Water pump housing date. #1989892
01/13/16 02:41 PM
01/13/16 02:41 PM
Blair County,PA
62maxwgn Offline OP
62maxwgn  Offline OP
Blair County,PA
How would you interpret this date code ?
Re: Water pump housing date. [Re: 62maxwgn] #1990162
01/13/16 08:41 PM
01/13/16 08:41 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Looks like 2-21 to me.
Re: Water pump housing date. [Re: 62maxwgn] #1990169
01/13/16 08:49 PM
01/13/16 08:49 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
don't have a clue but i'm sending you a pm.
Re: Water pump housing date. [Re: 62maxwgn] #1990173
01/13/16 08:52 PM
01/13/16 08:52 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Am I the only one that thinks it 12-21? maybe I would see it different if it were in my hands..
Re: Water pump housing date. [Re: QuickBpBp] #1990179
01/13/16 08:53 PM
01/13/16 08:53 PM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline
268RTs4ME  Offline
Do u have a casting # or part # u can post???
Re: Water pump housing date. [Re: 62maxwgn] #1990677
01/14/16 03:41 PM
01/14/16 03:41 PM
Maryland
Grnfsh Offline
Grnfsh  Offline
Maryland
I have the same question, I have a housing with the part number of 2780987 with appears to be a date code of 11-03.
Re: Water pump housing date. [Re: 62maxwgn] #1991118
01/15/16 03:57 AM
01/15/16 03:57 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Looks like the '62-'63 housing I sold on ebay years ago. I assume it's 1962 or '63 without seeing the casting number.
Re: Water pump housing date. [Re: 52savoy] #1991146
01/15/16 05:20 AM
01/15/16 05:20 AM
Didn't all the early , pre 1968, water pump housing have the alternator mounting hole centered closer to the center of the thermostat housing? confused
Re: Water pump housing date. [Re: 62maxwgn] #1991163
01/15/16 08:54 AM
01/15/16 08:54 AM
2
268RTs4ME Offline
268RTs4ME  Offline
Your 2780987 fits 67-68 A Body 383, fits a 67 B Body 426, fits a 67-68 BC Body 383 440, fits a 68\69 B Body 426, fits a 69 ABC Body 383\440, fits a 71 BCE Body 383\426\440, fits a 67\68 BC Body 383\440, and a 70 BCE Body 383,426,440.
Re: Water pump housing date. [Re: QuickBpBp] #1991239
01/15/16 01:47 PM
01/15/16 01:47 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I see 12-21
Re: Water pump housing date. [Re: 62maxwgn] #1991307
01/15/16 03:55 PM
01/15/16 03:55 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
1666 and older had the alternator bracket bolt on the thermostat boss, 67 and newer it was off of there towards the alternator. Cakes different alternator bracket with no hole in the center. The newer Mopar performance aluminum water pump housings have both bolt bosses on them.
Another quick tell is the two water neck bolts go all the way through the ears on 1966 and older housing, on 1967 and newer the holes bottom out in the casting, they do not go through to daylight.
Re: Water pump housing date. [Re: Morty426] #1991409
01/15/16 06:28 PM
01/15/16 06:28 PM
Blair County,PA
62maxwgn Offline OP
62maxwgn  Offline OP
Blair County,PA
I see 12-21
If 12-21,12-21 of what ?
Re: Water pump housing date. [Re: 62maxwgn] #1991965
01/16/16 02:27 PM
01/16/16 02:27 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Cab, It got by me on the bracket boss.
It looks to be a 1971 housing if my memory hasn't failed me. I believe starting in '71, the funny looking triangle with a year next to it was used. I'll have to check my collection to be sure.
Re: Water pump housing date. [Re: 52savoy] #1991971
01/16/16 02:35 PM
01/16/16 02:35 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I don't think so. I thought that starting in 70 there would be a Pentastar on the inlet. There isn't one in this picture so I would say this is 69 or older.
Re: Water pump housing date. [Re: 62maxwgn] #1991978
01/16/16 02:42 PM
01/16/16 02:42 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I'm not really sure because it's been about ten years the last time I researched this.
Just checked a few housings. The pentastar moved around and wasn't always on the neck.. pictures coming soon. Still looks to be a '71
Re: Water pump housing date. [Re: 62maxwgn] #1992007
01/16/16 03:22 PM
01/16/16 03:22 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
My camera sucks...... Upper left going clockwise... 1967, 68, 69(and 70?), 71 and '72
well upper right.. need to rotate the picture.
Re: Water pump housing date. [Re: 62maxwgn] #1992075
01/16/16 05:37 PM
01/16/16 05:37 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
This the water pump from my 1970 Sixpack Heater Delete Superbee.
It's dated 06029 - 6/2/1969 exactly 2 months before the SPD of the car.
Re: Water pump housing date. [Re: 62maxwgn] #2460415
03/03/18 12:11 PM
03/03/18 12:11 PM
VA
dragon slayer Offline
VA
I know this is old post, but Mort, What are the numbers stamped on the upper driver side of the pump? I found a similar pump but has extra stamp.
Re: Water pump housing date. [Re: dragon slayer] #2460434
03/03/18 12:45 PM
03/03/18 12:45 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
So what's the mystery production date on this big block housing I have?
Unstamped warranty housing shruggy
