Re: 68 Pickup six to 440 swap
[Re: 70mopes]
#2009384
02/10/16 05:51 PM
02/10/16 05:51 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
If you build it like the factory did a 383/auto you won't need a cross member or a rear sump pan. If you have no pan then a rear sump is probably easier to find. The driveshaft from a 383/auto truck would be the correct length, and since the crossmember is in the same spot for all trucks, perhaps the slant 6/auto driveshaft is the same length as well. I don't know that the radiator has the inlet/outlet in the correct spots, but if so, you may be able to get by with it. I do know some with big blocks said their trucks ran hot. They don't make radiators for these trucks but apparently a Charger radiator is a close fit. Again you will have to check where the inlet/outlet is. http://www.championradiators.com/Dodge-D100-D200-1961-1971-radiatorThe suspension should be fine if it is in good condition.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: Soopernaut]
#2009569
02/10/16 11:25 PM
02/10/16 11:25 PM
RapidRobert
Mine looks close to the "rear sump pickup" in the last pic. I will measure the length of the "bends" tomorrow to help confirm. How I ended up with a FS pan and a RS pickup I have no idea. On the crossmember as said (& I mistakenly alluded to wrongly) you do not need a crossmember unless you have a hyd clutch setup and are going to a 727 & probably also a non hydro stick (I was thinking of my setup/conversion plans). On the hyd clutch setups (like my /6 & future 451 will have) the rear mount(s)s bolt to either side of the bellhousing & no crossmember tho one will bolt in.
[Re: RapidRobert]
#2010065
02/11/16 08:06 PM
02/11/16 08:06 PM
RapidRobert
Mine looks like the one in the pic. 1st leg from the threaded end tip is ~4&1/4" next leg is ~4" next leg is ~2" last horizontle leg into round screen is ~1.5". Does this descrip to be a truck front sump pickup?
[Re: vdriver]
#2010113
02/11/16 09:08 PM
02/11/16 09:08 PM
RapidRobert
A pic would be easier but my camera is down. EDIT My second leg is ~4" and yours is ~6". I'd about think it'd have to be the same one but let me go measure again tomorrow as that is a significant difference.
[Re: RapidRobert]
#2010851
02/13/16 12:01 AM
02/13/16 12:01 AM
RapidRobert
from the threaded end first leg is 4&1/8. second leg is 4&1/8. third leg is 2&1/4. last short horizontle leg is 1&1/8. with the screen held horizontle like it is in operation the height to horizontle height of angled threaded end tip is 8" and end to end with the tape in a straight line as the crow flies is 13 & 9/16.
[Re: 70mopes]
#2094160
06/18/16 10:34 PM
06/18/16 10:34 PM
RapidRobert
Is a 402 pan considered a "front sump" Thanks its considered a "center" sump; pan (tho the sump ain't exactly centered). front/rear sumpers are all forward or all rearward. for a quick visual drain plugs are traditionally at the rear but not even sure if that holds with these. I will go check mine again & the 451 block is belly up so I will drop it on there. I know it was the opposite of what the guy sold me (I dont even think he knew he was wrong) however I feel lucky!.
[Re: vdriver]
#2094396
06/19/16 01:10 PM
06/19/16 01:10 PM
RapidRobert
Ding ding ding I (do) believe we have a winna, thanks Vdriver! I'll go see what I have. EDIT I have the front sumper on the far left. I still ain't sure which one I need for my 65 D100 big block granny 4 sp project but iirc a credible source said "front sump"
