Help! What is the ring size for L2293 Pistons #2001658
01/30/16 01:28 AM
01/30/16 01:28 AM
Naperville, IL
TamrazsParts Offline OP
Naperville, IL
I have a .060 over 383. Got the engine as a short block and am running a clean up re-bearing/re-rering rebuild for the summer.
Ordered a set of top/second 5/64 rings and they are too fat. Are these pistons a 1/16 or 3/32 top and second ring?
There isn't much information out there on the rings. I can find anything on compression and weights but nothing on the ring types.
Any assistance appreciated. chuck@tamrazs.com
Thanks Moparts!
Come check out our latest products!
http://www.tamrazs.com
Re: Help! What is the ring size for L2293 Pistons [Re: TamrazsParts] #2001753
01/30/16 04:59 AM
01/30/16 04:59 AM
I'm almost sure that the ring sizes should be 1/16,1/16, and 3/16 on the oil rings. TRW, as far as I know and remember, never varied from either 5/64,5/64, 3/16 or the narrower 1/16, 1/16, 3/16 on all the Mopar Hi Po V8 pistons. I have seen and used the 1/8 oil rings on a Hi Po 427 Ford motor, maybe even some Chevy may have used them also, maybe not confused IHTHs
Re: Help! What is the ring size for L2293 Pistons [Re: TamrazsParts] #2001802
01/30/16 11:28 AM
01/30/16 11:28 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Do you have a set of feeler gauges? set to .093 and .062 and see which slides in.
Joe
Without Data, you’re just another guy with an opinion.
Re: Help! What is the ring size for L2293 Pistons [Re: Cab_Burge] #2002102
01/30/16 06:40 PM
01/30/16 06:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Correct according to the TRW catalog.
