Re: 440 stock stroke 10 second combos
[Re: 383man]
#1999362
01/26/16 10:46 PM
01/26/16 10:46 PM
Posts: 1,030 ohio
67mprfan
ohio
I am just curious as with the 12.1 comp it dont sound like a pump gas combo so I am guessing its a race car only ? I friend with the duster says his compression is 12.1 and he insist he doesn't need race gas.... Its his motor I don't argue about it.
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: Street Monkies]
#1999492
01/27/16 12:33 AM
01/27/16 12:33 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I agree with using some good rods for sure. The lighter the better (BME?) Maybe a little work inside the runners on the Team-G, you could get away with 10* more duration and a bit more lift on the cam and a 5K vert. 2" header isn't out of the question either. Don't know if you seen the thread Brad H started? Fast 3.75"-stroke combo's? My combo's on the 2nd page if your interested.
#1999521
01/27/16 01:04 AM
01/27/16 01:04 AM
Posts: 5,169 CT
GTX MATT
CT
The team G has a bad rep, I dont have first hand experience but someone I know ran 10.97 in a 69 Road Runner with a stock stroke 440, TRW pop ups with 906s milled to a close chamber about 12:1, heads were ported, Team G with an annular 850 DP, 4 speed, 5.13s, 557 purpleshaft, all steel body stock interior stripped. I believe McCandless didnthat motor.
#1999667
01/27/16 12:01 PM
01/27/16 12:01 PM
Posts: 1,033 Madison, Wisconsin
chrisnben
Madison, Wisconsin
My '72 Cuda went consistent 10.80's in the mid '90s weighing at 3300#
Nothing more than a 30 over 440 with ported 906's, M1 intake, Nueten 950 holley, Comp 305/620 solid cam. Car had SS leafs, 29x11 Goodyears and 4.30 gear. Basic Mopar street car with a cage.
Your setup should be a 10.0 car all day. Definitely a 9" converter! Stick with the 1-7/8 headers too.
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
#1999749
01/27/16 02:24 PM
01/27/16 02:24 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
My old combo circa 1995; 448, trw flat tops(actually sealed power) down the hole .055(9.7cr), ported big valve 906's(flowed mid-260's), UD roller 259/264-108 in at 106, torker II, reworked annular 850, hooker 2" headers. 68 satellite, 3670lbs race ready, flat hood, mechanical fuel pump, 5/16 factory fuel line, crank driven W/P and alternator, battery up front. 727 w/9" dymanic(5300 stall), 4.56's, 29.5 x 10.5 slicks, old SS springs. 10.80's-90's in typical summer weather. 70's in spring and fall, went 60's on one day. Speed in the 125 range, 60' usually around 1.51-1.54, best ever 1.46. Shift at 63-6400, out the back around 66-6700.
Lucky I never had one of those ly rods give up on me......I wouldn't build it like that again, but that short block was originally done in 1981. After seeing how much my 383 picked up by upgrading the fuel system and adding some fresh air, I really wished I had done it with the 448.(of course, that probably would have gone faster enough to blow it up!!)
[Re: 67mprfan]
#2000025
01/27/16 09:25 PM
01/27/16 09:25 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I am just curious as with the 12.1 comp it dont sound like a pump gas combo so I am guessing its a race car only ? I friend with the duster says his compression is 12.1 and he insist he doesn't need race gas.... Its his motor I don't argue about it. Its all about the cam... if the piston is way up the bore before the valve closes it'll run on junk fuel
#2000683
01/28/16 08:25 PM
01/28/16 08:25 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
I know this has been asked a lot of times in the past. I love looking at different engine/car combos. I'm putting together a very a mild combo. I would like some guesses on how much power/torque and what it should run. For motor it's going to be a .030 440 with the 3.75" forged crank. I have some small dome bme pistons. They weigh 721-722g with out pin. They're the 1.094" stock pin size. With pin they're 865g I have lite weight pins. I will have to check and see if I can come up with a cc or mock the block up and check and see what kind of cr I'll have. I'm thinking like 12:1. Haven't decided on connecting rods yet. I have ootb 440 source heads 80 cc closed chamber. I have steel retainers, 1107 spring's, stainless valves. 1.6 440 source rockers. I have a team G 4500 tall top with some plenum work done to it. I have a 9375 1050 Holley that might be converted to E85. Planning on like 1 7/8" primary tube headers with 3" collector. I was thinking 2" and 3.5" collector but that could be a bit much. Hopefully getting a comp cams 567/567 264/264 @ .050 106 lsa solid flat tappet cam. Plan on keeping oiling system pretty basic hopefully. Trans is a 727 and it will have a trans brake. Looking at 10" converter in the 3,000-4000 stall range. I'll probably be using a 4.56 gear. I'm expecting car to be around 2500-2600 lbs with driver. Thoughts, opinions, and sharing different combinations would be greatly appreciated. Thanks moparts. Maybe some of you will have fun with this. If it's "right", you're going to have a hard time keeping IN the 10's. At that weight, I see 9.80's easy. Several moons ago, I went high 10.30's @ 128-129 @ 3200# with... TRW flat tops LY rods R280 roller 906 heads 4150 base M1 w/Dominator adaptor BOX STOCK 1050
[Re: MR_P_BODY]
#2000773
01/28/16 11:11 PM
01/28/16 11:11 PM
Posts: 1,030 ohio
67mprfan
ohio
I am just curious as with the 12.1 comp it dont sound like a pump gas combo so I am guessing its a race car only ? I friend with the duster says his compression is 12.1 and he insist he doesn't need race gas.... Its his motor I don't argue about it. Its all about the cam... if the piston is way up the bore before the valve closes it'll run on junk fuel Mike his cam is in the 270's range its a split lift. As for piston they're domes that have been fly cut some
[Re: cudadoug]
#2000812
01/29/16 12:03 AM
01/29/16 12:03 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Dammmm 9.80's with ootb Source heads and you have gone 10.30's @ 129 with 906's !!! Im shocked
1963 Plymouth Max Wedge 1971 Barracuda
#2000839
01/29/16 12:36 AM
01/29/16 12:36 AM
Posts: 10,031 Frostbitefalls MN (Rocky&Bullw...
gregsdart
All I will add is don't cheap out on the converter if you are going to use a brake, or, keep the launch rpm way down so you don't kill it. A cheap converter not built for trans brake use may not last a weekend at full load. I had that happen to me a long time ago, the insides look like someone beat up all the fins with a big hammer!
[Re: ozymaxwedge]
#2000844
01/29/16 12:44 AM
01/29/16 12:44 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
You guys would shake your heads at what we had to do to run fast years ago. Heck I flycut pistons on an assembled engine to get valve to piston clearance when I switched to a mushroom tappet cam and needed more clearance. I burnt a head gasket and the car slowed .10 every round one Sunday and took 2nd place changing the dial every round. Tore the heads off Sunday night and had the block welded in the car with nichle stick Rod, Welded the head, filed it down with a hand file within .002-.003 and went racing the very next Friday. Man I love racing
[Re: ozymaxwedge]
#2000893
01/29/16 01:49 AM
01/29/16 01:49 AM
cudadoug
Dammmm 9.80's with ootb Source heads and you have gone 10.30's @ 129 with 906's !!! Im shocked They flowed right at 260 @ 28" on Holtons bench, which isn't that far from the Stealth heads from what I'm told. I can only wish I had the choices of heads we have today!
[Re: cudadoug]
#2000912
01/29/16 02:04 AM
01/29/16 02:04 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
[quote=cudadoug]
TRW flat tops LY rods R280 roller 906 heads 4150 base M1 w/Dominator adaptor BOX STOCK 1050 Dammmm 9.80's with ootb Source heads and you have gone 10.30's @ 129 with 906's !!! Im shocked They flowed right at 260 @ 28" on Holtons bench, which isn't that far from the Stealth heads from what I'm told. I can only wish I had the choices of heads we have today! [/quote You and I both. I never owned a set of aluminum heads till I both a set while I was going through my divorce in 1999. I couldn't afford to use them but I sure as heck bought them. Lol
#2000998
01/29/16 04:35 AM
01/29/16 04:35 AM
ozymaxwedge
Australia
With a 440 cast crank Ive managed 11.0's with maxed out 915's, 10.80's with indy SR's and ad some gas 9.69 @ 135 before going to a stroker.
