorado
herkamer Offline OP
herkamer  Offline OP
Lakewood, Colorado
bump
Anyone? Loctite bearing sealant? Can I stake it in?
