Re: Low deck stroker intake?
[Re: Streetwize]
#2005894
02/05/16 01:53 AM
02/05/16 01:53 AM
Posts: 4,715 Wichita
GY3
Wichita
Hollis Page is a Moparts sponsor here, he's in central North Carolina and Larry works at his shop. Both of them are about the nicest people you'll ever meet and are AWESOME engine builders....and they LOVE MoPars!
Larry can give you a quote, I know it varies by the intake. I know when I used to do Street Dommy's it would take me about 3 hours of solid porting and roof radius work, and maybe another hour of finishing (Purdy up) work. I think I heard someone say Larry is doing a Torker for him. Thanks! I sent them a message through their website.
[Re: MarkZ]
#2005950
02/05/16 05:30 AM
02/05/16 05:30 AM
Posts: 43,375 Bend,OR USA
Cab_Burge
years ago I did a extensive dyno test on three different intakes ona 496 C.I. 426 W pump gas motor, a Torquer 2, a M1 single plane and a Edlebrock Performer RPM.The RPM was better below 4500 RPM and the M1 was better above 4500 RPM with teh averages being real close to the same from 2500 RPM to 6500 RPM. The Torquer 2 was not close to either one We jetted for best HP on all three intakes with the same carb. I ended up putting the RPM on the motor for street use, the owner loved it
[Re: ahy]
#2008786
02/09/16 08:36 PM
02/09/16 08:36 PM
GY3
Wichita
It is a pretty simple build. Low deck with 4.15" stroke and 4.375" bore. Steel main caps and studs. D dish pistons with 10.2 CR and zero deck for good quench with a ~.040" gasket. Ed heads thoroughly pocket ported. We were going to CNC them with the freshen but the guys flowed them and little to gain. The cam is a MM lobe mechanical flat tappet 243@.050 and .55" lift with 108 CL.
The engine has behaved well for >15k miles including two full road track days... where I out drove the "hemi" oil pan and also got the oil pretty hot. That was the main reason for the freshen... the EFI tuneup was a nice "extra". Very similar to my build!
[Re: ahy]
#2008811
02/09/16 09:28 PM
02/09/16 09:28 PM
Posts: 31,117 Oregon
AndyF
The engine has behaved well for >15k miles including two full road track days... where I out drove the "hemi" oil pan and also got the oil pretty hot. That was the main reason for the freshen... the EFI tuneup was a nice "extra". The 243@050 cam duration is a big part of the equation. Interesting contrast with the thread the other day where someone was looking to put a 270@050 duration cam in a very similar engine.
[Re: MarkZ]
#2008916
02/09/16 11:37 PM
02/09/16 11:37 PM
Posts: 5,160 Texas
dannysbee
Texas
See you fixed the oil pan issue. Have you thought about an oil cooler? What have you got that monster in and what transmission and gear?
Getting old just means you were smarter than some and luckier than others.
[Re: AndyF]
#2008964
02/10/16 12:30 AM
02/10/16 12:30 AM
Posts: 7,664 IN
ahy
IN
I'm just impressed that you resisted the urge to over cam the engine! I tell people all the time that the Mopar .528 works just great in a street driven stroker but a lot of people think I'm nuts. From what I can see, the timing events on the 528 cam are pretty similar to the one I am running with a bit less aggressive (safer) lobes. Very good for a street (or endurance) engine. With the limitation in port flow on a standard port head it seems like a bigger duration cam would narrow the torque and power band w/o much corresponding benefit in peak power. With a manual transmission (or even AT, esp with tight converter) the wide power band is great... just keep her between 4500 and 6000 RPM and all is good... or cruise to your heart's content at much lower revs... which I have done. On a dedicated drag car with high stall converter, may be a different story.
[Re: MarkZ]
#2008990
02/10/16 01:02 AM
02/10/16 01:02 AM
Posts: 5,160 Texas
dannysbee
Texas
Neat car. Flat hood and all. I bet it will embarrass some folks. Lol
[Re: MarkZ]
#2010259
02/12/16 12:44 AM
02/12/16 12:44 AM
Posts: 16,169 Mesa, Arizona
dart4forte
Mesa, Arizona
I've had several low deck strokers. The first two were 452s. I ran a Street Dominator with an 850 TQ on the 1st motor. The carb had several mods. Probably the most responsive combo I've ever ran. Gobs of torque.
The second stroker I ran a six pack manifold with BG Six Shooter carbs. This combo ran great however I think the motor needed some more carb. The total CFM on theSix Shooter carbs was 750 CFM, well below the standard Holley setup.
Abe Lincoln
[Re: MarkZ]
#2010532
02/12/16 04:24 PM
02/12/16 04:24 PM
Posts: 1,238 Nevada
dezduster
Nevada
I am not nearly as knowledgeable as any of these enginebuilders but I did just install an FiTech fuel injection system on my 408 with 228 234 cam and eddie airgap intake. The idle vacum was and is around ten inches. With the 750 DP it idled as if the cam was much larger drove as if the cam were much larger but raced at WO throttle corectly. Admittedly I did not tune the carb as though it was staying on. However an engine must pull fuel from a carb whereas injection is not pulled from the carb only to the cylinder. Single planes seems to be the more logical and popular choice among OE injected engines and injection manufacturers when asked. Having said all that I think the carburetor ran harder at wide open, but is that due to the softer feeling bottom end of the carburetor? OR am I running into the same situation that David Frieburger, Dulchic and Bruell did while comparing efi to carburator? I don't know, what I do know! If it is infact loosing power at WO, EFI makes up for it everywhere else. So yes I would like single plane. Input but no solid answer.
