Page 2 of 3 1 2 3
Re: tunnel ram users can i get your advise [Re: ProSport] #2013319
02/16/16 05:57 PM
02/16/16 05:57 PM
Guitar Jones Online laugh2
Yeah, that sure is true. My 8 gallon fuel cell used to last through 3 time runs and 3 rounds of racing. Now I'm filling it up after warm up and time runs. laugh2
"Come get your wife"
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion.
Re: tunnel ram users can i get your advise [Re: mopar dave] #2013324
02/16/16 05:57 PM
02/16/16 05:57 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Yea it got kind of annoying lol, but I loved that TR!
Re: tunnel ram users can i get your advise [Re: mopar dave] #2013326
02/16/16 06:00 PM
02/16/16 06:00 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I ran a tunnel ram on the street with a matched set of 750 dp's with no problems except spark plugs fouling probably due to low RPM's. On the track they worked great
Re: tunnel ram users can i get your advise [Re: mopar dave] #2013332
02/16/16 06:03 PM
02/16/16 06:03 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
OK that's nice to know 750's won't be too much carb. With the tunnel ram wont be ready in time for Dyno day, but I can put it on a chassis Dyno when its done.
Re: tunnel ram users can i get your advise [Re: mopar dave] #2013374
02/16/16 07:14 PM
02/16/16 07:14 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Bill Jenkins (if anyone but me remembers the fastest small block engines on the planet at the time?) remarked 40 years ago that the carburetors and plenum volume that produced the highest steady-state power on the dyno are at least 10% too big for best acceleration.
Boffin Emeritus
Re: tunnel ram users can i get your advise [Re: mopar dave] #2013382
02/16/16 07:19 PM
02/16/16 07:19 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I'm running two 660's that flow about 690 each. They have 50 cc pumps. They are on a 440 that is an old school build. Still haven't gotten all the bugs out yet. This is the best pair of carbs I have had on this engine yet.
Re: tunnel ram users can i get your advise [Re: 70HemiGTX] #2013406
02/16/16 07:59 PM
02/16/16 07:59 PM
Mt Morris Michigan
Mt Morris Michigan
Many racers out there that like their 660's. I asked Mark about them and he didn't have much to say. Besides the center squirter and straight boosters what makes them so different or better than a 650dp?
Re: tunnel ram users can i get your advise [Re: polyspheric] #2013412
02/16/16 08:03 PM
02/16/16 08:03 PM
Mt Morris Michigan
Mt Morris Michigan
Well, if the 750's are on the edge of being too small than they should work well on my combo.
Re: tunnel ram users can i get your advise [Re: mopar dave] #2013415
02/16/16 08:08 PM
02/16/16 08:08 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
You'll be happy with 750 double pumpers. I don't know how necessary it is, but my Quickfuel carbs were custom calibrated for a TR and had wedge shaped floats for a TR with sideways mounted carbs. They were pretty much spot-on right out of the box.
Re: tunnel ram users can i get your advise [Re: ProSport] #2013422
02/16/16 08:17 PM
02/16/16 08:17 PM
Mt Morris Michigan
Mt Morris Michigan
Cool! Do you know what qf put in them for IFR and main jets? Square jetted or PV out of the box?
Re: tunnel ram users can i get your advise [Re: ProSport] #2013478
02/16/16 09:27 PM
02/16/16 09:27 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have had very good luck with custom QF carbs over the years. ALthough, they are under new ownership now correct? I have not bought one since the change, but I would be curious to know. I still use a lot of they're parts over Holley stuff.
Re: tunnel ram users can i get your advise [Re: mopar dave] #2013487
02/16/16 09:37 PM
02/16/16 09:37 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I took the road less traveled and used a pair of 850 thermoquads. 18 dyno pulls later they were dialed in. They made about 40 hp more than a 1140 dominator on my 605. Torque numbers were better from the start of the pull all the way to the end. IF I drive it nice, I've been able to see 10mpg. I'll never go back to a single 4bbl. Dave
Re: tunnel ram users can i get your advise [Re: mopar dave] #2013506
02/16/16 09:56 PM
02/16/16 09:56 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I no longer own the car, I know I ran them square jetted with no power valves but I can't remember if they came that way. I'll try to see if new owner still has the build sheets for the carbs.
I'm sure he'll know what jets are in them.
Dragula, I did not know Quickfuel was under new ownership. I wonder if some of the guys stayed.?
Re: tunnel ram users can i get your advise [Re: ProSport] #2013542
02/16/16 10:37 PM
02/16/16 10:37 PM
Mt Morris Michigan
Mt Morris Michigan
Just curious to your specs. Mark said he would help me out with the tune on the ultras. Thanks
Re: tunnel ram users can i get your advise [Re: quickd100] #2013697
02/17/16 12:57 AM
02/17/16 12:57 AM
Mt Morris Michigan
Mt Morris Michigan
sounds read good. thanks for all the good info guys. now i'll get these ordered
Re: tunnel ram users can i get your advise [Re: mopar dave] #2013762
02/17/16 04:52 AM
02/17/16 04:52 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Just put a pair of 950 TRE carbs on my 528 street strip Cuda and Love it, still have some bugs but picked up about 40hp over dominator and went 608 rwhp.
Did have a little trouble starting it but I turned off the start retard so it's all in 34deg and now fires up great, I would also say it feels better on the street.
Go for it.
1963 Plymouth Max Wedge
1971 Barracuda
Re: tunnel ram users can i get your advise [Re: mopar dave] #2013862
02/17/16 11:42 AM
02/17/16 11:42 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I believe it is simply that they are well calibrated to a tunnel ram OOTB, and the 1:1 linkage works well for fuel distribution
Re: tunnel ram users can i get your advise [Re: mopar dave] #2013882
02/17/16 12:12 PM
02/17/16 12:12 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Once you say "no power valves, no vacuum advance", a question about mileage is pointless.
Boffin Emeritus
Re: tunnel ram users can i get your advise [Re: polyspheric] #2013928
02/17/16 01:30 PM
02/17/16 01:30 PM
Mt Morris Michigan
Mt Morris Michigan
who cares about mileage. i just want to go fast and look good doing it. i finally got the carbs ordered. what a pain that was. got them refurbished for $650ea thru jegs, but will be drop shipped from holley. i would have liked to try the 660's after reading all the good reviews on them, but Marks responce on those left me thinking he didnt think much of them. just my opinion.
Re: tunnel ram users can i get your advise [Re: polyspheric] #2013931
02/17/16 01:32 PM
02/17/16 01:32 PM
Mt Morris Michigan
Mt Morris Michigan
oh, these will have pv when street driven and square jetted while at the track.
Page 2 of 3 1 2 3
