Re: SB to BB swap problem [Re: moparmarks] #2001729
01/30/16 03:35 AM
01/30/16 03:35 AM
ND
dodgedon Offline
dodgedon  Offline
ND
I'm not sure on the 77. Maybe someone can take a picture of what they have. I did find a few pictures of what I'm thinking.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: SB to BB swap problem [Re: dodgedon] #2001732
01/30/16 03:42 AM
01/30/16 03:42 AM
ND
dodgedon Offline
dodgedon  Offline
ND
I don't know what year these trucks are but this is what I was thinking.... In the small picture you can see the rubber mounts are beside the extension. The plate is bolted solid to the bottom.
Anyone have a truck like this to verify??
67 Charger 383 auto
Re: SB to BB swap problem [Re: moparmarks] #2001736
01/30/16 03:53 AM
01/30/16 03:53 AM
Western Colorado High Desert
moparmarks Offline OP
Ok that looks like a 208 transfer case. Mine is a 203 so that's probably the difference. They use different extensions.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: SB to BB swap problem [Re: moparmarks] #2002041
01/30/16 05:30 PM
01/30/16 05:30 PM
Alberta
440_Offroader Offline
Alberta
Both my 79's with 203's have the plate. I know a ramcharger I had, had a similar issue. I had to leave all transmission crossmember/mount bolts loose to get the passenger mount to go in. IIRC I had to space the passenger mount up some also, to have the engine level.
Re: SB to BB swap problem [Re: moparmarks] #2002082
01/30/16 06:12 PM
01/30/16 06:12 PM
This 77 didn't have a plate and the cross member has big holes for the rubber mounts to fit in. Sure looks factory to me.
Also the cross member in the above pic is different than mine.
If the transfer case goes up any more then it will hit the floor.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: SB to BB swap problem [Re: moparmarks] #2002436
01/31/16 01:37 AM
01/31/16 01:37 AM
ND
dodgedon Offline
dodgedon  Offline
ND
The cross member in the picture has the riser bolted on it for a larger frame rail. My 85 W350 has that also. Half ton trucks would not have that part.
67 Charger 383 auto
Re: SB to BB swap problem [Re: moparmarks] #2002542
01/31/16 10:51 AM
01/31/16 10:51 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I've had a couple of mid 70s Ramchargers and a Trailduster that had the plate, and my 80 1/2 ton 4x4 had the plate, but those were all small block trucks, maybe the difference?
I think, looking at everything your dealing with, I would enlarge the holes in the frame and add a washer under the nut. It doesn't explain where the issue rests, but it will move the project forward without causing a huge problem in the real life workings of the truck.
I suspect that at some point, someone will come on here ans say "I had that problem and ???? was the cause, and this was the fix". Then we will all be doing the head slap and go "OOOOOHHHH!!!!" But that might be a year from now or more.
Enlarge the holes and put it together. If the fix is identified, you can address it then if you wish. Gene
Re: SB to BB swap problem [Re: poorboy] #2003552
02/01/16 05:17 PM
02/01/16 05:17 PM
dogdays Offline
dogdays  Offline
Good idea.
R.
Re: SB to BB swap problem [Re: dogdays] #2004401
02/02/16 09:31 PM
02/02/16 09:31 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
Ok I just looked at mine, the passenger mount is on the front of the motor ears and the drivers side is on the rear and mine is in an 83 4x4 with a 383 auto trans.If you need a pic I can go out and snap one.
Re: SB to BB swap problem [Re: G-Money1320] #2004435
02/02/16 10:27 PM
02/02/16 10:27 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
Dont mind the rust and paint chipping, thats what salt and snow plowing do!! smile It will be redone this year. Here is the drivers side.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: SB to BB swap problem [Re: moparmarks] #2004442
02/02/16 10:46 PM
02/02/16 10:46 PM
Thanks G-Money. That's interesting. Could I trouble you for another picture of the pass mount? Maybe pull the plug wire and see if you can get a shot of the lower mounting bolt.
Many thanks.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: SB to BB swap problem [Re: G-Money1320] #2004443
02/02/16 10:46 PM
02/02/16 10:46 PM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
This is what I was going to reply! This is exactly what I had to do when I did the swap on my 88 ram. I couldn't figure out why the transmission wouldn't line up, just like the OP. I found an old picture on RCC. Set the mounts up like these pics and it solved the problem
Re: SB to BB swap problem [Re: James74] #2004447
02/02/16 10:51 PM
02/02/16 10:51 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
I will get one for you tommorrow as its pouring out right now and I think the wife is getting worried that I keep going out in my long johns to take pics!! smile
Re: SB to BB swap problem [Re: G-Money1320] #2004456
02/02/16 11:01 PM
02/02/16 11:01 PM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
http://ramchargercentral.com/articles/?sa=view;article=37
here's the link to the pics I was talking about, if it helps...
Re: SB to BB swap problem [Re: moparmarks] #2006771
02/06/16 03:12 PM
02/06/16 03:12 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Awesome thread!
Moparlee
