Page 20 of 45 1 2 18 19 20 21 22 44 45
Re: Trick Flow heads [Re: DGS] #2004851
02/03/16 03:19 PM
02/03/16 03:19 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Originally Posted By DGS
Originally Posted By roadhazard
I certainly hope they did not use dimensions/ spacing from a gasket that may have been wrong.
Here's a good test to see if a pair of intake gaskets are symmetrical, as they should be in this application. Place them back side to back side and try to line up the ports. Also notice any variances in bolt hole locations.
Ours match up exact with only a very slight variance in hole location. I can't tell you how many heads I measured for bolt hole locations and all were different to some degree so I had to "settle" on a figure. Still, the bolts will go in with plenty of room to spare if the gasket needs to be shifted for any reason.
See my post https://board.moparts.org/ubbthreads/ubbt...tml#Post2004008
My ports are symmetrical. I wonder if there are really some Trick Flow heads out there which don't have symmetrical port pairs - or if Trick Flow changed the porting. Mine are of the early type with the hole not filled in (ordered mid-October).
I'm sorry but how do you know for a fact they are moved an equal amount and symmetrical, you're using a square. Yes, the ports are farther away from the inner bolt holes than the outer holes. It's been that way since the inception of the B/RB wedge. The guys here are speaking in terms of .050" or so.
Re: Trick Flow heads [Re: fast68plymouth] #2004858
02/03/16 03:27 PM
02/03/16 03:27 PM
AndyF Online content
AndyF  Online Content
The ports in my TF heads are not symmetrical with the bolt holes. The LH pair of ports is shifted over a little more than the RH pair of ports. Or perhaps the bolt is drilled in the wrong location. Hard to tell without having some sort of fixed datum to measure everything from.
None of the intake gaskets that I have on hand fit properly. I've tried several different mfgs. It isn't a huge problem, most folks probably won't even notice but I've been trying to get the port alignment "perfect" and so I keep futzing with it.
Re: Trick Flow heads [Re: fast68plymouth] #2004926
02/03/16 05:00 PM
02/03/16 05:00 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
It certainly appears that azzkikr's pairing of that head and that gasket have good gasket to port/bolt alignment for all 4 ports.
I'd be perfectly happy with that if I were putting it together.
The next question will be, how will the ports of the intake manifold line up when it's sitting on the long block?
Re: Trick Flow heads [Re: fast68plymouth] #2004944
02/03/16 05:22 PM
02/03/16 05:22 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I can say the fel pro metal bathtub gasket is pretty correct. The composite facing gaskets are wack. My gaskets fit the bathtub gasket well and if Trick Flow based their port and bolt locations off the fel pro composite gasket, they are wrong.
This is why I stated earlier, porting based on a gasket should be avoided.
fast68plymouth do you have a pair of those fel pro's to put back to back and see what I'm talking about?
Re: Trick Flow heads [Re: fast68plymouth] #2005533
02/04/16 04:42 PM
02/04/16 04:42 PM
So. Burlington, Vt.
So. Burlington, Vt.
Oh, I know the fel pro paper gaskets aren't right.
If I stack two of them, numbers facing "out", line the bolt holes up as good as possible, the port mismatch is worse on one end than the other, but is as bad as about .060".
I agree that "if" the TF port to bolt spacing is in fact based in that gasket, then it isn't correct.
It certainly looks like azzkikr's head lines up nicely with one of those gaskets, so it would appear that at least one head is a match for that screwed up gasket.
Re: Trick Flow heads [Re: fast68plymouth] #2005543
02/04/16 05:04 PM
02/04/16 05:04 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I would certainly hope that TF did more than just use a gasket to figure where the ports should go,and would use known factory dimentions for the heads, that being said it would also seem to me that Fel-Pro might want to look at their die's and see if there is a problem there, after all I would wonder how many 100's of 1000's of gaskets they have made and how many time's they have been rebuilt over the years.
Re: Trick Flow heads [Re: fast68plymouth] #2006083
02/05/16 02:46 PM
02/05/16 02:46 PM
So. Burlington, Vt.
So. Burlington, Vt.
I would agree that you'd like to think a head manufacturer would use something other than a gasket to determine a port layout for a new head.
That being said, I've seen many many parts brought to market with things done down right wrong, or existing designs "improved" upon that were just a big step backwards(newer style BB Victor head for example). I've shaken my head in wonder more times than I can remember about what someone was thinking when they designed/produced new performance parts.
Re: Trick Flow heads [Re: fast68plymouth] #2006181
02/05/16 05:29 PM
02/05/16 05:29 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
fast68plymouth, I'd say its just a gasket issue, I bolted that Victor intake on my heads today and it really lines up nice!
Re: Trick Flow heads [Re: DblOJoe] #2011109
02/13/16 03:11 PM
02/13/16 03:11 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
Wow! WOW!! Holy crap Batman - I'm back up and running and the power gain on this little A-Body with the Trick Flows is amazing. Well worth the investment!
up up A big THANKS to everyone again for all the info sharing on this thread - made it easy!
up up Thanks FireCore (Rick & crew) for building the custom wire set - they work great!
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: Trick Flow heads [Re: B Dartman] #2011113
02/13/16 03:16 PM
02/13/16 03:16 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Congrats, Bill!
...now stop scaring my neighbors! LOL!
Re: Trick Flow heads [Re: B Dartman] #2011149
02/13/16 04:16 PM
02/13/16 04:16 PM
Good deal! Nice looking engine but that Pep Boys throttle return spring has to go. Send me your address and I'll shoot you a proper Mopar throttle return spring setup.
Re: Trick Flow heads [Re: AndyF] #2011183
02/13/16 05:01 PM
02/13/16 05:01 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
beer Andy - PM Sent
Congrats, Bill!
GY3 - I'll stop by tomorrow when temps are up penguinwalk
Re: Trick Flow heads [Re: B Dartman] #2011190
02/13/16 05:12 PM
02/13/16 05:12 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
So we have 3 600+ HP cars within a 5 mile radius up and running now.
It should be a fun summer!
I blame Moparts for this sickness as the guys on here make it too easy to select the proper combination of parts.
I have lots of Andy's parts on my car, too!
Re: Trick Flow heads [Re: fast68plymouth] #2012234
02/15/16 02:57 AM
02/15/16 02:57 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Looks killer!! Thanks a ton for the opportunity. I remember making those up... Hoping they were going on a cool car... Wow, you blew me away with it.. Thank you. Rick Gorski
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Trick Flow heads [Re: sunroofgtx] #2012297
02/15/16 10:41 AM
02/15/16 10:41 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I got a ride late yesterday afternoon. I'd ridden in Bill's Dart a few times before and the difference from just swapping heads is crazy!
He definitely needs to get some stickier rear tires! drive
It is, without a doubt, one of the cleanest Darts I've seen.
Re: Trick Flow heads [Re: fast68plymouth] #2012390
02/15/16 01:27 PM
02/15/16 01:27 PM
So. Burlington, Vt.
So. Burlington, Vt.
Sorry if i missed it, but what did the TF heads replace on that Dart?
Re: Trick Flow heads [Re: fast68plymouth] #2012408
02/15/16 01:53 PM
02/15/16 01:53 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
IIRC they were bone stock 452 castings..
Re: Trick Flow heads [Re: fast68plymouth] #2012428
02/15/16 02:10 PM
02/15/16 02:10 PM
UK
rb446 Offline
rb446  Offline
UK
Not knowing what cam you got in the dart, even so I bet you got 100hp+ increase over stock 452's, I think TF's flow around 300cfm at .500" depending on the bench etc., My old Cuda 440 went from 11.3 with stock 906's to 10.7 with just bolted on 2.14/1.81 906's that prob didn't flow more than 260 if that!!...gotta be 1 of the best 440>470 head out out there up to around the 700hp mark with pump gas CR in current 240 style, wait till they get the 270 MW version out for 500 inchers+
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Trick Flow heads [Re: GY3] #2012858
02/16/16 12:34 AM
02/16/16 12:34 AM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
Yes - 452's. The Dart is what I'd consider a mild street build - its a toy wrench - I'm not out to rotate the earth with it.
- 8.75 posi w/3.91 gears
- 3K Converter - BM Transpack
- TTI Headers & Exhaust - X pipe
- Comp Hyd Roller (Cam-Lifters-Rockers)
In this particular case, the Trick Flow Heads were a really nice jump in power. In contrast I recognize the racers weighing in on this thread are trying to find literally every ounce of power they can get = some mixed opinions.
Anyway - I actually printed this thread and have it in the garage in a binder - all the advice/help has been much appreciated beer
Re: Trick Flow heads [Re: fast68plymouth] #2013129
02/16/16 02:26 PM
02/16/16 02:26 PM
So. Burlington, Vt.
So. Burlington, Vt.
I'm sure that's a huge improvement!!
