72 "Gold Duster" Build
#1995118
01/20/16 08:02 PM
01/20/16 08:02 PM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
And appropriately enough it is Gold. Dad decided he wanted something a little less "flashy" than the Banshee Dart so this is going back together as a sleeper. I picked this up in the fall with plans for a new build for him. Body is solid and the paint is...well I can live with it. Plan is to remove the 225 /6 and 904 along with the 7 1/4 and replace them with a 416-727 and 8 3/4. I do need to come up with a dash pad as this one is toast. I'm sure I'll have to source a bunch of other parts along the way...
...FAFO...
Re: 72 "Gold Duster" Build
[Re: skicker]
#1995123
01/20/16 08:09 PM
01/20/16 08:09 PM
skicker
"The Champ"
"The Champ"
Western Md.
The plastic trim on the body is the only thing I will be removing from the exterior. I picked up a set of Wilwood disc brakes for all 4 corners and am re-using a 65 B Body 8 3/4 I had laying around along with a set of 4.56 gears. Plan is to use Cal Tracs rear suspension and tie the frame together with the kit from US Cartool. It got backed into the garage today to begin the transformation after removing the stinking gas tank and lines outside a month or so ago.
...FAFO...
[Re: Pacnorthcuda]
#1995227
01/20/16 11:57 PM
01/20/16 11:57 PM
skicker
"The Champ"
"The Champ"
Western Md.
The car was painted in 1993 when the 1/2 vinyl top was removed. It just looks like enamel...not base-clear. The moldings were added around 2010. Why is a mystery but by being garage kept it may not hurt it. There's one small spot that is loose and doesn't look any different under it. I'll definitely be proceeding with caution while using a small heat gun or hair dryer. I could maybe leave them on if they were straight. The DS doesn't look too bad but the PS is up and down...
...FAFO...
[Re: skicker]
#1996542
01/22/16 08:21 PM
01/22/16 08:21 PM
Posts: 1,030 ohio
67mprfan
ohio
Nice project looks simple and easy which none of mine ever turn out to be
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#2027119
03/08/16 11:42 AM
03/08/16 11:42 AM
skicker
"The Champ"
"The Champ"
Western Md.
I ordered a set of the US Car Tool frame rails to tie this together. Dad is adamant that he does not want a roll cage so these should work well with no severe modifications. The floors underneath look clean...someone had glued the replacement carpet down which made it a real PITA to get out and remove all the glue.
...FAFO...
[Re: amxautox]
#2078771
05/23/16 12:34 PM
05/23/16 12:34 PM
skicker
"The Champ"
"The Champ"
Western Md.
Since the "Garden" is more important than the car...forward progress has been lacking... Both of the new frame rails from US Car Tool are mocked up, trimmed and ready to be welded in. These fit pretty decent and are definitely better than cutting the floors for box tube rails when you may not need them. Below is how well they fit in...once the ends are tacked in I can adjust the floors in the center to help close up any gaps...
...FAFO...
[Re: skicker]
#2092890
06/16/16 09:57 AM
06/16/16 09:57 AM
skicker
"The Champ"
"The Champ"
Western Md.
The new US Car Tool frame rails are welded in. They fit pretty good.
...FAFO...
[Re: skicker]
#2092891
06/16/16 10:00 AM
06/16/16 10:00 AM
skicker
"The Champ"
"The Champ"
Western Md.
Inside the floor all you see is the spot welds and they're kind of hard to find. Man its nice not having to do a bunch of rust repair for a change...
...FAFO...
[Re: skicker]
#2092893
06/16/16 10:04 AM
06/16/16 10:04 AM
skicker
"The Champ"
"The Champ"
Western Md.
The new 002 and 003 rear leaf springs are going in now with the 65 B Body 8 3/4 with 4.56 gears. Here's a pic of the sliders were using on this at the rear. The front spring hangers have been moved back 3/4".
...FAFO...
[Re: skicker]
#2092894
06/16/16 10:07 AM
06/16/16 10:07 AM
skicker
"The Champ"
"The Champ"
Western Md.
The wildwood brake parts for the front and rear. Definitely the best way to convert a 4" bolt pattern car to 4 1/2" bolt pattern.
...FAFO...
[Re: skicker]
#2092901
06/16/16 10:19 AM
06/16/16 10:19 AM
skicker
"The Champ"
"The Champ"
Western Md.
This is just for you Tom...
There's also a couple pics of the 416 that will go in later and a bunch of /6 parts for cheap if anyone can use them...
...FAFO...
