Re: SB to BB swap problem
[Re: moparmarks]
#2001729
01/30/16 03:35 AM
01/30/16 03:35 AM
Posts: 517 ND
dodgedon
ND
I'm not sure on the 77. Maybe someone can take a picture of what they have. I did find a few pictures of what I'm thinking.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: dodgedon]
#2001732
01/30/16 03:42 AM
01/30/16 03:42 AM
Posts: 517 ND
dodgedon
ND
I don't know what year these trucks are but this is what I was thinking.... In the small picture you can see the rubber mounts are beside the extension. The plate is bolted solid to the bottom.
Anyone have a truck like this to verify??
[Re: moparmarks]
#2002082
01/30/16 06:12 PM
01/30/16 06:12 PM
Posts: 12,495 Western Colorado High Desert
moparmarks
This 77 didn't have a plate and the cross member has big holes for the rubber mounts to fit in. Sure looks factory to me. Also the cross member in the above pic is different than mine. If the transfer case goes up any more then it will hit the floor.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#2002436
01/31/16 01:37 AM
01/31/16 01:37 AM
Posts: 517 ND
dodgedon
ND
The cross member in the picture has the riser bolted on it for a larger frame rail. My 85 W350 has that also. Half ton trucks would not have that part.
[Re: moparmarks]
#2002542
01/31/16 10:51 AM
01/31/16 10:51 AM
Posts: 10,665 Freeport IL USA
poorboy
Freeport IL USA
I've had a couple of mid 70s Ramchargers and a Trailduster that had the plate, and my 80 1/2 ton 4x4 had the plate, but those were all small block trucks, maybe the difference?
I think, looking at everything your dealing with, I would enlarge the holes in the frame and add a washer under the nut. It doesn't explain where the issue rests, but it will move the project forward without causing a huge problem in the real life workings of the truck.
I suspect that at some point, someone will come on here ans say "I had that problem and ???? was the cause, and this was the fix". Then we will all be doing the head slap and go "OOOOOHHHH!!!!" But that might be a year from now or more. Enlarge the holes and put it together. If the fix is identified, you can address it then if you wish. Gene
[Re: poorboy]
#2003552
02/01/16 05:17 PM
02/01/16 05:17 PM
dogdays
[Re: G-Money1320]
#2004435
02/02/16 10:27 PM
02/02/16 10:27 PM
Posts: 1,675 Mi.
G-Money1320
Mi.
Dont mind the rust and paint chipping, thats what salt and snow plowing do!! ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) It will be redone this year. Here is the drivers side.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
[Re: moparmarks]
#2004442
02/02/16 10:46 PM
02/02/16 10:46 PM
moparmarks
Thanks G-Money. That's interesting. Could I trouble you for another picture of the pass mount? Maybe pull the plug wire and see if you can get a shot of the lower mounting bolt. Many thanks.
[Re: G-Money1320]
#2004443
02/02/16 10:46 PM
02/02/16 10:46 PM
Posts: 1,771 Jamestown, Indiana
James74
Jamestown, Indiana
Ok I just looked at mine, the passenger mount is on the front of the motor ears and the drivers side is on the rear and mine is in an 83 4x4 with a 383 auto trans.If you need a pic I can go out and snap one. This is what I was going to reply! This is exactly what I had to do when I did the swap on my 88 ram. I couldn't figure out why the transmission wouldn't line up, just like the OP. I found an old picture on RCC. Set the mounts up like these pics and it solved the problem
