Re: 780 #3310 for racing
[Re: junkyardmaxie]
#2002065
01/30/16 05:51 PM
01/30/16 05:51 PM
Posts: 43,311 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#2002080
01/30/16 06:12 PM
01/30/16 06:12 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
A long tome ago, I used one on my 440 bracket car with some success. Easy to drive, but eventually I worked up to an 850 DP and achieved that cars best ETs and speed. Still a good place to start and you can use the same fittings and linkage on a bigger carb.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: junkyardmaxie]
#2002099
01/30/16 06:38 PM
01/30/16 06:38 PM
Posts: 304 Florida
Mark Whitener
My first year bracket racing, 1983, I was runner up in the sportsman class for the season. Second year I won. 780 vacuum secondary.
Mark Whitener [url=www.racingfuelsystems.com[/url]
[Re: Dave Hall]
#2002213
01/30/16 09:08 PM
01/30/16 09:08 PM
Posts: 5,992 Anoka County, MN
Leigh
Anoka County, MN
2970 total, stock stroke 360, X heads, 4:56 gear, 5100 flash, .557 cam, 1.50 60's, well thought out, hundreds of passes. A B A, each jetted over hundreds of passes, no difference in R4780 and R3310. (780, down leg boosters). It depends on the motor. Enough is enough. Anecdotal opinion from a dumb A@@!
[Re: junkyardmaxie]
#2002402
01/31/16 12:51 AM
01/31/16 12:51 AM
Posts: 12,296 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
If you can tune a carb and the carb is sized right for your combo, then you can make most any one work. Some will just take more work and require more changes than others. In other words, the tuner is more important than the carb. I personally like the 3310. A lot. For street cars, it and the new Street Demons are my go-to carbs. But it would not be my first choice for a track car. But that doesn't mean it cannot be a winner in the right hands and on the right combo. As has been noted in a previous post. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
Master, again and still
[Re: junkyardmaxie]
#2002443
01/31/16 01:50 AM
01/31/16 01:50 AM
Leigh
Anoka County, MN
what jets, 50 cc pump, what power valves ? my set up real close to yours I'm sorry, that was 33 years ago! I do remember that combo needed more pump shot, so I used a 50 cc pump. A different cam, converter, manifold combo probably wouldn't need it.
[Re: DaveRS23]
#2002586
01/31/16 12:22 PM
01/31/16 12:22 PM
Posts: 7,506 Az
Crizila
Az
If you can tune a carb and the carb is sized right for your combo, then you can make most any one work. Some will just take more work and require more changes than others. In other words, the tuner is more important than the carb. I personally like the 3310. A lot. For street cars, it and the new Street Demons are my go-to carbs. But it would not be my first choice for a track car. But that doesn't mean it cannot be a winner in the right hands and on the right combo. As has been noted in a previous post. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Found this one in a carb junk pile at a swap meet. $25. Works great. The 3310 is one of the all time best street carbs Holley ever sold - and they sold plenty.
Fastest 300
[Re: B1MAXX]
#2002676
01/31/16 03:00 PM
01/31/16 03:00 PM
Thumperdart
State of confusion
Even though I like and have them on street engines, a vacuum secondary carb is not the best for the track. They aren't as quick to react. You will never get the car to 60 as good as a double pumper. my Agree, and I don`t use a vs on anything ever and can get a dp just as clean on the street...........
[Re: cgall]
#2003442
02/01/16 03:25 PM
02/01/16 03:25 PM
dogdays
To answer the question, I would estimate that more than 100,000 3310s have been used on drag cars since it was introduced on the 425hp 396 in 1965. Many of these cars have been winners.
The downleg booster carb is the only 780 in the series, everything else is a 750. If you look at the boosters some of the carbs have little tabs sticking out on the outside of the booster, those were there to correct fuel distribution problems in the 396.
Holley switched to straight boosters with the 3310-2, IIRC, and that was a long time ago.
If you're after that last tenth a double pumper is probably better. If you are after consistency, like bracket racing, the 3310 can be a very good carb.
If you're looking for a strictly street carb the 80508 is a newer version of the 3310 and I believe it has better metering.
R.
[Re: junkyardmaxie]
#2003999
02/02/16 09:02 AM
02/02/16 09:02 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
IMO a tight converter will like the vacuum carb over the D/P. The only dislike I ever had with a 3310 was actually on the street and roll racing - the slight lag before the secondaries rolled in that a D/P doesn't have.
Free advice and worth every penny... Factory trained Slinky rewinder.........
