Re: Gen 2 Hemi in A-body? [Re: Hot 340] #2002376
01/31/16 12:31 AM
01/31/16 12:31 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Welllll.......I started with bare Hedmans. Ended up changing 5 tubes and both collectors. Then had them coated. I do not know if TTIs or anything else will fit without mods.
The SS and AFX mount kit is a weld-in kit. I bolted in my bare "K" member and suspended the engine with the mounts bolted to it by a cherry picker. Then positioned the mounts and tacked them with a welder. It took some trimming of the mounts to get it just where it needed to be. But it fit.......barely.
There is a reason that there are not Hemi A bodies running around everywhere.
Master, again and still
Re: Gen 2 Hemi in A-body? [Re: cudadoug] #2002467
01/31/16 02:20 AM
01/31/16 02:20 AM
Skypower Offline
Skypower  Offline
Denny at hdk built my k-member he has all the measurements for an a body with tti headers and a test mule front end to make sure all fits like it should.
