R3 block 59* 9.2 deck height w/48* cam tunnel? #2006022
02/05/16 12:39 PM
02/05/16 12:39 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Can it be made usable and what will be required? Jim
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: rt66jim] #2006036
02/05/16 01:06 PM
02/05/16 01:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How can you have a 59* block and a 48* tunnel..
its one or the other... its the angle of the lifter
wave
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: MR_P_BODY] #2006038
02/05/16 01:10 PM
02/05/16 01:10 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Mike it is one of those early R3 blocks with the wrong cam tunnel.
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: rt66jim] #2006041
02/05/16 01:12 PM
02/05/16 01:12 PM
P
Porter67 Offline
Porter67  Offline
P
Not sure but here is a new R3 block about 200 mile from me for $800, im not sure what gives here.
Mopar # 4532907 340 R-Block
http://denver.craigslist.org/pts/5418293475.html
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: rt66jim] #2006056
02/05/16 01:44 PM
02/05/16 01:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would press in sleeves into the cam tunnel so
you can use a 59* cam... yeah its a fair amount
of work but if the block is cheap enough it would
be well worth the work... I would assume that $800
block is the same way based on the price... or talk
to the cam grinders and see if they can cut a 48*
cam to 59* specs and then use the needle bearings
EDIT
Or check on getting a few cams made for this type
of block... there are a few out there
wave
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: Porter67] #2006074
02/05/16 02:28 PM
02/05/16 02:28 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
That block will probably be FUBAR too as it is 1 serial # before this block I was asking about.
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: rt66jim] #2006153
02/05/16 04:30 PM
02/05/16 04:30 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
What exactly is wrong about the cam tunnel?
FYI guys that block is sold
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: rt66jim] #2006169
02/05/16 05:14 PM
02/05/16 05:14 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My R3 is #003. The only issues were the main bulkheads weren't trimmed enough to clear stock counter weights, 30 minutes with the carbide. And the upper 2 timing cover bolt holes were drilled in the low deck location, drilled and tapped 2 holes.
Doug
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: dvw] #2006176
02/05/16 05:23 PM
02/05/16 05:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug
My R3 didnt have any number(that I recall)... it
had the same issue in the bulkhead area
wave
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: rt66jim] #2006200
02/05/16 06:29 PM
02/05/16 06:29 PM
Sioux Falls, SD
MGC340 Offline
MGC340  Offline
Sioux Falls, SD
I just bought the block that was on Craigslist. He said he didn't know if it was a 48 or 59 degree cam tunnel. I told him it should be easy to tell if the #5 cam bearing bore and the #1 are the same its a 48. I've been on the phone with Comp and LSM to see if they have cams available but I've been stuck on hold. I guess it will be a surprise to see what I get when it shows up lol. Does anyone have anymore info on these blocks? For the money hopefully I can make something work.
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: rt66jim] #2006234
02/05/16 07:24 PM
02/05/16 07:24 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Just buy custom can for it, 48° tunnel 59° lifter angle.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: rt66jim] #2006263
02/05/16 08:02 PM
02/05/16 08:02 PM
Sioux Falls, SD
MGC340 Offline
MGC340  Offline
Sioux Falls, SD
I called Bullet they said they have never heard of this before but could grind a cam for $750. Not bad considering.
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: MGC340] #2006274
02/05/16 08:21 PM
02/05/16 08:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know if Bullet buys their blanks or if they
make them.. but if they get rough cores they can
grind anything with them... a 48* cam ground on 59*
with roller bearings would be great... or even better
would be a 48* block... mine was a dry sump block with
a solid valley area and no filter set up
wave
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: MR_P_BODY] #2006303
02/05/16 08:56 PM
02/05/16 08:56 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
What are the bearing bores? No such thing as 48 or 59 bearing size. I have had several different bearing arrangements with 48 degree. There have been a few for 59.
What is the lifter bore spacing? 1.625 is common for 48. And 1.875 is stock 59.
The hurdle in making a camshaft with oil pump gear. Loose the gear and go external oil pump and front distributor solves problem. Order a spool and get your cam ground.
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: Leon441] #2006312
02/05/16 09:16 PM
02/05/16 09:16 PM
Sioux Falls, SD
MGC340 Offline
MGC340  Offline
Sioux Falls, SD
Leon,
I'll measure the block when it arrives. He didn't know. What does a guy have to do about a intake? I have w5's and a Indy intake. Can a guy mill enough off a standard deck Intake to make it work or what should a guy do?
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: MGC340] #2006326
02/05/16 09:48 PM
02/05/16 09:48 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Do a mockup with the parts u have, then u will know what direction to go.
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: rickraw] #2006750
02/06/16 02:43 PM
02/06/16 02:43 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Well we figured it out thanks to all of your input here. #1 and #5 cam bores are the same size. The lifter bores are 59* as checked with a pair of 59* roller lifters. Thanks for everyone's help and input. Jim
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: rt66jim] #2006842
02/06/16 05:35 PM
02/06/16 05:35 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
So you need a 2 in Babbitt bearing cam for that block. Or is it set up for a 50mm roller?
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: 1967dartgt] #2006905
02/06/16 07:27 PM
02/06/16 07:27 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Well I don't know we only checked the #1 & #5 CB bores. Will they all be the same if it's the 50MM roller? Jim
Re: R3 block 59* 9.2 deck height w/48* cam tunnel? [Re: rt66jim] #2006946
02/06/16 08:16 PM
02/06/16 08:16 PM
Ambridge, Pa.
Ambridge, Pa.
Yes. Had mine done yrs ago. I don't remember the size.
