Page 2 of 3 1 2 3
Re: prefabbed tube chassis install on steel body [Re: turbo toad] #1994406
01/19/16 10:25 PM
01/19/16 10:25 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Don't those bars going to the back off the top of hoop look small to you guys? Maybe 1 1/4. Offer 250 because of the trip.
Re: prefabbed tube chassis install on steel body [Re: turbo toad] #1994437
01/19/16 10:50 PM
01/19/16 10:50 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I don't know about that chassis. There is a significant amount of rust on that thing. Makes me a little nervous. shruggy
[image][/image]
Re: prefabbed tube chassis install on steel body [Re: turbo toad] #1994476
01/19/16 11:19 PM
01/19/16 11:19 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Lots of valid observations.
I always try to be diplomatic about things. With that being said, I wouldn't drive 10 hours for that if it was free. Just saying.
Re: prefabbed tube chassis install on steel body [Re: turbo toad] #1994635
01/20/16 02:02 AM
01/20/16 02:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
That chassis will only cert to 8.50 now days...
thats just like mine... but with a few minor tubes
it can be a 7.50.. in the halo it needs the corner
support tubes for sure... but right now its a 8.50..
it was a 7.50 some years back just like mine was..
but they changed some rules.. if you line up the main
hoop in the right location you can move some stuff...
forget where the wheels will line up... you can fab
the brackets to move them
EDIT
Also check the wall thickness before you buy..
sand it clean and sonic it or have it done..
they increased the wall to.135 from .115 I believe
wave
Re: prefabbed tube chassis install on steel body [Re: turbo toad] #1994658
01/20/16 02:28 AM
01/20/16 02:28 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
1.625" diameter tubing is a minimum .118" wall thickness. Anything 1.5" diameter and smaller is a minimum .108" thickness. These specs are for a mild steel 25.4 chassis that will cert 7.50. Pretty current specs as I just got the paperwork from sfi last week.
Back to the OP. If that chassis was built with .120" wall tubing it may not pass cert with the amount of rust shown. If it was built with .134" wall tubing you should be good if you add/correct the chassis as needed for current sfi specs. Beep
Re: prefabbed tube chassis install on steel body [Re: turbo toad] #1994726
01/20/16 05:13 AM
01/20/16 05:13 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
After looking at added pictures.......that thing is ROUGH. If a PRO built it, he was no PRO chassis builder. I wouldn't drive around the block for it and it be free
Re: prefabbed tube chassis install on steel body [Re: turbo toad] #1994760
01/20/16 10:43 AM
01/20/16 10:43 AM
michigan
turbo toad Offline OP
michigan
Thanks for all the comments and observations thats why i posted the pics. Im on the fence and not sure what or if I'll go look at it. But if i do ill diffently see if i cant get a sonic tester from work and take it with me.
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: prefabbed tube chassis install on steel body [Re: turbo toad] #1994970
01/20/16 04:20 PM
01/20/16 04:20 PM
I bought a Alston Avenger chromemoly kit car chassis that a local guy had assembled and welded up years ago. it look nice but he had mistakenly used .065 wall tubes in the left front door upright bar from the foot bar and used the same material for the foot bar that ran across the front behind the motor. The SFI spec called for .083 tubing there so it wouldn't certified for racing runaway
Make sure and sonic test every bar along with the SFI spec. sheet in your hands when you do the testing up
Re: prefabbed tube chassis install on steel body [Re: turbo toad] #1995003
01/20/16 05:03 PM
01/20/16 05:03 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
What states it in. Someone might be able to look at it for you.
Re: prefabbed tube chassis install on steel body [Re: FastmOp] #1995039
01/20/16 05:31 PM
01/20/16 05:31 PM
michigan
michigan
Its in CYNTHIANA, KY and id be willing to pay someone for there time if they did go and look it over for me so if theres a member in or around the CYNTHIANA, KY area and would be willing to go take a look for me and some take key measurements id paypal them for there time?????
Guys like all of you im on a budget and im trying to make my valiant as safe and as lite as i possibly can with in my means. Any and all help is always appreciated and if a member is willing to go and look this chassis over it would be much appreciated pm me here with a phone number and will go from there
Thanks all
Aaron
Re: prefabbed tube chassis install on steel body [Re: turbo toad] #1995060
01/20/16 05:56 PM
01/20/16 05:56 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
It's about two hours from me. I know we have a track up there by it with some mopar guys. Hope one knows the seller or some info.
I can get up that way but it's going to be a week or two.
If someone is closer that would be good too.
Re: prefabbed tube chassis install on steel body [Re: FastmOp] #1995139
01/20/16 08:53 PM
01/20/16 08:53 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
My advice is to pass on to "deal". By looking at the chassis pics its going to take some work. For slightly more you can get a new chassis that fits your body for the same amount of work(Alsotn Pro Gas chassis) for example. In the end you will have a better and more valuable race car, and probably for the same total $$$
twocents
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: prefabbed tube chassis install on steel body [Re: turbo toad] #1995282
01/21/16 01:14 AM
01/21/16 01:14 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Thanks all
Aaron
Looks like I will be driving tomorrow afternoon and friday night on 75 and they look to be only 15 to 20 minutes out of my way..........
Re: prefabbed tube chassis install on steel body [Re: turbo toad] #1995500
01/21/16 02:06 PM
01/21/16 02:06 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
"Guys like all of you im on a budget and im trying to make my valiant as safe and as lite as i possibly can with in my means."
Ain't we all. But there is such a thing as false economy. You may drag that thing home for $10 and the price of fuel to go get it. How many hours are you going to spend sanding rust? Or how much are you going to pay to have it blasted? What's it going to cost to fix if it won't cert, fix what's broken or not done correctly? And then what's it going to take to get it to fit your application?
The real issue is you may get into this thing, probably spend a lot more money than a new chassis that fits your car would cost, and still have a half a$$ piece. Or get half way into it, give up and junk it and loose all of that money. I see it all the time.
The bare chassis is chump change. Struts, brakes, rear, shocks, plumbing, tin, fuel, electrical, wheels and tires, etc., etc., etc., is where the money gets spent. IMHO, all I see in those pictures are problems, headaches, time and money spent that could have been used more wisely.
Re: prefabbed tube chassis install on steel body [Re: CMcAllister] #1995646
01/21/16 05:46 PM
01/21/16 05:46 PM
dogdays Offline
dogdays  Offline
I know nothing about the subject except that my garage and backyard are littered with the "good deals" I should have passed up. I still have trouble passing up those "deals" that are of negative value.
Negative value is an idea that we should all learn.
Say I find a 1954 New Yorker that I can buy for $200.00. It's a great deal, right? Wrong. That car has negative value.
In buying it I have signed myself up for at least several thousand dollars of expenses before I can even use it. If for some reason I do not use my $200 New Yorker, it will sit there and depreciate forever. My $200 will sit there with it, and I can't even buy beer with the money.
Now I may decide I am willing to invest those dollars and hours because I really have always wanted to drive and own a 1954 New Yorker. If that's the case it IS a great deal, but that $200 purchase still has negative value. Ecomnomists call it "Opportunity Cost". Why? Because by putting that $200 into something, I have passed up the opportunity to invest in something else, which could be better.
If you find yourself using the word "just" in describing the object, it most likely has negative value. "It just has to pass cert." "It just has to be modified to fit my car." etc.
As I said to start, I have learned this lesson many, many times and am weighed down by all the negative value I have piled up over the years.
R.
Re: prefabbed tube chassis install on steel body [Re: dogdays] #1995781
01/21/16 07:58 PM
01/21/16 07:58 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Originally Posted By dogdays
I am weighed down by all the negative value I have piled up over the years.
R.
Preach it... bow I'm in the same boat... rant
To quote a line from Days of Thunder..."your a victim of your own god damn creation" whistling
...FAFO...
Re: prefabbed tube chassis install on steel body [Re: turbo toad] #1996924
01/23/16 12:35 PM
01/23/16 12:35 PM
michigan
michigan
Member Markz528 has offered to try and swing by the sellers place where the chassis is been stored to look it over and take some key measurements and to look over the craftsmanship of the chassis. Ill keep you guys posted.
Re: prefabbed tube chassis install on steel body [Re: turbo toad] #1997062
01/23/16 03:37 PM
01/23/16 03:37 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
That's good I suppose, but having met Mark, seen his car and knowing how he thinks......Pass is going to be the advice. The pictures obviously show this thing is VERY rough
Re: prefabbed tube chassis install on steel body [Re: Monte_Smith] #1997162
01/23/16 06:17 PM
01/23/16 06:17 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Thanks Monte but I will try to be objective!
Unfortunately the weather killed the opportunity to go see it today but I have more opportunities in the next couple weeks that I hope can work. I would like to help..........
Re: prefabbed tube chassis install on steel body [Re: markz528] #1997204
01/23/16 07:27 PM
01/23/16 07:27 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
We are currently in the later stages of a similar build.Started out as an engine swap.62 Lancer w/440. You know what happened next. Purchased welded 4link subframe from A.R.T. as a focal point and built from there.
They offer a 10 point cage kit for a 69 valiant that I asked them to add a foot of length to all the legs. After trimming it fits great,main hoop,halo,and all.We already had CAP front a/arm components,so we just built a jig to incorporate the Lancer front end geometry into the new 2x3 frame rails w/coilovers and rack and pinion. We would have chosen a strut front end, inretrospect,but it started out as an engine swap.
Don't want to highjack your post, so we are going to try to post some pictures soon.IF we can help w/any info, you can pm me here. Good luck
Page 2 of 3 1 2 3
