Jets & air bleeds
#2003318
02/01/16 12:43 PM
02/01/16 12:43 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Last year I finally started to fine tune.Started jetting up with plug readings using the azz dyno and time slips.Only getting 4 runs in a day made it a loooooong process.I ended the season with the biggest jets I have which are 99's and its square and still a little lean.My carb guy said to start reducing the air bleed size. What I would like to know,what is the difference between increasing the jet size VS reducing the air bleed. I can see where I might be able to make small changes due to the DA with air bleeds only.Is that ok,,or should I be making those changes with jeta?? ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
Re: Jets & air bleeds
[Re: hemi-itis]
#2003333
02/01/16 01:00 PM
02/01/16 01:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use the ratio of 1 bleed size = 2 jet sizes.. its close but not perfect.. so if you want to drop 10 jet sizes you drop 5 bleed sizes ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: hemi-itis]
#2003341
02/01/16 01:06 PM
02/01/16 01:06 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Depends on how efficient the carbs are but we have usually seen closer to one bleed being more in line with moving the jet 3-4 sizes. But your results may vary. My opinion would be don't get to carried away with dropping the hi speed bleed, and we are talking just replacing the high speed bleed here. They also sell larger jets than 99, and not all jets are created equal. You could buy 100, 102, 104, 106, 108 and 110's. But honestly buying a Holley jet and not pinning it who knows
[Re: hemi-itis]
#2003379
02/01/16 02:02 PM
02/01/16 02:02 PM
Thumperdart
State of confusion
Not uncommon to have jets that are way bigger than needed if the hi speed bleeds are too big and I too was at 99`s w/ .037 hi speed bleeds so I went w/.028 hi`s and brought the jetting down to 84-92 (ft. p/v) and now it rocks. What size are the hi`s now...........Another note; can`t pin holley jets w/any accuracy due to the taper unlike others like maxi jets and maybe BLP which are numbered to size not flow...........
[Re: hemi-itis]
#2003381
02/01/16 02:06 PM
02/01/16 02:06 PM
Al_Alguire
Las Vegas
Guess I should ad changing two that pin the same will do little to change the curve. Yes some do have different taper that Holley claims this changes the amount of fuel it flows but it will do little to change the amount of fuel there. Funny how no one else does this, so makes one question how much this taper changes anything. I hear the no use pinning thing all the time, I have pinned every Holley jet from 62-110 and can tell you the only time I have seen the same pin size is in SOME sequentially numbered jets, Most likely why many suggest never bothering to change just one sizes at a time, always go up 2.
[Re: Al_Alguire]
#2003386
02/01/16 02:14 PM
02/01/16 02:14 PM
Thumperdart
State of confusion
I think after a 70 holley jet the hole gets bigger BUT the taper and depth changes therefore the FLOW changes. No bs just facts and holley is all I use and the small changes react as they should...........one holley jet equals roughly a 4% change in flow and if it wasn`t for the holley engineers 50 years ago, none of these other holley "copies" would exist.........
[Re: hemi-itis]
#2003390
02/01/16 02:18 PM
02/01/16 02:18 PM
Al_Alguire
Las Vegas
We prefer jets where the numbers actually MEAN something ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Cannat say I have seen the same results on the dyno going up one size on many holley jets. But all I have to rely on is my experience on the dyno reading AFR numbers and jets. I am not a carb guru for sure. BTW it if was not for Henry Ford we would not be where we are either. Things progress you either keep up or fall behind. To each their own. Guess we should just keep using those old sand cast metering blocks and porous main body and boosters too ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
[Re: Al_Alguire]
#2003397
02/01/16 02:28 PM
02/01/16 02:28 PM
Thumperdart
State of confusion
I`ll keep that in mind Andy after the many I`ve fixed w/(don`t touch the bleeds)are awesome just ask around and yes the bleeds are the curve and when the jets are out in left field the CURVE is jacked due sometimes to hi speed bleeds. Again Andy, you spend time in a dyno room(not real world)and I test/tune on the mean streets and most on here are faster and cleaner after I touch the "don`t touch" hi speed bleeds. Al, I usually see results from a two jet or more change and I love the billet pieces and modern touches for sure it`s just the WACKED tunes as YOU`VE admitted that needs help........Forgot; I have two local 8-second street/strip cars that have stock blocks n bowls on em SO they do work just not as light and pretty.......
[Re: hemi-itis]
#2003494
02/01/16 04:12 PM
02/01/16 04:12 PM
hemi-itis
As the RPM and the boost goes up,so do the AFR's.I'm stll pulling plugs,so easy with a hemi.It's getting into the high 13's with NO speckling.I'm starting to thing that back pressure might be diluting the combustion chamber ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) At this point I can see the results on the next pass,unfortuatly I have to wait 'till spring to continue being a tuna fish.My next 2 obsticles will be heat & the full exhaust.
[Re: hemi-itis]
#2003502
02/01/16 04:19 PM
02/01/16 04:19 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
The air bleeds, high speed and idle affect the mixing of air and fuel in the carb. I look at the percentage of difference in hole sizes when changing the bleeds, a .027 bleed compared to a .029 bleed is substantial difference in the percentage of the hole sizes. Bigger bleed hole equals more air with less fuel, less hole size equals less air amd more fuel into that circuit ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) The idle circuit bleeds affects the air fuel ratio from idle to W.O.T no mattr wah the RPM ![work work](/ubbthreads/images/graemlins/custom/work.gif) I remember a statement in National Dragster that the Pro Stock teams didn't change jets in thier carbs. once they had them dialed in from Denver in the summer to Pomona in the winter, they would and did change the bleeds for each track and weather conditions on a regular basis ![work work](/ubbthreads/images/graemlins/custom/work.gif) Tune off the spark plug and time slip for that day, unless you buy and use a wide ban ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Once you get the car as good as you can from jetting then try tuning the bleeds ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) IHTHs
[Re: hemi-itis]
#2003506
02/01/16 04:26 PM
02/01/16 04:26 PM
Thumperdart
State of confusion
As the RPM and the boost goes up,so do the AFR's.I'm stll pulling plugs,so easy with a hemi.It's getting into the high 13's with NO speckling.I'm starting to thing that back pressure might be diluting the combustion chamber ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) At this point I can see the results on the next pass,unfortuatly I have to wait 'till spring to continue being a tuna fish.My next 2 obsticles will be heat & the full exhaust. AGAIN, What size hi speeds bleeds are in it(em)now...........
[Re: Thumperdart]
#2003798
02/01/16 10:46 PM
02/01/16 10:46 PM
hemi-itis
Dom,they have .038 in the high bleeds,jets 99 square.Best pass so far had 30* timing.Want to try 28* and see if it picks up.I will change the HSB's and start from there in the spring. I did install a Racepak logger dash so I can see what's going on.Want to find the limit on pump gas with a few more passes,then overdrive it then see where it will go.At almost 4k LBS,it's a handfull ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
[Re: hemi-itis]
#2003803
02/01/16 10:55 PM
02/01/16 10:55 PM
MR_P_BODY
Are you by chance using E-vacs with them ahead of the O2 bung.. if so.. change that.. you will get a bogus A/F reading... also if the bung is near the exit of the collector.. that will give you a lean number also ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: hemi-itis]
#2003923
02/02/16 01:46 AM
02/02/16 01:46 AM
Thumperdart
State of confusion
Dom,they have .038 in the high bleeds,jets 99 square.Best pass so far had 30* timing.Want to try 28* and see if it picks up.I will change the HSB's and start from there in the spring. I did install a Racepak logger dash so I can see what's going on.Want to find the limit on pump gas with a few more passes,then overdrive it then see where it will go.At almost 4k LBS,it's a handfull Try some 28`s for starters and watch what happens w/the jetting........
[Re: hemi-itis]
#2003960
02/02/16 03:05 AM
02/02/16 03:05 AM
MR_P_BODY
So at this point it doesn't matter which way to fatten,be it bleeds or jets?? What do you have for a jetting set... if yours goes up to 99s now then yes it would matter.. unless you want to start buying more jets.. I have 2 sets(boxes) that range from 35(I think) to 99.. I have 2 sets for when I was running dual 4bbl and when I got my dom from QF after having them set it up for E-85 I asked if they could set it up for the jets I have.. they did so that way I wouldnt have to go buy more.. just something to think about ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2004013
02/02/16 10:40 AM
02/02/16 10:40 AM
hemi-itis
Are you by chance using E-vacs with them ahead of the O2 bung.. if so.. change that.. you will get a bogus A/F reading... also if the bung is near the exit of the collector.. that will give you a lean number also Evac is capped.O2 should be back far enough in the exhsust pipe. Collector is 4 inch going into 4inch exhaust reduced to 3.5 In front of the muff When I remove the exhaust,I will need extensions and put an o/2 bung in them. I Thoght bleeds & jet changes effected the AFR differently ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif)
