Re: Electronic ignition or standard points style distributor?
[Re: vinnyd76]
#1986219
01/08/16 12:42 PM
01/08/16 12:42 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
I hate change but I went away from points.I ran a Mallory dula point till about 15 years ago.You can run the points dist with Petronix and look almost stock.Not a big deal to go with factory dist and box unless its a 100 point resto.Rocky
Chrysler Firepower
[Re: vinnyd76]
#1986338
01/08/16 03:48 PM
01/08/16 03:48 PM
RapidRobert
You posing the Q tells me originality ain't an issue. Was the '70 originally a points app? (I'm assuming yes per the Q). I'd likely go electronic with a regular 70's electronic dist and a good American made ECU (not an orange box) and an E coil. An HEI can mount under the dist with the tailor made ($$$) alum plate or (easily) make your own. Use some Radio Shack heat sink paste with it. this would keep the point based firewall uncluttered with the addition of an ECU. For the points app (or going with Pertronix its needed) AZ has rebuilt dists for cheap. The P system needs minimal bushing play & has its own caveats, nothing too serious, IE iirc the P 1 cannot use solid core plug wires & I'd get the P II if I was going that route
[Re: poorboy]
#1986712
01/09/16 02:15 AM
01/09/16 02:15 AM
Posts: 598 Glendale, CA
whuston383
Glendale, CA
I gotta say like most all other Mopar guys, I've followed the Mopar tech advice and installed electronic conversions (Mopar Performance, MSD, Accel, and Mallory) on my cars. I still own the ones with Mopar Performance(2 cars), MSD, and Mallory. The Mopar Performance Orange box on my Roadrunner has left me stranded twice in 20 years! Now, I keep one in the trunk of the car; not a low-cost spare to keep on hand. The others don't get driven enough to see a fail rate. These cars are always in a climate controlled garage when not being driven, for record purposes.
Just over 4 years ago, I dragged a non-op 63 Fury home from the Lake LA/high desert. The contacts on the points were gone. As in GONE! There was nothing left other than the point body assembly on either side, so those got replaced. Other than a set of points and points only, I'm running the same plugs, wires, cap, rotor, coil, and condenser from the day I dragged it home. It runs great! Since getting it road worthy again in late 2013, I've put over 5000 miles on it. I left this car this way just to see how much hype might be behind the whole electronic ignition movement. Is a point ignition really THAT unreliable? Time and driving will continue to tell. I've not touched anything under that distributor cap since I installed those points and got the thing running. I haven't even put the timing light on it. I have revived friend's cars with point ignitions and no spark simply by dragging 600 grit sandpaper between the contacts and reinstalling the cap. They are still running on those points today.
I know, I know. I'm weird and against the masses here. This is just information to consider. I'm not saying put in a point ignition and I'm certainly NOT putting the point ignitions back in my other cars. But, I'm going to leave this one alone and keep running it until I see/feel a degradation in performance that warrants a look-see into a potential ignition problem. Until then, I've got that extra set of points I paid $2.90 for, and a 3/16" blade screwdriver, in the glovebox just in case.
Oh yeah. One more thing. My 63 Fury More Door Hardtop sits outside. Year round. In the rain. It has never failed to start. It rained like 5 inches in the last 3 days here. The car starts and runs.
Wow. You say you have a Sports Fury? Talk about rare.
[Re: vinnyd76]
#1986739
01/09/16 03:13 AM
01/09/16 03:13 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I agree there's nothing wrong with points. To do a comparison , I was drag racing a pretty stock 440 years ago with a Mallory Double Life dual point distributor. It was so old it was really hard to find points/rotor for it. My buddy talked me into buying a MSD 6-AL box and a MSD billet distributor, not that my engine was running bad, actually it ran fine. So I spent the money and the results were not even noticeable , not even a hundredth of a second difference in ET.. So , in my case I wasted money going to electronics with that engine. Now that being said , now with more cubes, more compression, more RPM's and of course horse power I think the electronics probably work better.
[Re: rowin4]
#1986754
01/09/16 03:30 AM
01/09/16 03:30 AM
RapidRobert
I have a points dist & a new set of points just collecting dust. sometime I'm gonna try it & set the gap at .010" for the longest dwell (.008" if it will start/run) & see how it acts. small gap=longest dwell (saturation time/most power)=shortest life (contacts are together for longer time to arc/burn/wear out): best for performance. All of that inversely proportional. For Grandmas' DD, widest gap (at least .017" for the longest life). EDIT IIRC the dwell on electronic ign (MP) is 42 (dist) deg ?? 45 is an eighth of a (dist) turn so that or a micro second less would be the max possible (dwell time). MORE EDIT for a serious points afficionado get a copy of the Jacobs' ign bible. 3/4 of that thing is devoted to points!
[Re: RapidRobert]
#1986762
01/09/16 03:58 AM
01/09/16 03:58 AM
whuston383
Glendale, CA
Well, it's great to know I'm not the 'Lone Weirdo' and I have good company! I promise I will post when/if this ignition needs any maintenance or adjustment. Hopefully, I'll be able to find this string when it happens.
[Re: vinnyd76]
#1986854
01/09/16 12:39 PM
01/09/16 12:39 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
My Cuda still runs points
The only thing wrong with points is the slant six, real PITA to adjust them then.
[Re: vinnyd76]
#1986909
01/09/16 02:46 PM
01/09/16 02:46 PM
Supercuda
About to go away
About to go away
up yours
Yeah, I do that too, but it's a PITA anyway.
[Re: vinnyd76]
#1988948
01/11/16 11:58 PM
01/11/16 11:58 PM
Posts: 10,634 Freeport IL USA
poorboy
Freeport IL USA
I did time with a lot of point distributors. The old factory dual point units were good. Some of the single point setups could be dialed in very well.
The reality is, the dwell on a set of points changes constantly. Higher RPM make it worse, and point bounce also comes into play. The point rubbing block wears down, and changes the dwell (reduces dwell angle or the degrees the points are open) as well. As the dwell angle reduces, the timing retards. The points also become pitted and give inconsistent dwell resulting in inconsistent spark timing. The problem is, with a point dist, the change is usually carried out over several months and is often unnoticeable by the driver.
The two current issues with a points dist are: 1) The points dist are aging or of are new questionable quality. Most have inconsistent cam lobe high point locations. Old dist find the lobes wore off, often at varying degrees per specific cam lobe, and new ones may never have been correct in the beginning. If the cam lobes are not consistent in the degrees of separation, the cylinders are not consistent in the degrees of timing each cylinder is firing. You probably won't feel a couple degrees of difference in cylinder timing, but it can show up in the power curve. The issue is, with a point dist, the thing that determines cylinder firing is a wear part. 2) Points availability isn't was it was in the heyday of points distributors. Back then, high quality points were available from several sources. Today the number of companies actually making points is pretty limited, and the quality is questionable.
Most of the short comings of dealing with points can be corrected with with a watchful eye and continual tinkering using the highest quality parts available today, if that is how you want to spend your time with your Mopar. I prefer to drive mine, so its electronic ignition for me. Gene
