Re: Different Nag-1 controller
[Re: hudsonhornet7x]
#1997893
01/24/16 08:15 PM
01/24/16 08:15 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
Thanks Joe. I have spoken to Hotwire and they assured me they handle this swap,I just wanted to hear from someone who had done it. By the way, did you make your own adapter for the trans output to mate up to a regular u joint?
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: Darius]
#1997919
01/24/16 09:03 PM
01/24/16 09:03 PM
Posts: 66 Catskill Mountains, NY
Joe12459
I'm not sure when he got it all figured out, but I bought my system in June last year. I had actually seen your build thread, while I was working out my details, and contacted Russell Drake. At that time, he was still perfecting his setup( probably in your car), and advised me that it still needed some programming work. I'm not exactly a computer genius, so I went looking for another answer. The Hotwire setup made sense, as I had the complete 08 Charger donor car. This setup uses all of the factory modules, and programs them to read the speed signal from his tone ring, which is very similar to the PCS tone ring except it used two sensors. I have put several thousand miles on it now, and it performs flawlessly, just as the 08 Charger did. I have an 8 3/4 rear with 3.23 gears and it is great on the highway and plenty fast on the street. This is news to me. I looked into Hotwire and was led to believe they did not have the NAG1 stuff figured out, maybe that all happened after my debacle. Awesome news it is though as this drive line with an 83/4 rear is great! I have a 2.76 gear and I get 20 mpg 70mph=2000 +or- rpm. It is pretty quick off the line and I can smoke the tires all I want .It chirps 2nd and 3rd when I am on it hard but not spinning the tires. It would be a beast out the hole with even a 3.55. More guys will make this swap now the right equipment is available. It is worth it!
[Re: rattler]
#1997922
01/24/16 09:05 PM
01/24/16 09:05 PM
Joe12459
I bought a driveshaft from www.thedriveshaftshop.com , which has an aluminum adapter that bolts to the trans flange, and a high speed CV joint that takes the place of the front u-joint/slip joint. I've had the car to 140+ mph, and it doesn't vibrate at all. Very nice setup. Thanks Joe. I have spoken to Hotwire and they assured me they handle this swap,I just wanted to hear from someone who had done it. By the way, did you make your own adapter for the trans output to mate up to a regular u joint?
#1998006
01/24/16 10:57 PM
01/24/16 10:57 PM
rattler
Crofton, Ky.
Thanks Joe. Do you remember what your driveshaft and adapter cost? You can PM me the answer if you like.
[Re: rattler]
#1998019
01/24/16 11:11 PM
01/24/16 11:11 PM
Joe12459
It was around $800.00 shipped, and it took about two weeks from the time I ordered it until it arrived. Thanks Joe. Do you remember what your driveshaft and adapter cost? You can PM me the answer if you like.
[Re: Joe12459]
#1998022
01/24/16 11:14 PM
01/24/16 11:14 PM
Joe12459
You have to let them know if your trans has the three bolt (5.7) or the four bolt (6.1/6.4) flange, so they send you the right adapter, and you have to measure very accurately. If you use the Hotwire tone ring, allow 1/8" between the adapter and the flange for the tone ring. It was around $800.00 shipped, and it took about two weeks from the time I ordered it until it arrived. Thanks Joe. Do you remember what your driveshaft and adapter cost? You can PM me the answer if you like.
#1998250
01/25/16 10:55 AM
01/25/16 10:55 AM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
I am happy to see this. Lots of questions in my mind but they probably are more specific to MY particular build as I was trying to swap EVERYTHING including the dash over and that created a different set of issues with the instrumentation and such. Had I seen this I surely would have gone this route. I know I looked at Hotwire and they had nothing on their site at the time about sending them my computers and all. Great new for those who want to do this. I do notice they don't have a reference for Chargers or Challengers as donor cars, wonder if there is a difference as far as programming goes on Hotwire's part?
Driving modern convenience in classic beauty
#1998258
01/25/16 11:16 AM
01/25/16 11:16 AM
Posts: 361 Canada
onig
Canada
I don't have or plan to use a Nag1 trans at this time. But this is a good interesting thread. Carry on men.
69 Dart
