Re: So, I'm thinking about buying a new Dodge diesel truck
[Re: camastomcat]
#2002083
01/30/16 06:14 PM
01/30/16 06:14 PM
DaytonaTurbo
Manitoba, Canada
I'm really tired of 10MPH towing. Yeah that must suck. Would take forever to get anywhere! Seriously though, keep your truck. The new ones don't do any better when towing. And even if they did, the extra money you would have to kick in to buy it would fix your transmission and buy you years worth of extra fuel to make up the difference.
[Re: camastomcat]
#2002357
01/31/16 12:04 AM
01/31/16 12:04 AM
Posts: 1,413 northeast ohio
hulmule
northeast ohio
looking at your address the truck isn't rusted away. I would build a good tranny and Tc and then some good mods. the new trucks from whom I talk to they don't get good mileage.good luck
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: 3csalvage]
#2002509
01/31/16 04:38 AM
01/31/16 04:38 AM
Posts: 43,650 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I had an early 04 with the 305 555 instead of the 325 600 you have and got MUCH better mileage towing! All I had on mine was a Bully Dog Triple Dog but the truck had 4.10 gears. Got 18-20 around town and 12-14 towing my 32' LQ trailer that weighed 11,200 lbs. You are probably towing more like 16K lbs? With my 2005 dually towing a 44' fiver I would get around the same mileage you do. The people I know that have new diesels get worse mileage than the 05 did, but comfort, power. and stopping and worlds apart!
JB Rhinehart, Realist
A-Body's RULE!
[Re: camastomcat]
#2002603
01/31/16 12:59 PM
01/31/16 12:59 PM
Posts: 8,191 Plymouth, MI
Blusmbl
Plymouth, MI
Gearing might help you a little but it takes a lot of HP to pull an enclosed trailer @ 80mph, especially through hills. The benefit of the newer trucks is you don't need to tune them to get the same power as your current ride, but I wouldn't expect a mpg improvement.
If you want better fuel economy the easiest and cheapest solution is to slow down.
[Re: 3csalvage]
#2002651
01/31/16 02:04 PM
01/31/16 02:04 PM
Rhinodart
Rhinotruck
Rhinotruck
With my 04 I did a test on a long trip running one tank at 55, one at 65, and one at 75 and the mileage difference was telling! At 75 I got 18.3 MPG, 65 20.0 even, and 55 22.5!
A-Body's RULE!
[Re: camastomcat]
#2004898
02/03/16 04:19 PM
02/03/16 04:19 PM
Posts: 20,697 in a cattle trailer down by th...
Guitar Jones
It seems counter intuitive to buy a new truck to get a few more MPG if any. I mean unless you just want a new truck because you aren't going to save any money. For what it's worth I'm not getting rid of my 12 valve for a new pig.
