Can you convert an older 727 to a lock up convertor?
#2007131
02/07/16 01:18 AM
02/07/16 01:18 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
The gear thread got me thinking about something I talked about a number of years ago and I think the conversation was that it could be done but I cant remember the particulars. I'm hoping a tranny guy can fill in the blanks and share the reality with me. I know the small block is easy just use a later model lock up trans but what about a BB can you convert it? I think this would help tremendously since no BB OD unit was factory available. Do they make a lock up convertor that will handle significant torque and power?
Thanks in advance, Kevin
Careful, your character's showing!
Re: Can you convert an older 727 to a lock up convertor?
[Re: mopar346]
#2007140
02/07/16 01:25 AM
02/07/16 01:25 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
no, you cannot convert a non lockup 727 to lock up.
But they did make some lock up BB 727's in the late 70's.
[Re: mopar346]
#2007147
02/07/16 01:32 AM
02/07/16 01:32 AM
mopar346
Interesting do you know the application and the strength of the convertors? My guess is there would be an issue unless you were running something pretty serious. It could inprove the highway situation buy 2-300 RPM I would think.
[Re: mopar346]
#2007165
02/07/16 01:55 AM
02/07/16 01:55 AM
mopar346
Yea but 300 rpm would drop your effective gear (if that's the right term to use here) .50, essentially taking a 3.91 to a 3.42 and a 3.55 to a 3.08.
[Re: mopar346]
#2007175
02/07/16 02:14 AM
02/07/16 02:14 AM
mopar346
I think I found it, doesn't say lock up in the ad if it the one I was looking at. What is the application?
[Re: mopar346]
#2007480
02/07/16 06:05 PM
02/07/16 06:05 PM
Posts: 26,039 Rio Linda, CA
John_Kunkel
Rio Linda, CA
There was only one lockup big block 727 and it was such a dismal failure the factory recommended that it be replaced with a non-lockup. Part number of that trans is 4028824, it was used behind the '78 400-2 in B and C-body wagons.
You can't convert a non-lockup to lockup because the lockup case casting was changed to clear the lockup valve assembly on the valve body.
[Re: A727Tflite]
#2007655
02/07/16 11:48 PM
02/07/16 11:48 PM
Supercuda
About to go away
About to go away
up yours
You can turn a non-lockup trans in to a lock up - need the valve body, input shaft and corresponding rear clutch retainer, pump support (reaction shaft support). Ah, no. Case is different for lockup vs non-lockup as well.
[Re: mopar346]
#2007703
02/08/16 01:00 AM
02/08/16 01:00 AM
Posts: 3,114 Michigan
A727Tflite
Wrong - you can convert a non-lockup to lockup all day long. Case was never an issue. Nothing in the case is different. There was a slight "machining" clearance cut - but the casting is no different from previous years. And i believe this slight machining change was needed only for the early valve bodies that used the lockup module - the later electric lockups with the electric solenoid don't need that cut. As for dismal failures of the 78 lockup in big block applications - i am not aware of any mechanical failures - they were customer unacceptable because of the drone noise due to low vehicle speed lockup at low engine speed - causing a drone noise.
[Re: mopar346]
#2007809
02/08/16 05:58 AM
02/08/16 05:58 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
AMC 727s were also available with a lockup in the mid 80's, I have one in my cj
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: A727Tflite]
#2008103
02/08/16 07:12 PM
02/08/16 07:12 PM
John_Kunkel
Rio Linda, CA
Wrong - you can convert a non-lockup to lockup all day long. Case was never an issue. Nothing in the case is different. To quote the factory literature on the lockup changes, "the case was revised to provide clearance with lockup valve body." So the case was (is) an issue. The pic below shows the point of major interference between the lockup VB and the non-lockup case. Your initial reply to the OP stated "You can turn a non-lockup trans in to a lock up - need the valve body, input shaft and corresponding rear clutch retainer, pump support (reaction shaft support)." which implies that the case is OK as is. Whether the revision is in the casting or "machining" it's obvious from the pic and the factory literature that it is an issue.
[Re: mopar346]
#2008150
02/08/16 08:23 PM
02/08/16 08:23 PM
A727Tflite
Yep - if you want to split hairs. But read my post again and the one later on - no one would likely use that old valve body with the module - when it is antiquated - when you can use the electronic version - which does not need the machining/relieving.
And you said "cannot convert" which is more incorrect - and leads people on this website to believe it cannot be done - I bet everyone on this website has a die grinder. That is all it takes John. And Supercuda is misleading in his statements as well. But that is ok - we have it cleared up for most everyone reading this so that is the desired end - good info.
[Re: A727Tflite]
#2008156
02/08/16 08:31 PM
02/08/16 08:31 PM
John_Kunkel
Rio Linda, CA
I bet everyone on this website has a die grinder. That is all it takes John. And Supercuda is misleading in his statements as well. Sure, you can put a Hemi in an Isetta with "a little grinding".
[Re: mopar346]
#2008183
02/08/16 09:40 PM
02/08/16 09:40 PM
Supercuda
About to go away
About to go away
up yours
What's misleading is your original response said nothing about case mods. You came back and mentioned it later. You can turn a non-lockup trans in to a lock up - need the valve body, input shaft and corresponding rear clutch retainer, pump support (reaction shaft support). There are two basic valve bodies - hydraulic control only for lockup then electronic control lockup. Early lockup control with electronics was called PTU (part throttle unlock), was one wire to actuate the lockup solenoid. You just need to be careful that you identify and get all the correct parts to do the swap.
