Re: Dana 60 to Dana 70 conversion possible? [Re: toplescuda] #2008825
02/09/16 09:50 PM
02/09/16 09:50 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The 70 is about 20% stronger and has a wider gear selection....
Originally Posted By toplescuda
I asked on here a couple years ago...I had a dana 70. And I had ask right here in this four months. If I could put dana 60 parts into a dana 70 housing. And 2as told no. So I pitched it
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Dana 60 to Dana 70 conversion possible? [Re: toplescuda] #2008882
02/09/16 11:01 PM
02/09/16 11:01 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
I have no idea which way you can go with parts. I do know that both use the same rear cover. I'm probably going back to a 60 housing. You are more than welcome to my 70 housing. It already has 4.10 gears in it. It's a floater style Ford truck rear, so you will have to cut it down and weld on housing ends.
[image][/image]
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2008927
02/09/16 11:50 PM
02/09/16 11:50 PM
montana
BANDIT Offline
BANDIT  Offline
montana
I still have a Dana 60 housing w/axles for sale.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2009027
02/10/16 01:43 AM
02/10/16 01:43 AM
sgcuda Offline OP
sgcuda  Offline OP
Bandit,
sent you a PM
[image][/image]
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2009238
02/10/16 02:49 PM
02/10/16 02:49 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Kenny...it'll bend again. You need a stronger housing that you can backbrace. Get a 9".
If you're dead set on keeping the Dana, just retube the one you have now.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dana 60 to Dana 70 conversion possible? [Re: an8sec70cuda] #2009286
02/10/16 03:39 PM
02/10/16 03:39 PM
I've seen Dana 60 with a one inch round tube front brace from the bearing ends on both sides to the pinion support work thumbs
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2009550
02/10/16 11:03 PM
02/10/16 11:03 PM
sgcuda Offline OP
sgcuda  Offline OP
Hey Chip,
That's not what happened. Basically, my mistake. Learned how to weld heavy steel using the Dana as my guinea pig. First ladder bar bracket setup broke loose. Luckily, still had the leaf springs in. Rewelded at least one more time, maybe twice. After all that heating, tubes finally took a setting slightly bowed. Haven't moved since, Axles still slide in and out dead square. Just don't think I should be hacking up these tubes anymore. I priced retubing through Currie. Almost as expensive as a new S60 housing. I bought this 52" Dana complete from Direct Connection drum to drum with 5.13 gears for $850. It's now cut down to 46 1/2".
[image][/image]
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2009639
02/11/16 01:26 AM
02/11/16 01:26 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
What power level and weight car will this be? What tire and expected ET range
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2009739
02/11/16 09:47 AM
02/11/16 09:47 AM
sgcuda Offline OP
sgcuda  Offline OP
750+ hp. 2700-2800 lbs. 14x32 stick car Hoping for high 8's.
[image][/image]
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2009808
02/11/16 01:06 PM
02/11/16 01:06 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I cut a bunnch of the stock truck brackets off from 2 Dana 60s. You can heat and shrink the tube to move it. Neither one of mine moved the tubes more than .060" at the end. The one in the 64 has 300 passes, 60ft in the mid to high 1.20's@3350 The other in the high 1.30's@3775 Neither have bent. Both are over 45" wide with no braces.
Doug
