Ok I'll give you some tips
Get a bottle Heater, keep extra bottles in it so they are at temp/pressure ready to go when you need them. I can make a bottle heater for under 50.00 is that too much ?
Get/make a flow tool, it's not that hard
Make plugs easy to,pull.
What's so hard about winching a car into a trailer ? I never drive mine in
Didn't you used to go on Josh'S board saying.......it's SO easy to bolt some nitrous on and race heads up.....yet SO hard to be a good bracket racer ? LOL
I can't believe some of you guys can't read or understand my main issue but yet say you race alone with your Son. My Son is now grown and lives elsewhere. He works and only raced 3 times last year. I will say AGAIN what my issue is. I'm being told by others that with nitrous to get a good tune you should tow to and from the lanes. How the heck can I tow the car and drive it too. Seems easy to understand to me but if not I will spell it out again
My car HAS NEVER BEEN TOWED up or back....
your running a big block, pull #8 and any other plugs on the return road. Honestly....you can read the straps for timing after driving back. do you really expect to come out guns blazing right from the first pass? WHy not start with a little and get your feet wet, add from there
