Re: MuuMuu's 68 Dart... It's a Learning Process...
[Re: MuuMuu101]
#1931191
10/13/15 12:28 AM
10/13/15 12:28 AM
moparpollack
Lil Herman
Lil Herman
85086
Well I guess the puppy can only ride shotgun as the bars go thru where the back seat should be. If this is more a street car why didn't they put the bars thru the package tray?
I bet Brian could make that 273 scream!
[Re: moparpollack]
#1931209
10/13/15 12:54 AM
10/13/15 12:54 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
That's what I was expecting, but I didn't want rear seats in there since it was getting a cage. The two don't click with me. But, I kind of like it as now it's easier to put a sound system back there. The 273 is going to be my project after the Dart is up and running.
[Re: MuuMuu101]
#1931231
10/13/15 01:49 AM
10/13/15 01:49 AM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
So, Hotchkis made some progress on the Dart. It seems the roll cage is almost done. It just needs me to sit in it to get the side impact members mocked up. So, I'll probably do that before the end of the week. At the same time, I'll be taking my engine to IMM to get looked over. I'm still not certain yet, but I may be removing the supercharger and either just building a 360 or 408.
I also purchased some goodies. I was able to locate a pair of use MP offset shackles. That will help with my rear wheel rub as I can take off the 5mm spacer that's currently their. I also found another pair of wheels that I liked that are 18 x 9.5" and what I believe to be the perfect offset to fit a 275/35/18 tire all the way around without rubbing and at a point where I could actually rotate them. If I find a buyer for my current wheel setup, I might just pounce on it. Did they make that cage specifically for your car or is it some kind of generic kit that they installed? I can't say the I have ever come across another one done like that.
A new iron curtain drawn across the 49th parallel
[Re: 67autocross]
#1931234
10/13/15 02:13 AM
10/13/15 02:13 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I also purchased some goodies. I was able to locate a pair of use MP offset shackles. That will help with my rear wheel rub as I can take off the 5mm spacer that's currently their. I also found another pair of wheels that I liked that are 18 x 9.5" and what I believe to be the perfect offset to fit a 275/35/18 tire all the way around without rubbing and at a point where I could actually rotate them. If I find a buyer for my current wheel setup, I might just pounce on it. Did they make that cage specifically for your car or is it some kind of generic kit that they installed? I can't say the I have ever come across another one done like that. They based it off the 4-point cage on JEGS website. ( http://www.jegs.com/i/Jegster/550/941701K/10002/-1) They said it'll be quicker and cheaper for me to find a cage with an already bent roll tube than them charging me the labor for making a custom one. I'm not sure if JEGS roll cage was designed to go through the back seats or the speaker holes. The diagonal tube that goes from the driver's top to the passenger bottom was added for extra rigidity. The boxed section at the bottom of the roll hoops were custom in case I flipped so the tubes wouldn't go straight through the floor. There will be a little extension added to the rear window cranks so the rear windows can still roll down. There will be an added side impact member with a swing-out since it's very difficult for me to get into cages do to my size and hip problems.
[Re: MuuMuu101]
#1931746
10/13/15 11:47 PM
10/13/15 11:47 PM
67autocross
Manitoba Canada
I also purchased some goodies. I was able to locate a pair of use MP offset shackles. That will help with my rear wheel rub as I can take off the 5mm spacer that's currently their. I also found another pair of wheels that I liked that are 18 x 9.5" and what I believe to be the perfect offset to fit a 275/35/18 tire all the way around without rubbing and at a point where I could actually rotate them. If I find a buyer for my current wheel setup, I might just pounce on it. Did they make that cage specifically for your car or is it some kind of generic kit that they installed? I can't say the I have ever come across another one done like that. They based it off the 4-point cage on JEGS website. ( http://www.jegs.com/i/Jegster/550/941701K/10002/-1) They said it'll be quicker and cheaper for me to find a cage with an already bent roll tube than them charging me the labor for making a custom one. I'm not sure if JEGS roll cage was designed to go through the back seats or the speaker holes. The diagonal tube that goes from the driver's top to the passenger bottom was added for extra rigidity. The boxed section at the bottom of the roll hoops were custom in case I flipped so the tubes wouldn't go straight through the floor. There will be a little extension added to the rear window cranks so the rear windows can still roll down. There will be an added side impact member with a swing-out since it's very difficult for me to get into cages do to my size and hip problems. Thanks for the reply, it's always interesting to see people do things a bit different.
[Re: MuuMuu101]
#1942452
10/31/15 08:20 PM
10/31/15 08:20 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Went and visited Hotchkis yesterday. I dropped off some parts and discussed the game plan with them. We also measured and mocked up my side impact members and they should be pretty neat. Then I took the engine and drove it all the way to IMM engines. Unfortunately, I didn't realize there was coolant still in the water pump. So, once I made the first stop leaving the driveway I heard a stream of coolant dump onto the floor of the SUV.
[Re: MuuMuu101]
#1942457
10/31/15 08:24 PM
10/31/15 08:24 PM
moparpollack
Lil Herman
Lil Herman
85086
Looks like you learned something! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: MuuMuu101]
#1957516
11/25/15 03:15 AM
11/25/15 03:15 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
So, another bit of an update. I just talked to Brian at IMM engines. When he tore my engine apart, he was surprised that it had all stock internals. He said the block was good but was in need of a rebuild as all of the bores were about 0.003" out of round. Anyway, we talked it over and speculated what would be the best method to pursue for this engine (supercharger vs. stroking) and we decided stroking.
Here are some specs on the engine: 408, forged SCAT rotating assembly (4.00" stroke, 0.030" overbore), EQ Magnum Cylinder heads adapted to the LA block, hydraulic roller cam and lifters, ARP fasteners, Milodon Road Race oil pan and pick up, 1.6 aluminum rocker arms, Marley 5/16 push rods, 750 DP carburetor w/ 1/2" carb spacer, MSD ready-2-run distributor, match-ported Edelbrock LD4B etc.
It should make about 500-575 hp according to Brian. ETA on dyno day is going to be sometime around mid-January.
[Re: MuuMuu101]
#1958494
11/26/15 08:45 PM
11/26/15 08:45 PM
Posts: 4,704 Wichita
GY3
Wichita
Looks like you learned something! Weight transfer? Always bring rags? Or that the 273 isn't in the back of the SUV? Obvious that it is a 360 because of the external balance flexplate!
[Re: MuuMuu101]
#1983770
01/04/16 10:13 PM
01/04/16 10:13 PM
Posts: 8,150 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
I like what you're doing ![popcorn popcorn](/ubbthreads/images/graemlins/custom/popcorn.gif) if your blower needs a home we'll find it one ![devil devil](/ubbthreads/images/graemlins/custom/devil.gif) (Some might say bolt it to your 273 ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) )
[Re: UCUDANT]
#1983796
01/04/16 10:35 PM
01/04/16 10:35 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I like what you're doing ![popcorn popcorn](/ubbthreads/images/graemlins/custom/popcorn.gif) if your blower needs a home we'll find it one ![devil devil](/ubbthreads/images/graemlins/custom/devil.gif) (Some might say bolt it to your 273 ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) ) I'm thinking about canning off all the extra parts I don't need. Just less space in the garage, more money in my pocket, and it won't tempt me to get another vehicle (I was thinking about a '72-75 truck, maybe not so much now). I'm not sure if I have the energy (or money) to do another old vehicle. If I get a truck, I might just get a newer 1500 with a 5.7L Hemi. But if I were to do it (and I was planning on it initially), I was thinking about finding some old TRW 10.5:1 pistons, forged crank and rods, a set of 360 heads with 1.8" valves (already have from a crate engine and would bring the engine down to about 9-9.5:1), just plopping on the M1 intake (already have), and add supercharger with 7-8 lbs of boost. That should of made a high revving screamer with at least 300 hp easy. Or, I could throw it on the 408 in the future, but that would be scary. Probably be pushing around to 600-700 hp. Ever since I announced I was going stroker in my Stroker vs. Supercharged thread I've gotten countless people messaging me on my threads and pm's asking how much I want that supercharger for. It gets pretty annoying after awhile.
