Re: 780 #3310 for racing
[Re: cgall]
#2003442
02/01/16 03:25 PM
02/01/16 03:25 PM
dogdays
To answer the question, I would estimate that more than 100,000 3310s have been used on drag cars since it was introduced on the 425hp 396 in 1965. Many of these cars have been winners.
The downleg booster carb is the only 780 in the series, everything else is a 750. If you look at the boosters some of the carbs have little tabs sticking out on the outside of the booster, those were there to correct fuel distribution problems in the 396.
Holley switched to straight boosters with the 3310-2, IIRC, and that was a long time ago.
If you're after that last tenth a double pumper is probably better. If you are after consistency, like bracket racing, the 3310 can be a very good carb.
If you're looking for a strictly street carb the 80508 is a newer version of the 3310 and I believe it has better metering.
R.
[Re: junkyardmaxie]
#2003999
02/02/16 09:02 AM
02/02/16 09:02 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
IMO a tight converter will like the vacuum carb over the D/P. The only dislike I ever had with a 3310 was actually on the street and roll racing - the slight lag before the secondaries rolled in that a D/P doesn't have.
Free advice and worth every penny... Factory trained Slinky rewinder.........
