Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2009134
02/10/16 11:23 AM
02/10/16 11:23 AM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
I love that ramp truck... always wanted one
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2010332
02/12/16 02:23 AM
02/12/16 02:23 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
you need a budd hub to fit your spindle. I would just swap out the front axle myself. I have done it lots on gravel and logging truck to get the big front end.
I would swap the rear out too while I was at it. then you have a truck you can actually drive
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: chrisf] #2010341
02/12/16 03:00 AM
02/12/16 03:00 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
What are you swapping into these things? Eaton? Timkin?
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2048619
04/07/16 06:25 AM
04/07/16 06:25 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I have a '69 Dodge L-600 with Dayton rear wheels and 6-lug Budd's on the front.Both are 20" split rims,I'd like to replace them with tubeless or at least one piece rims also,the Accuride link looks promising!Dodgedon,what tires manufacturer) are the 10.00 x20 you are running? Mine are 8.25-20,the only tires I see are Chinese manufactured. ~RT
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: RTSrunner] #2049369
04/08/16 12:14 AM
04/08/16 12:14 AM
ND
dodgedon Offline
dodgedon  Offline
ND
We buy whatever is available. The rear drivers are bias and usually Recaps or good used. These tires don't seem to wear out on the rural gravel roads and fields. On the fronts we buy New Radials. These do wear more and are more of a safety issue. I will look at the brands but i think the most recent front set was a Kelly tire.... Its my understanding when talking to the neighbors that 7.50-20 and 8.25-20 tires are very hard to come by. They end up buying a new tire in whatever is offered and most often it's bias. I will look and see what brands we are using mostly and report back
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2049433
04/08/16 02:09 AM
04/08/16 02:09 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Cool,thanks!
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: RTSrunner] #2049708
04/08/16 02:30 PM
04/08/16 02:30 PM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
That would be good to know too! up I will probably buy a set of the tubeless Dayton wheels that are made locally. boogie
JB Rhinehart, Realist
A-Body's RULE!
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2050074
04/08/16 11:32 PM
04/08/16 11:32 PM
IN
ahy Offline
ahy  Offline
IN
FWIW Specialty Tires America makes the 8.25 x 20 and 10 x 20 sizes. I would guess the 10 x 20 is also still available from other manufacturers. I run a set of STA tires on a '47 Power Wagon and they have been fine... not a lot of miles though.
http://www.stausaonline.com/tires/sta-super-transport-2/
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: RTSrunner] #2050179
04/09/16 03:18 AM
04/09/16 03:18 AM
ND
dodgedon Offline
dodgedon  Offline
ND
The most recent new 10.00R-20 tires were kelly Armorsteel KGR. These are the typical ribbed front steer type tires. As for the rears both Dodges have Goodyear grip type tires. Recaps on the one and virgin on the other. The other trucks have the major brands you would expect to see... Dunlop, Bridgestone, Firestone, General, but these are 22.5 and 24.5 bud style tubeless wheels. I did see a truck today with what looked to be newer 8.25-20 tires on the front. They were Sumitomo ST727. The side wall did say "Made in Japan".
I think if diameter is a concern and you are currently running 8.25-20 or 9.00-20. You would have more options in a 22.5 tubeless wheel and a low profile Radial tire that would match what you have. But new wheels add to the cost... If your trucks are geared like ours, short tires will not help you get down the road any quicker.
67 Charger 383 auto
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2050349
04/09/16 12:42 PM
04/09/16 12:42 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Thanks for the info guys great to find options for these old sizes.~RT
