Re: Rear End question about gears and overdrive.
[Re: 2ndopp]
#2012079
02/14/16 10:50 PM
02/14/16 10:50 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
By the way 2ndopp, I think you'll be alot happier taking your 360 to 408 cubes vs. doing a full swap in to a 440. I'm a big block guy but it takes alot of time and money to completely change over, usually you're talking about changing radiator, engine mounts, headers, different tranny case, maybe converter, engine accessories, etc etc.
[Re: ProSport]
#2013267
02/16/16 05:22 PM
02/16/16 05:22 PM
Posts: 4,457 Washington
madscientist
Washington
Actually, I have not seen a set of 3.08's for a 60 since 1983 when I bought the 5.57's for my car. I remember thinking who would use that gear? It's worthless to me. If they don't make it today, it's because no one wanted it.
I will never understand how people calculate gear ratio, especially the auto guys. They gear too tall and force the converter to slip and then say the engine rev's too high. Obviously, I don't care for automatics either.
I can't think of a single use for a 3.54 gear for a muscle car oriented set up. It's not a camry. Please let all the manufacturer's know which parts you don't approve of so they can stop production immediately! And feel free to make a list of how you want us to build our cars, you crack me up. Hopefully you'll be cruising around my neighborhood so I can show you how well 3.23 gears work with a stroked big block. Not to mention the maroon colored Dart here on Moparts that runs 9.50's with a 3.54 gear. I hope he built the rest of his car to your expectations. Are you running less than 318 cubes with your 557 gears? I don't care what you do. You get butt hurt awful easy. If you think a 3.55 is a LOW gear I can't help you. Get a life.
[Re: 2ndopp]
#2013298
02/16/16 06:38 PM
02/16/16 06:38 PM
ProSport
Akron, Ohio
If you think a 3.55 is a LOW gear I can't help you. Get a life. Not butt hurt at all, and my life is amazing. Just trying to point out bad info, not everyone needs 557 gears in their street car and street gears aren't just for Camry's. Have a great day!
