Re: Bearings and fingerprints
[Re: B G Racing]
#199531
01/21/09 02:18 PM
01/21/09 02:18 PM
Posts: 43,308 Bend,OR USA
Cab_Burge
Bob, you are killing me
oh by the way empty your pm's so I can bug ya some more.
Can't never be too careful,I get the sniff test everytime I come home,by 3 dogs and the wife.Remind me to tell you about the dog humping my leg one night and after I changed cloths he got the jeans out of the hamper and proceeded to molest them infront of Debby,If looks could kill PMs empty,wondered why it was so quite.
Me thanks you and Fred are related Way to deep into other non normal sexual related activitys
[Re: Cab_Burge]
#199534
01/21/09 02:38 PM
01/21/09 02:38 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Cab,It's the "normal sex" that gets me in trouble,the "non normal" she don't care about or wont belive
[Re: B G Racing]
#199535
01/21/09 11:32 PM
01/21/09 11:32 PM
some time ago i sent out 3 sets of coated bearings -1/+1 and std size to a customer. he figured out which ones he needed and sent the others back. not thinking much about it at the time i put them on the shelf and there they sat for a couple of months. little did i think to look at them and make sure they were clean and not abused. fast forward to an occasion where i needed a -1 set of bearings. the fingerprints destroyed not only the Calico coating, but the lead/indium layer just crumbled apart too. they weren't even good enough for mock up bearings and went in the trash pronto. bearings could sit in oil forever, but fingerprints left on them will take their toll for sure.
[Re: dthemi]
#199537
01/22/09 12:10 AM
01/22/09 12:10 AM
i'm not totally sure of what the intent of the original post was. i just wanted to share my experience. as far as touching bearings goes, i touch every one of them i install in an engine as i put assembly lube on them. that's not quite the same as leaving fingerprints on them though, especially if it's for an undetermined amount of time.
[Re: dthemi]
#199539
01/22/09 01:29 AM
01/22/09 01:29 AM
Posts: 602 Alexandria, VA
SealockRacing
Alexandria, VA
havent built a big block, or a small block, but 2 strokes, i was a pro at it. did a little research from the old man and pretty much figured it out myself, if i locked one up and there was nothing visible in the cylinder, i could feel the problem, and know it was no good. you get the point. i think this stuff is in my genes John
