Rear axle four link bracket stiffeners #2007572
02/07/16 09:05 PM
02/07/16 09:05 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
I have noticed that sometimes on the four link brackets there is a cross tube welded from left to right. Is there a lot of flex going on and at what point is it necessary? I have never heard of the brackets flexing or bending, but I guess it's possible. My brackets are 1/4" thick from Smith Racecraft. They are four link brackets, but will be using ladder bars. Car is a big tire four speed setup. Should I be thinking about this mod? Car is going into the 8's.
[image][/image]
Re: Rear axle four link bracket stiffeners [Re: sgcuda] #2007583
02/07/16 09:44 PM
02/07/16 09:44 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've seen mounts rip off a housing. Probably due to lousy welds. But I've seen 3 cars it happened to, one this past year. They all went upside down. My ladder bars are boxed and the shock mounts are supported with a tube at 45 degrees to the mount.
Doug
Re: Rear axle four link bracket stiffeners [Re: sgcuda] #2007853
02/08/16 11:47 AM
02/08/16 11:47 AM
gregsdart Offline
gregsdart  Offline
If the car gets sideways and the brackets aren't at least boxed, they can lay over. Had it happen to me. Luckily I got the car back under control without any further damage.
Re: Rear axle four link bracket stiffeners [Re: sgcuda] #2007879
02/08/16 12:37 PM
02/08/16 12:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I put the bar on the stuff I build.. ladder
bar and 4 link.. just to help stiffen up the
longer section that hangs down... I've had to
weld up some brackets that were cracked for
a few people.. and I add that tube for them
EDIT
Also I add a gusset to the front lower section
that you can see on the right side.. to stiffen
that part where the lateral link can crack them
off
wave
Re: Rear axle four link bracket stiffeners [Re: sgcuda] #2007920
02/08/16 02:19 PM
02/08/16 02:19 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Here is what RJ Racecars did on ours. Kinda hard to see as there is a lot going on but it has a couple braces from side to side as well as boxed 4 link brackets
Re: Rear axle four link bracket stiffeners [Re: sgcuda] #2011586
02/14/16 03:09 AM
02/14/16 03:09 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Here is a picture of one I did for a friends altered. Reason for replacement was the lower bracket on the right side folded over and cracked when car got sideways and then caught traction. Previously had neither the cross member or brackets boxed. IHTH Beep
Re: Rear axle four link bracket stiffeners [Re: sgcuda] #2011690
02/14/16 01:27 PM
02/14/16 01:27 PM
sgcuda Offline OP
sgcuda  Offline OP
Wow! I've never seen pics of that before, but I guess it happens fairly often. I didn't think of welding the crosstube to the bottom of the housing. I guess that's a real good idea for added side to side strength.
[image][/image]
Re: Rear axle four link bracket stiffeners [Re: sgcuda] #2011718
02/14/16 02:26 PM
02/14/16 02:26 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Yeah, pretty common.
Re: Rear axle four link bracket stiffeners [Re: sgcuda] #2011797
02/14/16 03:55 PM
02/14/16 03:55 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Plate the brackets.....install the crossbar.......weld it to housing.......and also, do NOT just weld crossbar to inside bracket on both sides and call it good. Take the time to fit the bar through both plates on either side and weld it all up.
You are NOT going to keep your dana housing from bending, so do all you can to help it. Plus as mentioned, this keeps you from laying the brackets over and ending up on the rooof
Re: Rear axle four link bracket stiffeners [Re: Al_Alguire] #2012111
02/14/16 11:21 PM
02/14/16 11:21 PM
Ohio, United States
BuckeyeBrawler Offline
Ohio, United States
Alot going on! Wow that's understatement ! Really cool though! up
