Re: Preferences on cage design?
[Re: sgcuda]
#1988875
01/11/16 10:39 PM
01/11/16 10:39 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Scratch starting isn't a problem any more. Between getting the right electrodes, and the right settings and gas, a nicely ground tip makes this thing a breeze to start. No effort at all. Now, I can't figure out how I couldn't get it to start in the first place.
[image][/image]
[Re: cudaman1969]
#1989017
01/12/16 01:25 AM
01/12/16 01:25 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I would put the A pillar bars close to the A pillars going through the pad... see where your VIN is and make sure you clear it... this is what I did on my Rampage... you can see them here.. they go down through the dash pad
[Re: MR_P_BODY]
#1989023
01/12/16 01:52 AM
01/12/16 01:52 AM
Posts: 8,388 fredericksburg,va
cudaman1969
fredericksburg,va
I would put the A pillar bars close to the A pillars going through the pad... see where your VIN is and make sure you clear it... this is what I did on my Rampage... you can see them here.. they go down through the dash pad How did you put the pad in? Just notch it?
[Re: cudaman1969]
#1989033
01/12/16 02:11 AM
01/12/16 02:11 AM
MR_P_BODY
Mine ended up being sorta notched.. if you can drill a hole in it and put the tube through it then weld it.. its mainly about how you will assemble that area of the car.. mine is a separate chassis(I set the body down over the chassis) so I had to notch part of the pad.. if your welding in the tubes while its in the car then just cut a hole with a hole saw and stick the tube through it
[Re: MR_P_BODY]
#1989044
01/12/16 02:25 AM
01/12/16 02:25 AM
cudaman1969
fredericksburg,va
Mine ended up being sorta notched.. if you can drill a hole in it and put the tube through it then weld it.. its mainly about how you will assemble that area of the car.. mine is a separate chassis(I set the body down over the chassis) so I had to notch part of the pad.. if your welding in the tubes while its in the car then just cut a hole with a hole saw and stick the tube through it I'm going to drop the cage down to weld the top of the bars so the dash will go in later. I'll notch it then piece-glue the piece back in I guess.
[Re: cudaman1969]
#1989050
01/12/16 02:40 AM
01/12/16 02:40 AM
MR_P_BODY
I'm going to drop the cage down to weld the top of the bars so the dash will go in later. I'll notch it then piece-glue the piece back in I guess. [/quote] The way a dash is on a L-body(Rampage is the same in the front of the car) is the pad covers the face of the dash and on to part of the top.. then it has a metal plate thing.. this is where the defroster ducts come up.. I had to notch both parts so there wasnt anything to glue in for me... but maybe you will have to
[Re: MR_P_BODY]
#1989075
01/12/16 04:46 AM
01/12/16 04:46 AM
cudaman1969
fredericksburg,va
I'm going to drop the cage down to weld the top of the bars so the dash will go in later. I'll notch it then piece-glue the piece back in I guess. The way a dash is on a L-body(Rampage is the same in the front of the car) is the pad covers the face of the dash and on to part of the top.. then it has a metal plate thing.. this is where the defroster ducts come up.. I had to notch both parts so there wasnt anything to glue in for me... but maybe you will have to [/quote] 73 Cuda
[Re: Stanton]
#1989164
01/12/16 12:34 PM
01/12/16 12:34 PM
Posts: 22,821 Bitopia
jcc
Bitopia
One set for alum, one for steel. Haven't heard of that. What's the reason? The main concern is for cleanliness with alum, steel often being dirtier and oiled, steel tigging is more forgiving. Your gloves contaminating the tig rods is where the issue arises. I have a thumb wheel and a pedal, switch between when the need arises, put pedal is always my first choice. Miller recently offered a wireless floor pedal, which is lighter and must be a lot easier inside a car to use, but found out after installing it, it only works with the newest machines.
[Re: sgcuda]
#1990954
01/14/16 10:45 PM
01/14/16 10:45 PM
sgcuda
I have a new favorite toy store: Airgas! After only one of the tool trucks that come to my dealership had welding gloves, he told me $60.00. Took a trip to Airgas, where we get our supplies from. 2 #5 cups, a cheater lens, 3 pairs of tig gloves (buy 2, get 1 free) state tax, county tax, district tax, total came to $23.07. I wanted some ER70S6 filler rod, but they were all out. I guess that means another trip next week
[image][/image]
[Re: sgcuda]
#2039284
03/26/16 07:01 PM
03/26/16 07:01 PM
sgcuda
I just want to take the time to say "Thank You" to everybody that helped me get through the initial walking steps of Tig welding. To all my friends, co-members, and just anyone who cared enough to add a response and give some guidance, Thank You All. I welded my first critical pieces today, the Racecraft ladder bars. I bought the unwelded kit for a custom length. Practiced on a couple of pieces of scrap C/M before I attempted to weld the fittings to the tubes. I was nervous because of the thin wall tubing and the solid fittings absorbing heat differently. All of a sudden, you just "Get it". The sound, the puddle, the arc, just all starts to flow as one. Was really a cool experience. Tomorrow, the rear suspension goes into the chassis. I can't wait to install the cage.
[Re: sgcuda]
#2039299
03/26/16 07:28 PM
03/26/16 07:28 PM
MR_P_BODY
Glad to see your getting the hang of it.. when you weld thick and thinner parts its all about the direction of the tip to apply the heat to the thicker part... get it hot enough to make your puddle then you will see you have to start backing out of the heat... have fun EDIT once you get the hang of it you will see your color rings will be the same distance all the way around
[Re: sgcuda]
#2040201
03/28/16 01:20 AM
03/28/16 01:20 AM
Thumperdart
State of confusion
Damn, look at you go boy.............lol! Nice job man........
[Re: sgcuda]
#2040399
03/28/16 01:48 PM
03/28/16 01:48 PM
MR_P_BODY
Looks great... now learn how to weld when you are all out of position(like damn near upside down)LOL.. the biggest thing about welding is being comfortable and being able to see the weld.... I have to get a new cheater lens for my helmet.. mine has a few scratches and of course they are right where they are in my sight
[Re: sgcuda]
#2040936
03/29/16 02:05 AM
03/29/16 02:05 AM
sgcuda
Thanks for the comments, guys. You're right Mr P. Have already been bouncing my head around the inside of the car welding up mounting brackets for the frame rails and tacking the cross members in place. I try very hard to maintain the 3 P's: 1)Practice (I try to simulate welds on scrap materials to get the right settings before the actual pieces are welded.) 2) Patience (Take my time, on small, thin materials, stop and cool down, maintain a clean electrode tip) 3) Pee before welding (Hey, I'm getting old. Not my fault. )
[image][/image]
