Adding part-throttle kickdown to earlier VB?
#199000
01/20/09 03:51 PM
01/20/09 03:51 PM
Posts: 1,069 Washington State
70Duster440
Washington State
I've got a '68 727 with TF2 kit. Converter stalls at about 2500-2800. Shifts fine. Full-throttle kickdown works fine. At slow speeds, under a load (such as turning up an incline) it stays in 3rd and essentially becomes a dog unless I mash the throttle or manually downshift. Is it possible to add part-throttle kickdown without changing the VB? This guy promises an amazing transformation with a mod that costs as much as a new VB: http://www.brauerengineering.com/trans/index.htm
Re: Adding part-throttle kickdown to earlier VB?
[Re: 70Duster440]
#199003
01/21/09 08:37 PM
01/21/09 08:37 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Erik's valve bodies are quite amazing. Have one in everything I own that is TF equipped except for one. He's a little hard to get ahold of these days but if you can, it's well worth it. His mods are completely different than any off the shelf kit as he epoxies certain passages to make the VB do what he wants. Can't wait till I can get him out to do the last one!
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: 70Duster440]
#199004
01/22/09 01:14 PM
01/22/09 01:14 PM
Posts: 1,286 Ft. Lauderdale, FL
solarguy
Ft. Lauderdale, FL
I'm confused here. Is there a Part throttle kickdown AND a Full throttle kickdown or are they one and the same?? I'm asking because I recently changed to a higher stall converter and while shift points are good, kickdown doesn't come in exactly where I want it since rpm is a little higher. linkage adjusted to get great shift points up come down a little late. before converter swap, kickdown came in at a better point
thanks
[Re: RapidRobert]
#199010
01/23/09 04:49 PM
01/23/09 04:49 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The early PTK like the one pictured in my original reply has no limit valve, depending on the axle ratio the PTK can occur at some pretty high road speeds and this can be annoying. My '57 NY with 2.94 gears will still PTK at 60 mph.
The '71 and later PTK module contains a limit valve and spring to limit the PTK to below 40 mph but the limit function won't work when retrofitting the '71 and later module to the earlier VB. The only way to get the limit feature in an earlier trans is to swap in the entire VB.
[Re: 70Duster440]
#199012
01/23/09 08:23 PM
01/23/09 08:23 PM
solarguy
Ft. Lauderdale, FL
70Duster440, do you have a part number and source for those prepackaged modules?
[Re: 70Duster440]
#199013
01/23/09 08:49 PM
01/23/09 08:49 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
"Also, is it true that if you decrease the space between the kickdown valve and the throttle pressure cam that it will downshift at a higher "closed throttle" condition?"" Bump
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: solarguy]
#199015
01/23/09 09:47 PM
01/23/09 09:47 PM
70Duster440
Washington State
Sorry, I don't. Sounds like bigslant6fan (above) might though.
[Re: 70Duster440]
#199018
01/24/09 03:52 PM
01/24/09 03:52 PM
Posts: 203 Taneytown, MD
bigslant6fan
Taneytown, MD
sorry I don,t,all mine are used,and the square type doesn,t even have any casting nos.
