Modify LOOKS of steering column from auto to floor shif
#198842
01/20/09 10:22 AM
01/20/09 10:22 AM
Posts: 406 Houma, Louisiana
twister360
Houma, Louisiana
I just installed a TCI Street fighter floor shifter in my Duster with an automatic shift on the column. Can I remove the shift lever and the shift indicator on the column and replace with parts that will make it look like an automatic on the floor? If so, what are the replacement parts I would need and where to find? Thanks Gary
My car 74 Duster mild 360/904/3.91 13.44/101.54
Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408
2004 Dodge Ram 1500 Laramie 5.7
2010 Dodge Challenger R/T Classic B-5 6 speed
2010 Jeep SRT8 for the little wife
Re: Modify LOOKS of steering column from auto to floor shif
[Re: duckblind]
#198844
01/20/09 10:33 AM
01/20/09 10:33 AM
twister360
Houma, Louisiana
In the past I saw where someone had a collar for a column for sale that looked like it would repalce the shift indicator. Not sure this could be done, but was in hopes that it could without changing out the entire column. Thanks Gary
[Re: Pntastar69]
#198848
01/20/09 06:16 PM
01/20/09 06:16 PM
Posts: 7,861 Witness Protection Program
Kudakidd
I cut the tabs off the bowls, filled them in, then repaint. Looks just like a manual column.
Hey Mark, looks like it's gonna be awhile until we row those 4 speeds, huh? We got 51" of snow and its still mid -Jan!
To answer the question; I bit the bullet and bought a good used manual transmission column and swapped it in.
[Re: Kudakidd]
#198849
01/20/09 06:29 PM
01/20/09 06:29 PM
twister360
Houma, Louisiana
Could the change be made with just changing the collar?
[Re: chrisf]
#198850
01/20/09 07:38 PM
01/20/09 07:38 PM
Posts: 3,136 Palm Coast, FL (near Daytona B...
Blown_Hemi
I have done this twice on Dodge trucks. First one was a non tilt and I got all the parts to convert it from the dealer. Second was a tilt column which was never offered in trucks with a floor shift, 1970's trucks. I cut and filled the holes with JB weld, sanded and painted it. Turned out great.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
[Re: DaytonaTurbo]
#198852
01/20/09 09:17 PM
01/20/09 09:17 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
Back when I converted my 70 Charger from Column to floor, I just replaced the two collars on the steering column with a 70 B Body collar, I am sure A & B body collars are the same. Remember that you also have a collar at the bottom of the column in the engine bay that lines up with a linkage that goes to your trans. I chiseled mine off, straightened it out and painted it.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#198853
01/21/09 09:57 AM
01/21/09 09:57 AM
twister360
Houma, Louisiana
did one collar replace two collars? Thanks Gary
[Re: Rug_Trucker]
#198855
01/21/09 11:00 AM
01/21/09 11:00 AM
twister360
Houma, Louisiana
So, do you have the parts I need? Is it for sale? Thanks Gary
[Re: twister360]
#198856
01/21/09 11:33 AM
01/21/09 11:33 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
If you are asking me? No nothing for sale. Just burnt out with too many projects and not enough time.
[Re: Rug_Trucker]
#198857
01/21/09 11:59 AM
01/21/09 11:59 AM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
I was looking at the FSM for my 67 Barracuda last night. Yes, the top of the column does come apart. You will need the part where the indicator is and the part where the gear selector is. Interesting in that I have been watching parts for sell and have never noticed either of these two parts offered. It may be even more specific by years 67-69, depending on where the key fits on later model column cars. I have a 67 so never noticed when it switched over. Looks to me like this is all pot metal too. I get the grinding off part, but there must be something better than bondo to use. I was looking at the indicator part wondering if one could not save the top metal part of the indicator and perhaps try epoxying in the very top portion of it(cut the sides off) and then use a product like Metal to Metal or All Metal to fill in and smooth out.
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
[Re: Kudakidd]
#198858
01/21/09 01:27 PM
01/21/09 01:27 PM
Posts: 2,757 Gilbertsville, PA 19525
Pntastar69
Maybe you have 51", we have maybe 5" total the entire winter so far. Only 2" left in some places.
[Re: Pyper70]
#198860
01/21/09 05:08 PM
01/21/09 05:08 PM
Posts: 4,804 Castlegar, BC, Canada
That AMC Guy
I know this may sound odd, but has anybody ever considered leaving the quadrant on the column as a display only? Grind the nub for the shift handle off and leave the quadrant and all it's associated linkage hooked up so when you move the lever on the floor, the quadrant indicates the proper gear as well?
I think that'd be neat. Less work too!
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: That AMC Guy]
#198861
01/21/09 08:35 PM
01/21/09 08:35 PM
twister360
Houma, Louisiana
The factory linkage has been removed in order to install the TCI Street Fighter floor mounted shifter. There was no way to have both of them in working order. I just wanted to make the steering column look like a manual column with out having to change the entire column. I checked with the dealer this morning and the necessary parts to convert are not available. Does anyone know of a steering column repair shop that may have the spares I need. If all fails I will need a manual column if anyone has a spare to sell. Thanks Gary
