Page 2 of 5 1 2 3 4 5
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #1987398
01/10/16 04:35 AM
01/10/16 04:35 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Originally Posted By lockjaw-express
hi Jeremiah,
I have the "old discontinued" bellhousing...are you saying my 15330 bell won't work?
Did you have the later mfg 15335?
I guess I am a little confused on what bell you actually have.
BTW, Chris at Hyatt RS told me that as long as you have the original bellhousing serial number from Lakewood, they can recertify it. Or, you can send back to Lakewood for them to modify and certify.
br, Mark
"The old lakewood 15330 was drilled for an a-230 similar to a stock bell. The Lenco adapter plare isdrilled for an a-230. They discontinued the 15330 and superseded the part number to the already existing pn 15335 which does not have the smaller a230 pattern. I purchased another 15335"
We now own two Lakewood 15335 bellhousings. Hopefully I can make them work in their respective cars.
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #1987453
01/10/16 12:00 PM
01/10/16 12:00 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Very nice looking B-body! I think you're gonna need more hood pins with your new motor. smile
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #1987476
01/10/16 12:46 PM
01/10/16 12:46 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Hi JericoGTX,
Tim selected a disc that would work both on the street and the strip with high HP...it will slip a small amount for the street, and with reduced static pressure it will slip much more.
I did not get a full answer to that question from Beth or Chris, but then again, a lot has happened for them. They do have other employees from what I could gather.
Have you been driving your clutch on the street?
br, Mark
i have one of Tim's clutches, i ran it on the street for a summer. long as your left leg is up to snuff they work good!! It will squeak a bit when its hot if your trying to maneuver around tight spaces like a parking lot. mine would still be in there but i ran out of sacrificial hemi 4 speeds...
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: 68 HEMI GTS] #1987525
01/10/16 01:36 PM
01/10/16 01:36 PM
Ohio
lockjaw-express Offline OP
Ohio
Hi pro sport, thank you, however a good friend of mine did the original restoration.
68hemigts,
Thank you for the picture, and I am hoping for good results. Tim Hyatt told me that the Lenco St-1200 would be the best to handle any track use. He also told me that the street manners are very good, and that clutch use would be at a minimum.
I ordered mine with the heavy duty sprags for any driver error for the street.
BTW, Very nice '68 Dart you have!
Br, Mark
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #1987609
01/10/16 03:35 PM
01/10/16 03:35 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I'm glad to not be going down this road alone any more. Thank you for sharing your research. After looking at the pictures it appears that you have the 15330 bell so it should be good.
Keep us updated!
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: Jeremiah] #1993723
01/18/16 11:26 PM
01/18/16 11:26 PM
Ohio
Ohio
I received my Browell Bellhousing alignment tool today, and it is well made!
Too cold here in Cincinnati to work on the car (5 degrees outside & too cold in the garage)!
BR, Mark
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #1993763
01/19/16 12:05 AM
01/19/16 12:05 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Those sure are nice drool I have a few machinist buddies out there that will make one for me after I get the blueprints done. I want to have the register adapter machined so it will do large and small bell openings,just flip it around for whatever retainer you have.
Sounds like it's going to be an awesome machine up
Gus beer
64 Plymouth Savoy
Dana 60
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2002134
01/30/16 07:40 PM
01/30/16 07:40 PM
Ohio
Ohio
Here are the pictures of the RobbMC Starter to clear TTI Headers, and a very well made product.
I also used RobbMC Offset dowels, and they are very well made, and worth every penny!
Got everything aligned and ready to mount the Lenco, which should be here around the 8th of February.
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2002156
01/30/16 08:07 PM
01/30/16 08:07 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Nice setup! Just an observation, will that white paint stay after heated cycles? I wouldn't want you to have to make adjustments under the car and not be able to tell what hole is what...
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2002157
01/30/16 08:08 PM
01/30/16 08:08 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: Dave Hall] #2002190
01/30/16 08:43 PM
01/30/16 08:43 PM
Ohio
Ohio
Hi Dave, yes it is high-temp paint. I also have a window in the bottom and can mark them as well.
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: ProSport] #2002310
01/30/16 11:25 PM
01/30/16 11:25 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
Bob, car should look familiar, it was Labrat's(Randy B's).
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: Blown 68 R/T] #2002379
01/31/16 12:35 AM
01/31/16 12:35 AM
Ohio
Ohio
yes, it is Randy's GTX!
I will race it with his motor to get it in the 10's as Randy wanted, then off to putting a Aluminum Block Big inch Hemi!
Then 9.90's
Mark
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2002400
01/31/16 12:48 AM
01/31/16 12:48 AM
Shannonville, Ont
Shannonville, Ont
Mark
Sounds awesome!
A big Hemi/Lenco , Randy will be smiling up above!
Think you're selling yourself short with the 9.90's running 800+hp. keep us posted with your progress, maybe see ya at Norwalk sometime. beer
Kevin
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: Blown 68 R/T] #2002487
01/31/16 02:54 AM
01/31/16 02:54 AM
Ohio
Ohio
hi Kevin,
I am doing all of the upgrades that Randy wanted to do, and then some...
I am hoping the lenco will work out for the street, but I trailer my cars most places anyway.
I am planning on attending the Mopar Race in Norwalk this year, and I look forward to seeing you all there.
BR, Mark
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2002871
01/31/16 08:12 PM
01/31/16 08:12 PM
Rittman Ohio
Rittman Ohio
Yeah I'm sure Randy would approve up I'm really glad someone like you got that car.Randy and I discussed putting a stick in that car after his hip surgery but that's about all the further it went.
Nice car,hope to have my Savoy back together before Norwalk in July.
See you then.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: fourgearsavoy] #2010146
02/11/16 09:54 PM
02/11/16 09:54 PM
Ohio
Ohio
I got my Lenco and shifters today, and Lenco will ship out my input shaft and bearing retainer on Monday!
I was told to run 10w-30 motor oil in the transmission, and not ATF.
More to follow of my floor pan (small area rusted out) and tunnel mods.
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2010178
02/11/16 10:47 PM
02/11/16 10:47 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Sure is purty, hope you get it all together and make it to Norwalk this year, I would like to see it in person. up
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2010275
02/12/16 01:02 AM
02/12/16 01:02 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Hi Rowin4 & sgcuda,
Tim Hyatt told me that the type of disk would be street friendly with the Lenco. The static pressure is set at 1475#, however, I would need to bring that down to 800# for the strip.
Curious question? It is at 1475# now. How many turns in or out does it take to adjust it down to 800#?
Jerry
Old Geezer Racing
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2010294
02/12/16 01:30 AM
02/12/16 01:30 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
You would have to check with Chris. Depends on the spring pressures and the thread pitch.
[image][/image]
