Re: 440 build whats the best cam for street use
[Re: Gerald l]
#1999067
01/26/16 04:01 PM
01/26/16 04:01 PM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
Easy and pretty cheap and runs decent.Summits cams.Ive ran all of them in SBs and BBS.one of the large BB cams is still alive after 30 years.Has a lope to it but still nice street manners and turns on great.really no need to swap tons of parts either.the small cam is just a bit above the factory and also runs decent.For the price they cant be beat.Rocky
Chrysler Firepower
[Re: Gerald l]
#1999158
01/26/16 06:27 PM
01/26/16 06:27 PM
Posts: 57 GA
Gerald l
GA
Its a 4 speed manual running power brakes. I don't really plan on racing it. Everything is stock on it right now. Rear end is 8 3/4 with 3.23 gears I believe. I just want 500+hp with lots of torque on the low end for some street fun.
[Re: Gerald l]
#1999235
01/26/16 08:04 PM
01/26/16 08:04 PM
dogdays
HAHAHAHA....."I just want 500hp". All the TV shows and Youtube videos about 800hp engines are warping reality.
A bone stock 1970 440 put on the dyno right off the line would make around 335 hp. No B$.
However you can get your number with the right parts. It shouldn't even be that hard. For a street engine a 450 hp engine with a really stout bottom end would feel stronger going from light to light. You can lie about dyno numbers however you like, and many do, or their dyno operators know how to squeeze another 50 or 60 hp out of an engine for the big number.
I'd find Edelbrock's 440 buildup from when they first brought out the Perf RPM heads.
R.
[Re: Gerald l]
#1999252
01/26/16 08:20 PM
01/26/16 08:20 PM
Posts: 31,114 Oregon
AndyF
Its a 4 speed manual running power brakes. I don't really plan on racing it. Everything is stock on it right now. Rear end is 8 3/4 with 3.23 gears I believe. I just want 500+hp with lots of torque on the low end for some street fun. That is doable providing you have the budget since it won't be super cheap. A stock rebuild shortblock with some good flat top pistons at zero deck will be required. You want to shoot for 9.5 or 10:1 compression but you'll need to run premium. If you want to run regular then lower it back down to 9:1 or so. Add the Trick Flow heads and a Performer RPM intake and a 750 Holley or a 800 cfm Edelbrock and you'll be there. You'll need a hyd roller cam and decent rocker arms which will add $2000 or so to the build. (You might be able to do it with a solid flat tappet and some Crane nodular iron rocker arms but you'll be taking chances on reliability) I assume you have headers? If not then everything needs to be adjusted for HP manifolds, especially the cam selection. Go search for the Trick Flow 440 buildup on their website. They made 620 hp with 10.5 compression and open headers and a single plane manifold. Not really a street car build, but it wasn't a race car engine either. So 500 hp is doable, but it is going to be a $8000 engine by the time you're all finished. The 450 hp engine that Dogdays is talking about is probably $6000. You'll save money by using something like E street heads and a less expensive valve train. I'd still use the Performer RPM and the 800 cfm Edelbrock carb.
[Re: Gerald l]
#1999272
01/26/16 08:48 PM
01/26/16 08:48 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Ehh......
I have a stock 346 headed 440 with KB hyperpistons, (9.6 compression) Comp XS282 baby solid that will run power brakes. M1 intake, headers, etc. Very LOW dollar set up. By the MPH calculator makes an honest 425hp. This is a no nonsense 11 second motor in a a body. Still high 11s in an avg weight b/e body
Add a decent set of heads, Eddy RPM for example and your at 500 with ease.
Same shortblock with a decent set of 452s makes an honest 525hp. Low 11s in a heavy (3800) b body. 10 second deal in a A body.
It gets really confusing to me...why people think you need to spend $$$ to make decent power. I don't get it....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Gerald l]
#1999390
01/26/16 11:13 PM
01/26/16 11:13 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Keep in mind.... Building 500 horsepower leads to spending more money than just building the motor. There are other things to consider. Not the least of which is that you currently have a 4 speed and an 8-3/4". 500 HP is hard on 8-3/4's even with an Automatic (Don't ask me how I know). With a 4-speed, you might as well plan on investing in a Dana before you even start on the motor.
Ma put Dana's behind stock 440/4-speed combos.
[Re: Gerald l]
#1999511
01/27/16 12:50 AM
01/27/16 12:50 AM
RapidRobert
I did get caught up in the numbers game. We'll keep ya straight! welcome aboard Gerald
[Re: RapidRobert]
#1999617
01/27/16 07:29 AM
01/27/16 07:29 AM
Posts: 3,344 Central TX
roe
Central TX
These guys here know so much more than me its rediculous. What I will add though is that if you are going to be doing a complete rebuild, then doing a stroker is a good idea as the cost difference is pretty negligable since you'll be doing machine work any way. You're already talking about buying heads, intake and carb, so go for it. You'll have more torque for the street car, which is what you'll need more than HP, and you can get those higher numbers with a less radical cam (not really an issue with a 440 anyway because of your starting cubic inches) than you would without the stroker. I did a smallblock, 360 to 408 stroker on a magnum motor. After feeling the difference in power in the street car rpm range, I will never have a non-stroker motor again if Im paying for it to be built because the price was the same. And if you do get the itch to go more to the max on power later, your base is there and wont have to be redone. Just my ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: Gerald l]
#1999688
01/27/16 12:32 PM
01/27/16 12:32 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Thanks, you guys have given me some good insight. I did get caught up in the numbers game. It's called reality. Need vs. what someone tells you that you want. Take any running forged crank 440 ('cause you have a stick and it's easiest to start with), add a mild hydraulic flat tappet with matching valve springs, and go drive the wheels off it. Once you start getting into a rebuilding frame of mind you're into $6k plus like Andy says. You will normally get more from spending more, but honestly it sounds like the mild 440 upgrade will be enough for you. At least for now.
[Re: Fat_Mike]
#1999778
01/27/16 03:06 PM
01/27/16 03:06 PM
dogdays
OP, thanks for getting smart about numbers. I remember my first backroad pass in my cousin's 383 Road Runner, 4-speed, completely stock. I was disappointed, it didn't feel that strong. So I understand about wanting more. A 440 will get you more, that's for sure.
IMHO you'd get plenty stroking the 383 that you have right now.
Why change blocks when a 4.25" stroke will get you 489 cubic inches? That's over 100 more cubic inches, roughly 125 lb-ft more torque. I'd suggest doing the shortblock first, keeping stock heads and intake. Those can be added later as your budget allows. And no, it won't hurt the shortblock to be choked on airflow for a while. Your stock heads were used in the same year on all 383s and 440s.
If you can find a 440 in good running condition it'd probably be cheaper, that is if you can keep yourself from doing any more than a cam swap. The problem is that 440s were last used about 37 years ago, and most of them were built with compression in the low 8s. So they're not perfect either.
R.
[Re: Fat_Mike]
#1999817
01/27/16 03:43 PM
01/27/16 03:43 PM
Posts: 2,692 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
To the smart guys (no sarcasm intended): Since the OP is starting out with a 383, might he be better off stroking a 400??? I agree
2011 Drag Pak Challenger
[Re: Gerald l]
#2000542
01/28/16 04:57 PM
01/28/16 04:57 PM
Posts: 411 Harleysville, PA USA
Tommy D
When I was having my first "hot" motor built (by a buddy), I wanted to know how much HP it would make. He told me that for the street, and at the track, you want torque to get a heavy car moving. Mine is a '69 Road Runner. He was dead right. You'll want driveability to be good, and won't want to sacrifice it for a little extra ET at the track, since that is not a goal of your's.
That being said, you have two choices if you want to add more than you currently have. You could add a bigger cam, better pistons, and some more rear gear to your current combo. It would, no doubt give you more kick in the pants.
If you went stroker (either with your 383, a 400, or a 440 block) you will spend lots. I just finished a 496" 440-based build using 440 Source parts. It runs fantastic. When it came time to selecting the camshaft, I was originally going to go with a low-maintenance, hydraulic flat tappet design. After contemplating it for quite a while, I came to the conclusion that it was worth it to me to spend the money on a solid roller cam. It added some cost to the build, but I already had the roller lifters and adjustable rockers. I couldn't come to grips with spending that much money on a new long block, and then choking it down with a baby cam. Now the car runs mid-11's through the mufflers in street trim. I couldn't be happier, and the extra money spent on the roller cam isn't even a thought any longer.
With regards to torque, you build torque when you mechanically slow down RPM. Assuming your current engine makes around 300HP at the crank, switching from your current 3.23:1 gears to 3.91:1's would have a huge impact on "seat of the pants" feel. It would greatly increase the highway RPM that you'd see though, so you'll need to make that decision.
This is the same principal that applies when riding a bike with gears. I make one unit of "Tom HP". That same amount of HP, when slowed down by using gear ratio (putting a bicycle into 1st gear) allows my "Tom HP" to carry my 240 lb butt up a hill. Using the same "Tom HP", but putting the bike into 10th gear will not be conducive to pulling me up the hill. In this example, the "Tom HP" is equivalent to the existing HP your engine makes. The example of switching gears on the bike is related to swapping your rear end gearing. I hope I didn't confuse you, but you may get the most "bang for your buck" by swapping a center section on your existing combo.
