Page 2 of 3 1 2 3
Re: Jets & air bleeds [Re: hemi-itis] #2004015
02/02/16 10:43 AM
02/02/16 10:43 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Not sure how it applies to a blown application, but I thought the guideline was the HS bleeds generally end up 26-28 when emulsion is correct...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Jets & air bleeds [Re: hemi-itis] #2004036
02/02/16 11:52 AM
02/02/16 11:52 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I would agree with Dom and start with a 28-9 HS bleed. What you have is way to big IMO for the top end on any application especially in a blown application.
What fuel are you using? Each race fuel will have a different stoich reading. For instance what we use in the heads up car is best closer to 12.6. Just saying this may be worth looking into as you may be WAY leaner than you think.
Re: Jets & air bleeds [Re: OUTLAWD] #2004055
02/02/16 12:40 PM
02/02/16 12:40 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
that is how I understand it also, sound's like you need to start dropping the bleed size down, if i remember correctly 26 is where my bleed size is on my dominator, but I would start dropping them down 2 sizes at a time, car should start picking up with the added fuel if it is in fact lean.
Re: Jets & air bleeds [Re: hemi-itis] #2004082
02/02/16 01:37 PM
02/02/16 01:37 PM
Mark Whitener Offline
Read the second post in the following thread. 37 is way too big for MAB's, try 28's. And the rest of the car/engine/carb info might help.
http://racingfuelsystems.myfunforum.org/viewtopic.php?f=25&t=42
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: Jets & air bleeds [Re: hemi-itis] #2004086
02/02/16 01:45 PM
02/02/16 01:45 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By hemi-itis
That's what I was unsure of.If one changed the AFR differently than the other my jet selection ends at 99.I want to fatten the bleed and take some jet out.Then see how it effects my AFR's.I also put an air temp sensor in the intake to see what the temp is when I hit the heat ceiling.I also wonder how back pressure effects the AFR's. shruggy
Just throw some 28`s in there and be prepared to POSSIBLY jet down. Read the post Mark posted to grasp the relationship between e-bleeds and hi and low bleeds to see how they SHAPE the curve and how the jet in fuel and booster outlet control it.......Then there`s angle channel sizing etc.
Re: Jets & air bleeds [Re: Mark Whitener] #2004198
02/02/16 04:09 PM
02/02/16 04:09 PM
AndyF Offline
AndyF  Offline
The picture that Tuner included in that thread is a classic. It should be a sticky on here so people understand the difference between bleeds and jets.
Re: Jets & air bleeds [Re: hemi-itis] #2004305
02/02/16 06:59 PM
02/02/16 06:59 PM
Great Neck,LI,new york
hemi-itis Offline OP
That's what I'm trying to find out Andy,bleeds VS jets.Now at .035 and will go .028.
Al,I'm still on pump gas.Would like to find how it goes on pump junk,get it consistant so I can tune the suspension. Caltracs & Vikings on all 4 corners. My 60 are not that good blush
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Jets & air bleeds [Re: OUTLAWD] #2004307
02/02/16 07:01 PM
02/02/16 07:01 PM
That appears to be where I end up with smaller jets. iagree
Re: Jets & air bleeds [Re: hemi-itis] #2004308
02/02/16 07:03 PM
02/02/16 07:03 PM
Last pass the plugs were white with NO speckling,I know if I could have fattened it up there was a few MPH to be had.
Re: Jets & air bleeds [Re: MR_P_BODY] #2004311
02/02/16 07:06 PM
02/02/16 07:06 PM
Originally Posted By MR_P_BODY
I use the ratio of 1 bleed size = 2 jet sizes..
its close but not perfect.. so if you want to
drop 10 jet sizes you drop 5 bleed sizes
wave
So that can be done that way and not change AFR's??
Re: Jets & air bleeds [Re: hemi-itis] #2004382
02/02/16 08:58 PM
02/02/16 08:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You can NEVER fatten it up enuff w/38 hi speed bleeds.........
Re: Jets & air bleeds [Re: Thumperdart] #2004417
02/02/16 10:00 PM
02/02/16 10:00 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
He is using SV1's for carbs you guys know, right?......And they do not always fall into the same "range" as other carbs do for jetting.....Gots to follow the AFR....Its the only way I was able to start gaining on mine.
Re: Jets & air bleeds [Re: Dragula] #2004480
02/02/16 11:38 PM
02/02/16 11:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Do they differ in their fuel "curve" needs? Cos a 38 bleed is WAY out in left field "generally..........
Re: Jets & air bleeds [Re: Thumperdart] #2004505
02/03/16 12:11 AM
02/03/16 12:11 AM
Dragula Offline
Dragula  Offline
I tried the basic setup based on the size of the carb....No worky, so lets go with, they are different. Now I could share my setup, but mine is NA and a single carb...Probably totally different, dunno. I am not a carb guy.
I do know that my AFR is right around 11.9/12.0 WOT....And I need to lean it out just a tad more, and then work on my transition. These carbs idle better and cruise better than anything else I have seen, but I still struggle with the transition which is port #5 I think....
You also have to remember, these uncover a lot of throttle really quickly being what they are...I have called and received tuning advice, and I found the best way is to street it and watch the AFR...Trial and error.
Re: Jets & air bleeds [Re: Dragula] #2004510
02/03/16 12:20 AM
02/03/16 12:20 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Gotcha, never messed w/one and really have no desire to so your advice definitely outshines mine here........... thumbs
Re: Jets & air bleeds [Re: Thumperdart] #2004537
02/03/16 12:49 AM
02/03/16 12:49 AM
Dragula Offline
Dragula  Offline
Not claiming to know a whole lot...I kinda get myself into more trouble than its worth sometimes.
Re: Jets & air bleeds [Re: Dragula] #2004593
02/03/16 02:27 AM
02/03/16 02:27 AM
I'm no expert,,,,but I did stay in a Holiday Express once grin
Dom seems to be right on, Patrick told me to drop the bleeds down and jet as needed. Guess we will see if the jets & bleeds mimick those of a Dominator.I also had an issue breaking the throttle blades open from idle, I believe the 15 inches of vacume at an idle made it hard to come off idle smoothly.After breaking the second "stock" throttle pedal, I installed a lokar pedal.It's better,but not perfect.
Re: Jets & air bleeds [Re: hemi-itis] #2004594
02/03/16 02:30 AM
02/03/16 02:30 AM
Overhead view,,,,,,,,
Re: Jets & air bleeds [Re: Thumperdart] #2004595
02/03/16 02:33 AM
02/03/16 02:33 AM
I gave it ALL I had,,,,,,99's square violin
Re: Jets & air bleeds [Re: hemi-itis] #2004606
02/03/16 02:54 AM
02/03/16 02:54 AM
The fix.
Mark Whitener
Page 2 of 3 1 2 3
