Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: batt2rm] #1990591
01/14/16 01:25 PM
01/14/16 01:25 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: 1968RR] #1990647
01/14/16 02:50 PM
01/14/16 02:50 PM
dogdays Offline
dogdays  Offline
The quest for "best oil" is as fallacious as the quest for the "most beautiful woman". No such thing, although Monica Bellucci comes close.
As far as zinc goes, it is possible to have too much zinc. And while zinc is the first word in the chemical name of the compound most commonly used as an antiwear additive, I believe it is actually the phosphorus in the compound that does the work. Here's an excerpt from a paper on the use of zinc dialkyl dithiophosphate (ZDDP): "ZDDP decomposes to form a polyphosphate film on the surface".
There are many good oils specifically blended for use in high performance flat tappet engines. If I had to pick a family I'd go straight to Joe Gibbs Driven oils.
R.
