Re: r block cam [Re: LA360] #2012991
02/16/16 06:36 AM
02/16/16 06:36 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
yes mate i have one 500 lobe 275/289 @ 050 on a 116 with 1.85 rockers 925 lift lol
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: r block cam [Re: LA360] #2013011
02/16/16 09:56 AM
02/16/16 09:56 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
Originally Posted By LA360
If you're going to go to 60mm, go with the roller bearings. Do you still have those 60mm cams your got off Craig?
Not the best idea.
You can run plain bearing and save lots of block integrity
No real performance advantage to roller bearings and some top guys even think plain bearings deal dampens harmonics.
Re: r block cam [Re: W5DART66] #2018885
02/24/16 05:33 PM
02/24/16 05:33 PM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
If your taking about the first-generation R block ??? What you do is use a 50mm roller cam
You Machine out the block The first 4 mains from Front to back to the bearing size I can get that # if you need it and that last main can only go to 40mm so you have to turn down the cam on the last Journal
There's not enough mean on the block For a 50mm bearing
Pictures below are of a 48° First-generation R block
