Re: Super Bee dies
[Re: Texas383]
#2017379
02/22/16 02:26 PM
02/22/16 02:26 PM
Posts: 678 Marshall TX
Texas383
Marshall TX
...anyone have a clue as to why the car turns over but won't fire. BUT When I turn off the key it acts like it fires on a cylinder or maybe two but doesn't start, naturally, because I just turned the key off. Is that a ballast resistor issue? Ignition switch is NOS that I've had on the car only a few years.
I didn't do anything but install new chrome alternator. But put old alternator back on. Car ran like a top before.
I will try another ballast resistor this weekend and see if that helps.
I really need to get this car running/driving so I can move it to my new house/location! I can winch it on my trailer but prefer to get it working at 100%
Could the chrome ignition box have gone bad? Does it ground to car body? It's away from heat under the washer bottle.
1969 Y2 Super Bee 1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
Re: Super Bee dies
[Re: Texas383]
#2017395
02/22/16 02:45 PM
02/22/16 02:45 PM
Posts: 1,296 Tucson AZ,
MadMopars
Tucson AZ,
Have you checked the gap at the pick up in the distributor? Sometimes the linkage to the vacuum advance hangs up and I have to pop the cap and pull it back on my truck before it'll fire. Also, as mentioned either bypass the ballast resistor entirely or jump from the starter relay to ballast resistor for a solid power source. That should eliminate a good portion of potential problems. Lastly, are you sure the alternator is charging? When you get the car started again turn on the headlights and see if it expedites the dying process. Let us know how it goes. BTW, if you jump from the starter relay to the ballast resistor you will have to unplug the jumper to shut the car off. This test partially eliminates the ignition switch from the circuit and will no longer kill the ignition. Good Luck!
Re: Super Bee dies
[Re: therocks]
#2017893
02/23/16 04:14 AM
02/23/16 04:14 AM
Posts: 8,414 Highland, MI.
Sunroofcuda
Highland, MI.
Sunroof if I read it right you had a bad wire connetion not a bad ballast.As said typically when a ballast 99.99% of the time the car will start then die when key is let off.I did have a ballast go once that would not even start.It was one I never had in 50 years.Its always possible that a ballast can crack but have enough contact to run then quit but thats not typical.Rocky No, I don't think it was a bad wire connection, because it just plugs onto the ballast. When I put the other one on, I never had another problem with it. I don't know exactly where the spark was - but there was just a spark which was plainly visible in the dusk. I didn't do any wire repairs.
Re: Super Bee dies
[Re: Texas383]
#2018397
02/23/16 10:39 PM
02/23/16 10:39 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
I would check voltage at the back of igniton switch on the "run" terminal see if 12 volts ,u could have a voltage drop inside the ignition switch . should have 7 to 9 volts on the positive side of coil. 4.6 kinda low is this points car ? when switch gets hot more resistance less voltage and curant flow. Read up about voltage drop testing. Then check your ignition circuits that way. You will find it for sure with out guessing.
1969 Dodge Charger
1969 Dodge Superbee
Re: Super Bee dies
[Re: 52savoy]
#2018704
02/24/16 12:29 PM
02/24/16 12:29 PM
Texas383
Marshall TX
It's a non points distributor.
Yes I unplugged battery when installing alternator
Shouldn't there be 6 volts instead of 4.6 across the coil terminals with key on?
Re: Super Bee dies
[Re: Texas383]
#2018723
02/24/16 01:04 PM
02/24/16 01:04 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Sounds like a pickup to me also.Measuring across coil termonals is incorrect.You should have app 6 to 8 volts key on at coil Pos.Then get a test light ground and hold to coil neg that goes to dist.It should flash as car cranks.Measuring across coil connections dosent prove much except you have voltage at coil.You can also jump the ballast to see if car runs.Like said you should have voltage at ballast with key on .Rocky
Chrysler Firepower
Re: Super Bee dies
[Re: Texas383]
#2018794
02/24/16 03:27 PM
02/24/16 03:27 PM
MadMopars
Tucson AZ,
It's a non points distributor. Still has an air gap adjustment.
Re: Super Bee dies
[Re: Texas383]
#2021835
02/29/16 01:18 PM
02/29/16 01:18 PM
Texas383
Marshall TX
Great news!! Installed new ballast resistor and it fired up and stayed running!
Thanx to everyone!
Re: Super Bee dies
[Re: Texas383]
#2021836
02/29/16 01:21 PM
02/29/16 01:21 PM
RapidRobert
Great news!! Installed new ballast resistor and it fired up and stayed running! That wasn't that bad now was it!
Re: Super Bee dies
[Re: Texas383]
#2021907
02/29/16 03:37 PM
02/29/16 03:37 PM
Texas383
Marshall TX
...not bad at all. If you don't count withdrawal symptoms Now I have to wonder if installing the new chrome Powermaster alternator killed the ballast resistor or if it failed on it's own and it's ok to re install the Powermaster...? I sure don't want to install it and have the same issue again. I guess if I do I will know not to use the chrome alternator
Re: Super Bee dies
[Re: Texas383]
#2021951
02/29/16 04:55 PM
02/29/16 04:55 PM
therocks
Niles , Ohio
Chrome alt on my 65 and never hurt the ballast.I run MSD and just never deleted the ballast.Been on for at least 17 years.Did have a bad ballast and that was with the OE alt.Rocky
Chrysler Firepower
Re: Super Bee dies
[Re: Texas383]
#2139361
08/23/16 04:04 PM
08/23/16 04:04 PM
Texas383
Marshall TX
OK... for those interested I FINALLY resolved the dying issue. I put my old alternator back on and now it runs great all day without dying.
NOW... here is my big question. WHY?!?!?!?
What is wrong with my new alternator/car that would cause this. It's a 2 field chrome 17519 Powermaster 75 amp. I have one wired to field and the other grounded.
Re: Super Bee dies
[Re: Texas383]
#2139531
08/23/16 08:52 PM
08/23/16 08:52 PM
RapidRobert
I ain't thinking how the alt/reg could cause it to die. all that system could do is not charge or full field (full charge) or somewhere inbetween (even if intermittent from a loose connection) & it'd die if the batt finally ran down far enough or if it full fielded to the point where everything fried from too high of voltage (neither of which I think is happening here). I'm thinking Murphys Law, the ballast just happened to act up at the same time as the alt (if I am reading this right). 2 seperate issues I'd say. you replaced the ballast & it is running & if you want the Powermaster on there I would go ahead with it
Re: Super Bee dies
[Re: RapidRobert]
#2139841
08/24/16 12:16 PM
08/24/16 12:16 PM
Texas383
Marshall TX
Back in '95 the same car(I've owned it since 1980) died from an internal short in the alternator while driving down the road. I lost lights and ignition....everything.
