Re: Engine Torque Strap
[Re: DusterKid]
#2003300
02/01/16 11:22 AM
02/01/16 11:22 AM
Posts: 7,548 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
How about a couple nice steel brackets (engine and body) with a threaded rod and end-links (like tie-rods) - or is that too rigid? I swear I've seen kits in Hot Rod catalogs for that kind of thing. Cheers, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: DusterKid]
#2003467
02/01/16 02:55 PM
02/01/16 02:55 PM
Posts: 3,460 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
I just use a short piece of zinc-plated chain. Anything you use (torque strap, or cable, or chain) is going to be visible and noticable. Unless you go with a solid mount on that side...
The young kids at the cars shows sometimes ask me what the chain is for.
When I tell them I have to chain the engine down so it doesn't jump out of the car, their eyes get real big.....
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: DusterKid]
#2003532
02/01/16 03:54 PM
02/01/16 03:54 PM
Posts: 5,202 CT
GTX MATT
CT
The Shumacher strap Andy has above is nice, they are $$$ new though. I think mine was $110 for a B body. I'd buy that one from Andy, will look good and save a few bucks I'm sure.
[Re: AndyF]
#2003548
02/01/16 04:12 PM
02/01/16 04:12 PM
Posts: 3,949 Richmond, Indiana
19swinger70
Richmond, Indiana
I have a new torque strap that I'm not going to need. Shoot me a PM if you're interested.
I've had one of these on my Dart for 15 years now. Nice piece and looks great.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: wingman]
#2003553
02/01/16 04:18 PM
02/01/16 04:18 PM
Posts: 27,383 Rio Linda, CA
John_Kunkel
The Erection Connection
Rio Linda, CA
I just use a short piece of zinc-plated chain. Anything you use (torque strap, or cable, or chain) is going to be visible and noticable. Chain always does it for me. If you don't like the looks, cover it with shrink wrap.
[Re: DusterKid]
#2003571
02/01/16 04:45 PM
02/01/16 04:45 PM
Posts: 2,592 None
71rm23
None
I'm working on a 69 barracuda with a 360 and want to install a torque strap of some sort before a motor mount breaks since it has the older style mounts. I typically would just use a chain, but I'd to show this car. I thought of using a cable with 2 ends on it, has anyone done this? Did you make your own or buy one? Any pics? Thanks. They have them. Thinking of putting one on my car. http://www.engine-swaps.com/Pages/ProductsYear/67.72aBody.html#head3
[Re: DusterKid]
#2003605
02/01/16 05:33 PM
02/01/16 05:33 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
I thought of using a cable with 2 ends on it, has anyone done this? Did you make your own or buy one? Any pics? Thanks. I took a measurement... Then took a short winch cable, cut it to size, and re-crimped the ends... (Similar as shown here, but a much heavier, 'terminal end' that requires hydraulic crimping...) Bolted from block to K-frame... Much 'cleaner' than a chain... Still allows movement, but will contain the engine in the event of a motor-mount failure...
[Re: John_Kunkel]
#2004185
02/02/16 02:58 PM
02/02/16 02:58 PM
Posts: 1,662 PA
70Duster
PA
I just use a short piece of zinc-plated chain. Anything you use (torque strap, or cable, or chain) is going to be visible and noticable. Chain always does it for me. If you don't like the looks, cover it with shrink wrap. I use welded link chain also. So it's not noticeable, I get an appropriate sized bicycle inner tube, cut the valve stem area away, and fish the chain through the inner tube. With the matte black finish of the inner tube, it is hardly noticeable.
[Re: 19swinger70]
#2004726
02/03/16 10:58 AM
02/03/16 10:58 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I've had one of these on my Dart for 15 years now. Nice piece and looks great. same here,i had to drill a couple o holes and done.ive had mine 15 years with a hot BB stoker motor and its still good.especially if you are going to show it ,this piece looks like it belongs there.
