Front Valance Difference 71 72 vs 72 74 Charger #1993458
01/18/16 05:58 PM
01/18/16 05:58 PM
Ct, Hartford
birdfan70 Offline OP
Ct, Hartford
What is the difference between valances? I was told that 7172 were different than 7374 but I am not sure. If the are different how do you tell them apart . Thanks
Re: Front Valance Difference 71 72 vs 72 74 Charger [Re: birdfan70] #1993713
01/18/16 11:17 PM
01/18/16 11:17 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I think it's the brackets that attach the valance to the frame rails that changes from '72 to '73.
Re: Front Valance Difference 71 72 vs 72 74 Charger [Re: 71charger] #1993888
01/19/16 03:03 AM
01/19/16 03:03 AM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
correct. The brackets are different. Also the early 71's have a slightly different shape to the back of the lower valance.
The turn signal light housings used different connectors over the years as well.
Re: Front Valance Difference 71 72 vs 72 74 Charger [Re: birdfan70] #2149485
09/07/16 11:45 AM
09/07/16 11:45 AM
Ct, Hartford
Ct, Hartford
Thanks for the help.
