Dick Landy's Pro Stock modified T/A scoop... on My Chally?
#2001809
01/30/16 11:52 AM
01/30/16 11:52 AM
BradH
For at least some time in 1971, Dick Landy's choice of a hood scoop on his Pro Stock Challenger was a modified T/A raised behind the entry "snout" for additional carb clearance. This is the type of modification I've talked about doing to my repro T/A hood w/ a local shop who does a lot fiberglass work. Figured I show some pics of Landy's car, one of my car "as is" and a (crude) photo-shopped version showing what I think it would look like on mine. It would certainly expand my choice of intake manifold options, as well as keep -- somewhat -- to the original style of the car.
Re: Dick Landy's Pro Stock modified T/A scoop
[Re: BradH]
#2001813
01/30/16 12:03 PM
01/30/16 12:03 PM
Posts: 2,346 west palm beach, florida
modelmakerinc
The top pic, the scoop is raised off the hood surface, the second seems to have a bulge on the top of the scoop.
If it were me, I would do two things. I would section the scoop and add 1/2- 3/4" through the open area of the scoop and raise the base to lift it above the hood surface a bit.
Done properly the proportions would make it look kinda bigger but not wrong.
Re: Dick Landy's Pro Stock modified T/A scoop... on My Chally?
[Re: BradH]
#2001822
01/30/16 12:21 PM
01/30/16 12:21 PM
Posts: 8,190 Plymouth, MI
Blusmbl
Plymouth, MI
I think it looks a little odd but not bad by any means. I don't know if I like the Landy scoop vs. some of the other taller T/A scoops better though.
[Re: BradH]
#2001823
01/30/16 12:24 PM
01/30/16 12:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You need to KNOW how much vertical you need to get the intake and filter on it... so how much is that right now.. leave yourself a extra 1/2" of vertical for clearance... myself I would cut the scoop from front to back through the inlet opening and lift the whole top and blend in what is needed... it would look more like Ricks challenger scoop(or buy one like his)
[Re: BradH]
#2001852
01/30/16 01:09 PM
01/30/16 01:09 PM
Thumperdart
State of confusion
I like the 1st pic the best and I think the whole scoop needs to be higher not just the center that way the entrance is more in the "good air" but the my 6-pack is pullin air like mad so,..............
[Re: SpareParts]
#2001860
01/30/16 01:17 PM
01/30/16 01:17 PM
BradH
Maybe it's just the angle but the first picture the whole hood almost looks raised, like it blisters up through the middle. Anyone else see that? I definitely like the look of the 1st one The first pic of the resto definitely looks a bit different than the photo of the original below it. There are other pics of the resto that IMO make it appear "cleaner" in execution.
[Re: BradH]
#2001925
01/30/16 02:49 PM
01/30/16 02:49 PM
Posts: 1,506 TN
SCATPACK 1
TN
For at least some time in 1971, Dick Landy's choice of a hood scoop on his Pro Stock Challenger was a modified T/A raised behind the entry "snout" for additional carb clearance. This is the type of modification I've talked about doing to my repro T/A hood w/ a local shop who does a lot fiberglass work. Figured I show some pics of Landy's car, one of my car "as is" and a (crude) photo-shopped version showing what I think it would look like on mine. It would certainly expand my choice of intake manifold options, as well as keep -- somewhat -- to the original style of the car. Brad those are two different hoods. If you want it to look like the restored hood, then you will need to section the entire scoop including the opening and raise it all up so it looks right. I looked at his car a lot at Bristol in 1970 and the hood looked like the one in the top (restored) picture. It did not look like the second picture. I am sure that was the first attempt to get carb clearance and then he cleaned it up some to make it look more astatically pleasing. Jerry
Old Geezer Racing
