Page 2 of 6 1 2 3 4 5 6
Re: how do you make 756HP with a n/a 416? [Re: an8sec70cuda] #1995641
01/21/16 05:36 PM
01/21/16 05:36 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Originally Posted By an8sec70cuda
Justinp61...Pittsburghracer was just trying to help figure out what this combo consisted of, which the OP was asking about in his first post.
I agree that this particular combo seems to run good. Love the Lenco!
Look's to me like the guy has the "Package" pretty well scienced out.
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995658
01/21/16 05:55 PM
01/21/16 05:55 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
AWESOME CAR !!!!!
Re: how do you make 756HP with a n/a 416? [Re: pittsburghracer] #1995675
01/21/16 06:16 PM
01/21/16 06:16 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Yes it does have a vac pump and the usual go fast parts,but so do I minus the vac pump. There is no 4 LINC with double adjustable afcos all around. Just a floating ladder bar a d junc shocks, yet it wheels up every launch and straight as an arrow. He launches at 6000 and shifts at 7800. I'm a little impressed with his combo.
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995683
01/21/16 06:27 PM
01/21/16 06:27 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Yes its a very nice combo and runs great. Just trying to point out that its not a cheap build or probably one that I would pick for a weekly bracket raced program. If it truly weights in the 2800 pound area that makes it even more impressive.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: how do you make 756HP with a n/a 416? [Re: pittsburghracer] #1995829
01/21/16 09:07 PM
01/21/16 09:07 PM
Mt Morris Michigan
Mt Morris Michigan
I understand. Wheather its making 750hp or not I think it runs real good. The front end is all stock but the junk shocks. No tubular control arms or coil overs. A Dana with reinformant and ss spring's and ladder bars on floaters. A very affordable setup IMO. It does have a nice cage. The money is in the engine and trans. My original question was about how do you make that kind of power with what he has.
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995831
01/21/16 09:15 PM
01/21/16 09:15 PM
Mt Morris Michigan
Mt Morris Michigan
Also,if you look at the engine pics you'll see Harland sharp rockers,not t&d or jessel and some of the Carbs had press in air bleeds and the block is an X block,not an r3 or some other high dollar race block like some on here say you must have to live. This engine sees 8000rpm regularly. What kind of compression do you think it would take to make 750 with this combo?
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995838
01/21/16 09:25 PM
01/21/16 09:25 PM
Washington
madscientist Offline
Washington
There is so little difference between the "X" blocks and the "R" blocks it is of little consequence (not including deck heights and over bore potential).
Re: how do you make 756HP with a n/a 416? [Re: madscientist] #1995869
01/21/16 09:56 PM
01/21/16 09:56 PM
Mt Morris Michigan
Mt Morris Michigan
No kidding? I could of bought a X block 5 yrs ago for $1000. Guess I should of bought it. I have heard the bores are thin thou.
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995886
01/21/16 10:20 PM
01/21/16 10:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That car is VERY impressive and looks like a fun ride............. thumbs
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995899
01/21/16 10:30 PM
01/21/16 10:30 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
My old 422 w5 got upgraded and ended up making about 707 horsepower. I would think with a bigger head a true 750 would be easily possible.
Best Machine dyno'ed the W5 and it ended up running 140mph in a 3220 pound Super stock spring car with a 727.
So the numbers definitely line up. That's 14 to 1, gas ported slugs, 043 ring pack, and very good attention to detail in the machine work. Nice heathy roller.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995932
01/21/16 10:51 PM
01/21/16 10:51 PM
Washington
Washington
I just bought one for the smokin price of $800.00 I'd buy every one I can.
BTW I have sonic'd 5 different "X" blocks (including the one I have now) and all would go 4.100 easy. This one will go 4.125 max. I don't know where Chrysler got the 4.03 bore max.
Re: how do you make 756HP with a n/a 416? [Re: B3422W5] #1995967
01/21/16 11:31 PM
01/21/16 11:31 PM
Mt Morris Michigan
Mt Morris Michigan
Don,what compression and cam was in that? What was your port size? If you look at Steve's Dyno sheet you will see peak torque at 6100. How does that happen? He tells me it has a 4" crank.
Re: how do you make 756HP with a n/a 416? [Re: madscientist] #1995969
01/21/16 11:33 PM
01/21/16 11:33 PM
Mt Morris Michigan
Mt Morris Michigan
That was a very good buy. If I stay in the SB world I will look for another X block then.
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995971
01/21/16 11:37 PM
01/21/16 11:37 PM
Mt Morris Michigan
Mt Morris Michigan
I would guess Steve's engine is 14:1+ compression and a very large roller .700+ with the 245 intake port?
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1996105
01/22/16 03:16 AM
01/22/16 03:16 AM
AndyF Offline
AndyF  Offline
Torque peak at 6100 rpm requires a decent port cross section and a healthy camshaft. If you can get an engine to peak up there then you'll usually make good power.
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1996144
01/22/16 08:12 AM
01/22/16 08:12 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
14 or 15.1 compression
Indy 245 heads and intake done from Brett
Custom step headers and a good dominator
And of course a good cam which doesn't need to even be over 800lift.
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1996145
01/22/16 08:15 AM
01/22/16 08:15 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
20.000 will get what you need no problem
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1996148
01/22/16 08:25 AM
01/22/16 08:25 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
People often say it don't run what the #s on the dyno say...Well how many have great working cars ? Half of the mopar guys won't send a converter out or invest in proper shocks..Not The motors fault imo.
My car had freakin tti headers,3.91 gears,and a 5000 stall which IS FAR FROM OPTIMAL FOR A RACE CAR because I drove it on the street.
Re: how do you make 756HP with a n/a 416? [Re: fishy340] #1996216
01/22/16 12:30 PM
01/22/16 12:30 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
that's the reason for my comment about the "package",,it's not just the motor that does the work.
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1996245
01/22/16 01:06 PM
01/22/16 01:06 PM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
Dave you make it sound like its hard to do. The Indy head makes good power and with proper machine work and a solid combination you are there. https://www.facebook.com/media/set/?set=a.605850896137264.1073741836.135175363204822&type=3
This engine did cost appox 24,000 that included the new R3 block and a Callies crank, Compstar rods, CP pistons And T&D rockers. We used his 4150 carb and Vac pump. VP C-12 fuel was used and the heads were CNC ported at Indy and no other work was done to them.
