Re: Got a 66 D700, how to change out the Dayton wheels?
[Re: Rhinodart]
#2009134
02/10/16 11:23 AM
02/10/16 11:23 AM
Posts: 4,696 enfield, CT
ViperDave
enfield, CT
I love that ramp truck... always wanted one
67 Dart GT Vert 273/904 72 Town & Country 440/727 90 D350 reg cab dually cummins 15 Scat Pack Challenger
[Re: RTSrunner]
#2049369
04/08/16 12:14 AM
04/08/16 12:14 AM
Posts: 516 ND
dodgedon
ND
Dodgedon,what tires manufacturer) are the 10.00 x20 you are running? Mine are 8.25-20,the only tires I see are Chinese manufactured. ~RT We buy whatever is available. The rear drivers are bias and usually Recaps or good used. These tires don't seem to wear out on the rural gravel roads and fields. On the fronts we buy New Radials. These do wear more and are more of a safety issue. I will look at the brands but i think the most recent front set was a Kelly tire.... Its my understanding when talking to the neighbors that 7.50-20 and 8.25-20 tires are very hard to come by. They end up buying a new tire in whatever is offered and most often it's bias. I will look and see what brands we are using mostly and report back
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: RTSrunner]
#2050179
04/09/16 03:18 AM
04/09/16 03:18 AM
Posts: 516 ND
dodgedon
ND
The most recent new 10.00R-20 tires were kelly Armorsteel KGR. These are the typical ribbed front steer type tires. As for the rears both Dodges have Goodyear grip type tires. Recaps on the one and virgin on the other. The other trucks have the major brands you would expect to see... Dunlop, Bridgestone, Firestone, General, but these are 22.5 and 24.5 bud style tubeless wheels. I did see a truck today with what looked to be newer 8.25-20 tires on the front. They were Sumitomo ST727. The side wall did say "Made in Japan".
I think if diameter is a concern and you are currently running 8.25-20 or 9.00-20. You would have more options in a 22.5 tubeless wheel and a low profile Radial tire that would match what you have. But new wheels add to the cost... If your trucks are geared like ours, short tires will not help you get down the road any quicker.
